hello, i'm ordering a dvr-104 in the next few days, it comes with power director but i decided to download nero as most people seem to use this for dvd burning.
However after downloading version 5.5.8.0 the dvd burn option did'nt appear so i downloaded the newest version, 5.5.8.2 but the dvd burn options still did not ap[pear.
Why? is it because i need to have a dvd burner installed first?
And i downloaded the right versions i can tell when they load up.
Please help i don't want to have to download another version!
Results 1 to 12 of 12
Thats just what I asked 2 other people here, I also don't have the dvd option with nero 5.5.8.2. Can anyone out there shed some light on this if they know whats going on?
I don't believe that Nero's DVD options wil show up unless you have a DVD burner installed (they do not on the PC here that has no DVD burner, but show up on the PC which does have a DVD burner).
On another note, I'm not sure which OS the first poster uses, but the other 2 use XP Pro and Win2000, and I'd ask if they were logged on as an Administrator both when installing Nero, and if they have set any user permissions for non-administrators.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
i use windows me and i am not hooked up to a network so i have no administrator issues.
oh, you_are_alive, in response to something you said on another thread, when i loaded up nero 5.5.8.2 it came up as nero express but when i entered in a serial number it changed back to regular nero too.why's that? anyway, the dvd burn options might appear when i install the 104, but if thats the case i find it strange that nero does'nt even mention dvd burning in the help files. -
I only log on as Administrator always. Also, I think thats it then, you need a DVD writer. I guess I should just use my authoring software to also burn my movie. Mirror Image, have you made miniDVDs and XSVCDs? I know quality is different to everyone, but between these 2 formats, with lets say a bitrate of 3000, which one looks better on TV when played off your set top player?
Thanks boss for the reply from the other thread. I think we need a DVD writer. Let us know what happens after you install the 104, and if Nero changes afterwards.
Even if you do not own a DVD-Recoder, you can test the DVD
support by burning DVD images which can be burnt on supported
DVD-recorders In Nero go to "preferences" ... "expert settings"
and tick the "show all compilation types" checkbox.
See: http://www.nero.com/en/dvd_info.htm
Henk-Jan -
I was at the nero site before but did not come accross that page. I tried what it said and it worked! thanks henk-jan! but options to burn a ddcd came up as well a dvd. What is a ddcd?
I did a search on the net and it came up with Double Density CD. It looks like it is a 1.3Gb cd-r. I never heard of it before, but you're never to old to learn.
Greetings,
Henk-Jan -
I just did a search for the double density CDR and noticed that sony procuce them. Does'nt say if they are compatible with all cdrw though or if you need a special burner. These would be great if they worked with a regular burner, no more 2 disc vcd's. Anyone got anymore info on these discs, i'm surprised I hav'nt seen them mentioned on the forum before.
Craig -
From looking at this link DDCDR is not compatible with current CDRW burners, so with DVDr here I really don't see the point.
http://www.cdrinfo.com/hardware/sony200e/index.shtml
Craig
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
ImgBurn and Nero will not burn backup DVD
By rcguy1 in forum Newbie / General discussionsReplies: 4Last Post: 29th Jan 2008, 10:05 -
Nero won't burn video DVD
By solo_voyager in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2007, 22:06 -
How to burn DVD data with Nero 7?
By Kakui in forum Newbie / General discussionsReplies: 5Last Post: 28th Oct 2007, 17:00 -
DVD Shrink/Nero burn errors
By chibimaru in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Jun 2007, 04:22
