I often use Clever FFMpeg to convert to mkv or mp4. I'd also like to convert to mpg, but I'm having trouble. When I select mpg, I get an error message and a request to use a different container. Is there a way to convert to mpg anyway?
When multiplexing or recoding?
If it happens during multiplexing, the problem is in the message.
One or more codecs (video, audio, subtitles) are not compatible with the mpg container.
If you still need mpg, you must recode the corresponding stream with a compatible format.
Post a mediainfo report (text mode) of your video here and I'll tell you which stream(s) to change. -
Your video is
videostream: avc (h264)
audiostream: aac
subtitle: text
The mpg container supports:
videostream: mpeg1, mpeg2
audiostream: mp2,mp3,ac3
subtitle: none.
For an mpg you must:
convert the videostream to mpeg2
convert the audiostream to ac3
mux both converted streams to mpg. -
I understand from your answer that it's better not to convert to MPG with Clever. I'll just keep converting to MP4 or MKV with Clever. Thanks for the information.
clever FFmpeg-GUI, small FFmpeg UI, fully portable, no installation.
By ProWo in forum Video ConversionReplies: 3194Last Post: 2nd Dec 2025, 17:00 -
Custom Command in Clever FFmpeg GUI
By sam12345 in forum Video ConversionReplies: 21Last Post: 22nd Oct 2025, 12:39 -
Clever FFmpeg GUI Batch Mux
By Tom Saurus in forum Video ConversionReplies: 16Last Post: 29th Jun 2025, 09:49 -
Clever FFmpeg GUI doesn't work
By BenBen21 in forum EditingReplies: 29Last Post: 30th Jan 2025, 04:46 -
clever FFmpeg-GUI Error When Input Video Encoded With VP09?
By meeshu in forum EditingReplies: 16Last Post: 18th Mar 2024, 08:14
