Ok here it is... I have a movie file over 730mb...but time wise 72 minutes. I use a cd-rw 650mb 0r74minutes...I was told we can burn up to 74 minutes on a cd like that but nero keep asking me to finalize it because too big of a files...I want to know what to do ? I choosed to finalize one but i saw after that that I wont be able to reburn on it???? So how do you manage to fit that 72 minutes over 730mb unto a cdrw and still be able to reburn on it??? Help fast please I am wai ting![]()
well if you are using a cdrw, then you finalize the session, watch it and etc. when you are ready to burn something else to the disc, in nero go under recorder and choose erase rewritable. Depending on your player sometimes a quick erase will work but some players will need you to do a full erase on the disc. You'll loose the original information from the first burn, but are able to put anything else you want on it.
Is there a way to not have to finalize a DVD after burning?
By EagleW in forum Authoring (Blu-ray)Replies: 3Last Post: 27th Jan 2010, 16:56 -
Problems Burning Discs with DVDshrink/Nero
By iownju in forum DVD RippingReplies: 5Last Post: 20th Jul 2008, 16:56 -
USING Nero TO SOLVE ALL BURNING PROBLEMS?
By guitarparth in forum Newbie / General discussionsReplies: 8Last Post: 16th Nov 2007, 19:18 -
Finalize DVD-R PROBLEMS
By wswingsze in forum DVD & Blu-ray WritersReplies: 8Last Post: 13th Sep 2007, 22:12 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 16:36
