Can someone explain clearly how please to install devine or unshackle in windows. The cmd pip install devine does nothing all I get is
C:\devine\devine-master> pip install devine
'pip' is not recognized as an internal or external command,
operable program or batch file.
HELP !!
before you install python,
check python add PATH...
[Attachment 89400 - Click to enlarge]
[Attachment 89399 - Click to enlarge]Last edited by iamghost; 27th Oct 2025 at 14:14.
Ok right thanks now what do I do ?
C:\devine\devine-master>pip install devine
ERROR: Ignored the following yanked versions: 3.3.3
ERROR: Could not find a version that satisfies the requirement devine (from versions: none)
ERROR: No matching distribution found for devineLast edited by tvdownloaderfan; 27th Oct 2025 at 15:40.
It looks like Python or pip isn’t added to your system PATH, reinstall Python from python.org, make sure to check “Add Python to PATH” during setup, then reopen CMD and try pip install devine again.
C:\unshackle\unshackle-main>install
=== Unshackle setup (Windows) ===
[OK] uv is already installed.
Resolved 91 packages in 3ms
Updating https://github.com/vevv/subby.git (5a925c367ffb3f5e53fd114ae222d3be1fdff35d) x Failed to download and build `subby @
| git+https://github.com/vevv/subby.git@5a925c367ffb3f5e53fd114ae222d3be1fdff35d `
|-> Git operation failed
`-> Git executable not found. Ensure that Git is installed and available.
help: `subby` was included because `unshackle` (v1.4.8) depends on `subby`
[ERR] Dependency install failed. See errors above.
Press any key to continue . . . -
Thanks so how do I download from a url as this doesn't work (example)
uv run unshackle dl https://xxxxxxxx/episode/xxxx/xxxxxxxxxxx
Configuring devine to use a proxy
By dwk33 in forum Video Streaming DownloadingReplies: 5Last Post: 11th Jan 2026, 10:03 -
Unshackle - Modular Movie, TV, and Music Archival Software
By SummerArk in forum Video Streaming DownloadingReplies: 629Last Post: 11th Jan 2026, 05:37 -
Semi-automated guide to install stabbedbybrick's fork of Devine
By SaintyUK in forum Video Streaming DownloadingReplies: 62Last Post: 2nd Sep 2025, 17:03 -
Devine on Android
By PSXman_uk in forum Video Streaming DownloadingReplies: 5Last Post: 2nd Nov 2024, 17:07 -
help with install Devine
By macos in forum Video Streaming DownloadingReplies: 2Last Post: 14th Aug 2024, 05:58
