I have been downloading MSNBC news shows from https://livenewschat.eu/politics/ for later viewing and it has worked fine for a long time. But since some time it no longer works.
If I visit that URL I am getting redirected to https://livenewschat.eu/msnbc-live-stream/ instead.
I can play the video fine in my browser (Firefox) using this URL, but my download script has stopped working over the weekend...
When I try to run my normal download command I get this response:
Can someone please help?Code:Data from /home/user/www/MSNBC/url_strm.txt URL used: https://livenewschat.eu/politics/ https://cdn-ca2-na.lncnetworks.host/hls//index.m3u8 [https @ 0x55cf84f14840] HTTP error 404 Not Found [in#0 @ 0x55cf84f13ec0] Error opening input: Server returned 404 Not Found Error opening input file https://cdn-ca2-na.lncnetworks.host/hls//index.m3u8. Error opening input files: Server returned 404 Not Found
Details:
I use ffmpeg version N-121199-g5cb6d2221a-20250924 (a more recent version than is provided by apt on Ubuntu) so I can use the moov handling.
My script (a normal bash shellscript) needs the m3u8 url of the video stream in order to retrieve the video and also a working referer URL.
The ffmpeg command looks like this:
The variables are set as follows:Code:CMD="ffmpeg -hide_banner -loglevel warning ${MODE} -i \"${M3U8URL}\" -r 30 -vf scale=w=-4:h=480 -c:v libx264 -preset fast -crf 26 -x264-params keyint=30:scenecut=0:open-gop=0 -c:a aac ${MOVFLCMD} -t ${CAPTURETIME} ${TARGETFILE}" #
CAPTURETIME and TARGETFILE are script arguments for the duration in seconds and the output mp4 file nameCode:read -r VIDEOURL M3U8URL < "$URLFILE" #Read the current URL and M3U8 from file MODE="-referer \"${VIDEOURL}\"" MOVFLCMD="-movflags +frag_keyframe+empty_moov+default_base_moof -frag_duration 2000000"
As can be seen the two crucial items are VIDEOURL and M3U8URL and these are extracted separately just minutes before the download starts using a separate script. I believe the main problem is the m3u8 extraction script command which writes the file...
This is the current content of the URLFILE as created by my getm3u8 script, which worked fine until Friday:
Code:https://livenewschat.eu/msnbc-live-stream/ https://cdn-qc1-na.lncnetworks.host/hls//index.m3u8
I can switch download sites using the m3u8 URL creator script with a site selector for argument and it writes the two items to the file read by the download script.
What I need now is an extraction script command to retrieve the correct VIDEOURL and M3U8URL for the changed site.
Can someone here please provide an extraction command which will work to get the correct referer and m3u8 for the site?
change your M3U8URL to https://cdn-tx1-na.lncnetworks.host/hls/msnbc_live/index.m3u8
and add
-referer "https://livenewschat.eu/"
to your
CMD="ffmpeg -hide_banner -loglevel warning ${MODE} -i \"${M3U8URL}\" -r 30 -vf scale=w=-4:h=480 -c:v libx264 -preset fast -crf 26 -x264-params keyint=30:scenecut=0:open-gop=0 -c:a aac ${MOVFLCMD} -t ${CAPTURETIME} ${TARGETFILE}" -
C:\Documents and Settings\Administrator\Desktop>ffmpeg -headers "Referer: https://livenewschat.eu
/msnbc-live-stream/" -hide_banner -i "https://cdn-qc1-na.lncnetworks.host/hls/msnbc_live/index.m3
u8" -c copy v.ts
[https @ 07a9b940] No trailing CRLF found in HTTP header. Adding it.
[hls @ 07a9af80] Skip ('#EXT-X-VERSION:3')
[hls @ 07a9af80] Opening 'https://cdn-qc1-na.lncnetworks.host/hls/msnbc_live/1762791173500.key' f
or reading
[hls @ 07a9af80] Opening 'crypto+https://cdn-qc1-na.lncnetworks.host/hls/msnbc_live/1762791191500
.ts' for reading
Input #0, hls, from 'https://cdn-qc1-na.lncnetworks.host/hls/msnbc_live/index.m3u8':
Duration: N/A, start: 12913.767000, bitrate: N/A
Program 0
Metadata:
variant_bitrate : 0
Stream #0:0: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709), 720x404 [SAR 1:1
DAR 180:101], 30 fps, 29.97 tbr, 90k tbn
Metadata:
variant_bitrate : 0
Stream #0:1: Audio: aac (HE-AAC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp
Metadata:
variant_bitrate : 0
Output #0, mpegts, to 'v.ts':
Metadata:
encoder : Lavf60.11.100
DAR 180:101], q=2-31, 30 fps, 29.97 tbr, 90k tbn
Metadata:
variant_bitrate : 0
Metadata:
variant_bitrate : 0
Stream mapping:
Stream #0:0 -> #0:0 (copy)
Stream #0:1 -> #0:1 (copy)
Press [q] to stop, [?] for help
frame= 60 fps=0.0 q=-1.0 size= 205kB time=00:00:02.01 bitrate= 831.4kbits/s speed=3.23x
frame= 103 fps= 87 q=-1.0 size= 256kB time=00:00:03.48 bitrate= 601.8kbits/s speed=2.93x
frame= 133 fps= 77 q=-1.0 size= 512kB time=00:00:04.43 bitrate= 945.2kbits/s speed=2.58x
[hls @ 07a9af80] Opening 'https://cdn-qc1-na.lncnetworks.host/hls/msnbc_live/1762791197500.key' f
or reading
[hls @ 07a9af80] Opening 'crypto+https://cdn-qc1-na.lncnetworks.host/hls/msnbc_live/1762791197500
.ts' for reading
frame= 179 fps= 42 q=-1.0 size= 512kB time=00:00:06.01 bitrate= 697.2kbits/s speed=1.42x
frame= 233 fps= 47 q=-1.0 size= 768kB time=00:00:07.78 bitrate= 807.7kbits/s speed=1.59x
frame= 263 fps= 48 q=-1.0 size= 768kB time=00:00:08.79 bitrate= 715.8kbits/s speed=1.59x
I ended up in getting a script that gave me:
The problem earlier was how to extract the full M3U8URL, so it became non-working.Code:VIDEOURL="https://livenewschat.eu/msnbc-live-stream/" MODE="-referer \"${VIDEOURL}\"" and M3U8URL="https://cdn-qc1-na.lncnetworks.host/hls/msnbc_live/index.m3u8"
Also it seems like the start of the M3U8URL following // is changing from call to call among about a dozen candidates.
Now running.
Has 3D Youtube downloader stopped working for anyone else?
By adrian44 in forum Video Streaming DownloadingReplies: 27Last Post: 28th Jan 2025, 13:18 -
Get_iplayer has stopped working
By Gameshow Host in forum Video Streaming DownloadingReplies: 1Last Post: 28th Sep 2024, 08:45 -
aacgain has stopped working
By DarrellS in forum AudioReplies: 6Last Post: 1st Sep 2023, 12:23 -
EME logger stopped working
By hgfdgfui in forum Video Streaming DownloadingReplies: 6Last Post: 31st May 2023, 03:31 -
Download a video from uefa.tv. Stopped working
By tko4 in forum Video Streaming DownloadingReplies: 6Last Post: 16th Jul 2021, 04:07
cenecut=0
