When I upload avi to Virtualdub it writes that audio and video file has variale birtrate and to save it to uncompresed WAV or recompresed to MP3 whit CBR. When I do that and make VCD or SVCD the audio in film is stoping (breaking) every second ant like that throuaut the film-
Load the avi in Vdub. Audio >> Full processing mode then File >> Save wav. This will be a big uncompressed wav, and it WILL work. You are likely saving a compressed wav. Check the size. Typically it should be ~ 1GB.
Try using Nandub instead Virtualdub. Nandub handles VBR MP3 files, VirtualDub doesn't!!!
Jolly
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 08:39 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 04:55 -
Converting VBR avi Xvid/divX to wmv9
By surfmonkee in forum Portable VideoReplies: 4Last Post: 17th Nov 2008, 03:54 -
WMV3 and WMSpeech to Divx and mp3 VBR
By logicom in forum Video ConversionReplies: 6Last Post: 19th Oct 2008, 17:31 -
Convert divx vbr to cbr audio - video freezes (possible reason & soluti
By lingyi in forum AudioReplies: 0Last Post: 4th Oct 2007, 16:51
