Hi all, Well I have the capture, conversion, & editing pretty much figured out...so now it is time to get a bigger drive. I purchased an 80gb 7200rpm WD w/8mb buffer. I want to use it exclusively for capture, editing, etc. However I already have a 40 gig as my master.
Will it hurt performance to install it as a slave?
Do transfer Virtualdub & TMPGE to the new drive?
Needs some help, thanks
Samcut
Make sure you install DMA drivers for your harddrives (e.g., Via4in1 drivers if you have a VIA Athlon motherboard). Having the DMA on will double your HD capture performance.
Keep the 40 gig (master) for your system files and for your encoding apps. Keep the 80 gig (slave) just for video files. RAID HD setups is unnecessary with current 7200 rpm UDMA harddrives.
It would also be a good idea to backup your system HD with Ghost.
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 11:06 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 15:58
