A fast stand-alone for times when firing-up your all-in-one is too much.
Have a widevine cdm called device.wvd in the same folder as this script.
Edit line 41 to be your file save location.
fastALL4.py
I only write the code. Posting here carries no implication of support.PHP Code:''''
An alternative Channel 4 downloader using web-browser web endpoints.
Whilst it recovers 1080p resolution video, the bitrate is not quite
as high as Android endpoints provide.
The script is fast!
After the first run, when python creates runtime files and an AES key
is fetched and stored, the time to start downloading appears almost instantaneous.
A_n_g_e_l_a October 2025
USE: Just enter the C4 program_id found at the end of video urls eg 77297-003
Either on command-line enter
python fastALL4.py 74035-001
python fastALL4.py https://www.channel4.com/programmes/astrid-murder-in-paris/on-demand/74035-001
or just python fastALL4.py and enter program_id at prompt.
from httpx import Client, HTTPError
import re
import json
from cryptography.hazmat.backends import default_backend
from cryptography.hazmat.primitives.ciphers import Cipher, algorithms, modes
from cryptography.hazmat.primitives.padding import PKCS7
import base64
from pywidevine.pssh import PSSH
from pywidevine.device import Device
from pywidevine.cdm import Cdm
import os
import subprocess
import struct, uuid
from concurrent.futures import ThreadPoolExecutor
import sys
import pyfiglet as PF
SERVICE_CERT_HINT = "CAQ="
KEYCACHE = "./.keycache/C4keydata.json"
n_m3u8dl = "N_m3u8DL-RE"
# -- set this for your preferences
DOWNLOAD_DIR = "./"
WVD_PATH = "./device.wvd"
# -- end set
# --- create tmp folder to hold subtitles
if not os.path.exists("./tmp"):
os.makedirs("./tmp")
# --- ./tmp deleted by N_m3u8dl_re on completion
# --- create keycache folder to store AES KEY/IV
if not os.path.exists("./.keycache"):
os.makedirs("./.keycache")
class KeyRefreshNeeded(Exception):
pass
# data silo
class Title():
def __init__(self, title, episode,subtitle, key, episode_id = None):
self.title = title
self.episode = episode # any text for episode
self.episode_id = episode_id # in form S01E02
self.subtitle = subtitle
self.key = key # media decryption
# -- OUTLINE
# -- 1. look for cached AES KEY, IV previously obtained
# -- 2. If not found, download app.bundle.js and search for KEY,IV and store
# -- 3. Get VOD Stream data for the program_id
# -- 4. From data returned find enc_token - and decrypt with AES KEY,IV to find license url and ANOTHER token.
# -- 5. Use new token and license url to obtain a certificate. (1st license call)
# -- 6. Create DRM Challenge and include certificate in POST request to license url (2nd license call)
# -- 7. Parse license response for media decryption KEYS
# -- decryption related --
def load_cached_keys():
try:
with open(KEYCACHE, "r") as f:
data = json.load(f)
f.close()
KEY = data.get("KEY", "").encode()
IV = data.get("IV", "").encode()
if len(KEY) != 16 or len(IV) != 16:
raise ValueError("Bad key/iv lengths")
return KEY, IV
except FileNotFoundError:
return None
except Exception:
# Corrupt cache: remove and refetch
try: os.remove(KEYCACHE)
except FileNotFoundError: pass
return None
def save_cached_keys(KEY: bytes, IV: bytes):
tmp = KEYCACHE + ".tmp"
with open(tmp, "w") as f:
json.dump({"KEY": KEY.decode(), "IV": IV.decode()}, f)
f.close()
os.replace(tmp, KEYCACHE)
def fetch_fresh_keys(client):
url = "https://static.c4assets.com/all4-player/latest/bundle.app.js"
try:
bundle = client.get(url, timeout=8).text
except HTTPError as e:
raise RuntimeError(f"fetch bundle.app.js failed: {e}")
k_hits = re.findall(r'"bytes1":"([^"]+)"', bundle)
v_hits = re.findall(r'"bytes2":"([^"]+)"', bundle)
if not k_hits or not v_hits:
raise RuntimeError("bytes1/bytes2 not found in bundle.app.js")
KEY_s, IV_s = k_hits[0], v_hits[0]
KEY, IV = KEY_s.encode("latin-1"), IV_s.encode("latin-1")
raise RuntimeError(f"KEY/IV wrong size ({len(KEY)}, {len(IV)}), expected 16/16")
save_cached_keys(KEY, IV)
return KEY, IV
def get_keys_with_cache(client):
kv = load_cached_keys()
if kv:
return kv
return fetch_fresh_keys(client)
def decrypt_message(message_b64: str, KEY: bytes, IV: bytes) -> str:
try:
decryptor = Cipher(algorithms.AES(KEY), modes.CBC(IV), backend=default_backend()).decryptor()
unpadder = PKCS7(128).unpadder()
cbytes = b64u_decode(message_b64)
padded = decryptor.update(cbytes) + decryptor.finalize()
pt = unpadder.update(padded) + unpadder.finalize()
return pt.decode("utf-8")
except Exception as e:
# Signal caller to refresh keys
raise KeyRefreshNeeded from e
def b64u_decode(s: str) -> bytes:
Decode a URL-safe Base64 string (with '-' and '_') and
auto-fix missing padding.
s = s.strip().replace("\n", "")
s += "=" * (-len(s) % 4) # pad to multiple of 4
return base64.urlsafe_b64decode(s)
# --- end decryption ops ---
# -- create pssh box
def make_widevine_pssh(kid_hex: str,
system_id: str = "edef8ba9-79d6-4ace-a3c8-27dcd51d21ed",
version: int = 0) -> str:
Build a Widevine PSSH (v0) containing one KID.
Returns base64-encoded PSSH box.
# SystemID as 16 raw bytes (no dashes)
sysid_bytes = uuid.UUID(system_id).bytes # big-endian, correct for MP4/pssh
# KID as 16 bytes
kid_bytes = bytes.fromhex(kid_hex.replace("-", ""))
if len(kid_bytes) != 16:
raise ValueError("KID must be 16 bytes (32 hex chars).")
# Widevine PSSH data: field 0x12 (repeated key_id), length 0x10 (16), then the KID
# This is the minimal valid Widevine protobuf payload.
data = b"\x12\x10" + kid_bytes
# MP4 'pssh' box: size(4) + type(4) + version/flags(4) + systemID(16) + data_size(4) + data
size = 4 + 4 + 4 + 16 + 4 + len(data)
box = struct.pack(">I4sI16sI", size, b"pssh", version, sysid_bytes, len(data)) + data
return base64.b64encode(box).decode("ascii")
def get_kid(transcode_id: str) -> str:
''' C4, uniquely, allows default_kid to be constructed,
transcodeId is normally 7 or 8 binary digits.
code here deals with length differences'''
n = int(transcode_id, 10) # decimal → int
if not (0 <= n <= 0xFFFFFFFF):
raise ValueError("transcode_id out of 32-bit range")
tail = f"{n:08x}" # 8 hex chars, zero-padded
return "0" * 24 + tail
def generate_pssh(transcodeId: str = None):
default_kid = get_kid(transcodeId)
return make_widevine_pssh(default_kid)
# --- Widevine license helper ---
DEFAULT_HEADERS = {
"Content-type": "application/json",
"Accept": "*/*",
"Referer": "https://www.channel4.com/",
"user-agent": "Mozilla/5.0 (X11; Linux x86_64; rv:143.0) Gecko/20100101 Firefox/143.0"
def build_drm_today_payload(request_id: str, token: str, mpd_url: str, message_b64: str = "") -> dict:
# build payload to match C4 pattern
payload = {}
if token:
payload["token"] = token
if request_id:
payload["request_id"] = request_id
if mpd_url:
payload["video"] = {"type": "ondemand", "url": mpd_url}
if message_b64:
payload["message"] = message_b64
else:
payload['message'] = SERVICE_CERT_HINT
return payload
def post_json(client, url: str, data: dict, headers: dict) -> dict:
r = client.post(url, json=data, headers=headers)
try:
j = r.json()
except Exception:
raise RuntimeError(f"License server returned non-JSON (HTTP {r.status_code}): {r.text[:500]}")
if r.status_code >= 400:
raise RuntimeError(f"HTTP {r.status_code} from license server: {j}")
return j
def fetch_service_certificate(client, lic_url: str, request_id: str, lic_token: str, mpd_url: str) -> str:
# First POST: get signed DRM service certificate
payload = build_drm_today_payload(request_id, lic_token, mpd_url)
j = post_json(client, lic_url, payload, DEFAULT_HEADERS)
if not j.get("license"):
raise RuntimeError(f"Missing 'license' field in service certificate response: {j}")
return j["license"]
def request_license(client, lic_url: str, request_id: str, lic_token: str, mpd_url: str, challenge_bytes: bytes) -> str:
# Second POST: base64 of the CDM challenge inside 'message'
challenge_b64 = base64.b64encode(challenge_bytes).decode("ascii")
payload = build_drm_today_payload(request_id, lic_token, mpd_url, message_b64=challenge_b64)
raise RuntimeError(f"Missing 'license' field in license response: {j}")
return j["license"]
def pad_number(number):
return format(int(number), "02d")
def prompt_prog_id(default="74015-001"):
try:
s = input(f"Program ID ({default})?: ").strip()
return s or default
except (KeyboardInterrupt, EOFError):
print("\nAborted.", file=sys.stderr)
raise
def main(url):
client = Client()
with ThreadPoolExecutor(max_workers=1) as ex:
key_future = ex.submit(get_keys_with_cache, client) # disk/network in background
if url == "":
progId = prompt_prog_id()
elif len(url)>10:
progId = url.split('/')[-1] # https://www.channel4.com/programmes/astrid-murder-in-paris/on-demand/74035-001
else:
progId = url # 74035-001
try:
my_data = client.get(f"https://www.channel4.com/vod/stream/{progId}").json()
raise RuntimeError(f"fetch vod stream data failed: {e}")
vps = my_data["videoProfiles"]
if len(vps) <= 1:
raise RuntimeError(f"Expected at least 2 profiles; got {len(vps)}: {vps!r}")
stream = vps[1]["streams"][0]
# sanity: make sure it's still the one we expect
expected = "dashwv-dyn-stream-1"
actual = vps[1].get("name", "?")
if actual != expected:
raise RuntimeError(f"Profile[1] changed: expected '{expected}', got '{actual}'. Full entry: {vps[1]!r}")
uri = stream["uri"]
enc_token = stream["token"]
asset_id = my_data["transcodeId"] # both names 'asset_id' and 'transcodeId' used in code
# wait for keys from threadPoolExecutor
KEY, IV = key_future.result()
# the stream token hides -> lic_url | lic_token so decrypt with KEY, IV found in bundles.js
try:
decoded = decrypt_message(enc_token, KEY, IV)
except KeyRefreshNeeded:
# Refresh keys ONCE and retry decrypt
try:
os.remove(KEYCACHE)
pass
KEY, IV = fetch_fresh_keys(client)
# --- license url and token hidden; use KEY and IV to decrypt
lic_url, lic_token = decoded.split("|", 1)
# PSSH
pssh_b64 = generate_pssh(transcodeId=asset_id)
# --- Widevine essentials start ---
# --- uses a certificate to authorise cdm key exchange ---
# --- first negotialte certificate then get the license ---
device = Device.load(WVD_PATH)
cdm = Cdm.from_device(device)
session_id = cdm.open()
try:
# 1) Service certificate (first POST, message = 'CAQ=' (found using httptoolkit and watching json exchanges))
service_cert_b64 = fetch_service_certificate(client, lic_url, asset_id, lic_token, uri)
# 2) Set the service certificate
cdm.set_service_certificate(session_id, service_cert_b64)
# 3) Build challenge
challenge = cdm.get_license_challenge(session_id, PSSH(pssh_b64), privacy_mode=True)
# 4) Request license (second POST with message=base64(challenge))
license_blob = request_license(client, lic_url, asset_id, lic_token, uri, challenge)
# 5) Parse license and dump keys
cdm.parse_license(session_id, license_blob)
key = None
for k in cdm.get_keys(session_id):
if k.type == "CONTENT":
key = f"{k.kid.hex}:{k.key.hex()}"
if not key:
raise RuntimeError("No CONTENT keys in license response")
finally:
cdm.close(session_id)
# --- Widevine essentials end ---
# --- Have Key, mpd now need
# --- collect data for video download ---
title = my_data["brandTitle"].replace(':','') # ; upsets N_m3u8
websafe_title = my_data['webSafeBrandTitle'] # for url constuction
episode = my_data["episodeTitle"]
subtitle = my_data["subtitlesAssets"][1]["url"]
# -- get series and episode numbers
vid_url = f"https://www.channel4.com/programmes/{websafe_title}/on-demand/{progId}"
try:
vid_cont = client.get(vid_url).text
raise RuntimeError(f"fetch episode/series data failed: {e}")
regex = re.findall(r"name=\"title\" content=\"(.*?)\W{1,3}On\WDemand", vid_cont)
# --- If we have episode data
try:
_, sernum, _, epnum = regex[0].split(' ')
epnum = pad_number(epnum)
sernum = pad_number(sernum)
episode_id = (f"S{sernum}E{epnum}")
except:
epnum = ''
sernum = ''
episode_id = ''
if episode in title:
episode = '' # avoid repetitive strings in programme title build
# --- store subtitle file 'w' in file open will mean
# over-write of existng contents - easy re-use
my_title = Title(title, episode, subtitle, key, episode_id)
subs = client.get(my_title.subtitle).text
try:
with open("./tmp/subtitles.srt", 'w') as f:
f.write(subs)
f.close()
subs = None
except Exception:
subs = None
# N_m3u8DL-RE to do download
command = ([
n_m3u8dl,
uri,
#'--auto-select',
'-sa',
'all',
'-sv',
'best',
'-ds',
'id="0"',
'--save-name',
f"{my_title.title} {my_title.episode} {my_title.episode_id}",
'--save-dir',
f'{DOWNLOAD_DIR}/C4/{my_title.title}/',
'--tmp-dir',
"./tmp",
'--no-log',
'--key',
my_title.key,
'-mt',
'-M',
'format=mkv:muxer=mkvmerge',
if subs:
command.append("--mux-import:path=./tmp/subtitles.srt:lang=en:name='English'")
# bastard nilaoda!! Command nothing like --help tells it!
subprocess.run(command)
if __name__=="__main__":
title = PF.figlet_format(' A L L 4 ', font='smslant')
print(title)
try:
main(sys.argv[1])
except:
main("")
Noob Starter Pack. Just download any Widevine media! Over 30,000 downloads for V6!.
Kanopy Downloader
By Anonymous8743244 in forum Video Streaming DownloadingReplies: 11Last Post: 26th May 2025, 20:02 -
Yet another Channel4 Downloader
By stabbedbybrick in forum Video Streaming DownloadingReplies: 52Last Post: 18th Sep 2023, 11:42 -
Zee5 downloader
By swappyison in forum Video Streaming DownloadingReplies: 4Last Post: 2nd Sep 2023, 08:10 -
need help improving my downloader
By swappyison in forum Video Streaming DownloadingReplies: 9Last Post: 27th Aug 2023, 04:46 -
Fast youtube video downloader
By techmot in forum Video Streaming DownloadingReplies: 3Last Post: 3rd Jan 2023, 16:40
