  1. So, a website lets you "preview" contents (it's rent platform) and loads full film once you click play. There is timer on the page after 2-3 minutes you must refresh the page because it no longer let you watch the rest. Since it loads full movie I can grab m3u8 url via cat-catch copy N_m3u8DL-RE code and download is starting. But after that 3 minutes have passed N_m3u8DL-RE can't download new .ts fragments because supplied m3u8 URL is changed on the website. I clicked again preview it loads full movie again with fresh m3u8 url but everything inside is the same (key, key address). They use JWPlayer.
    I give some randomized example (no actual link) which can give you the method and I'd like to your help how to deal with constantly changing m3u8 url? I can't disclosure the name obviously...
    1st preview 1080p randomized m3u8 url:
    https://randomwebsite.com/s/f3b7c1e9a84d2f6b0c9e5a7d1b2c3e48/8394712650/47286/files/21/01/8397152/31473-zT8vKpR2mXq9bLd-drm-aes.ism/10288-zT8vKpR2mXq9bLd-drm-aes-audio=128000-video=1302000.m3u8
    key address:
    https://randomwebsite.com/47286/files/21/01/8397152/31473-zT8vKpR2mXq9bLd-drm-aes.ism.key
    Key method: AES-128
    in 2nd url only red text is changed. 2nd key address is exactly the same with first one.
    I can play .ts files that downloaded during preview no DRM. Image
    [Attachment 89566 - Click to enlarge]
  2. You won't get the 'full' version from the 'preview'.
  3. Originally Posted by LZAA View Post
    I got this thinking because once I load url to N_m3u8dl it shows full length of the movie and m3u8 contains all segments. Theoratically, I could download whole movie under 3 min if my internet speed is fast enough.. gigabit or something.
  4. Show 'ts' fragment URL.
  5. Originally Posted by LZAA View Post
    https://randomwebsite.com/s/f3b7c1e9a84d2f6b0c9e5a7d1b2c3e48/8394712650/47286/files/21/01/8397152/31473-zT8vKpR2mXq9bLd-drm-aes.ism/10288-zT8vKpR2mXq9bLd-drm-aes-audio=128000-video=1302000-1.ts
    Same url goes with 1-2-3.ts.
    Top info in m3u8
    #EXTM3U
    #EXT-X-VERSION:4
    ## Created with Unified Streaming Platform  (version=1.12.8-28913)
    #EXT-X-PLAYLIST-TYPE:VOD
    #EXT-X-MEDIA-SEQUENCE:1
    #EXT-X-INDEPENDENT-SEGMENTS
    #EXT-X-TARGETDURATION:2
    #USP-X-TIMESTAMP-MAP:MPEGTS=900000,LOCAL=1970-01-01T00:00:00Z
    I can only preview 3 times btw. It has expired after that.
  6. Can you download the latest addresses in the playlist?
  7. Originally Posted by LZAA View Post
    Yes. I chose last 30 segments on cat-catch can watch the latest part of the movie.
  8. I can try to do it.
