I have a few video files that when playing in VLC have multiple audio and subtitle tracks, but when I go to select them do not show any description. So when I click on Audio/Audio Track it lists "Track 1" then "Track 2" etc. Same with Subtitle/Subtrack. Is there a way to add a description to them? Most of my files at least say "Stereo" or a language or "Comentary by....". Thx!
Thx. I downloaded it but don't see a way to do it with the GUI. I'll do some further research.
This shows how to use metadata for MP4 videos.
https://superuser.com/questions/1208273/how-to-add-new-and-non-defined-metadata-to-an-...208277#1208277
From there there is a link on using metadata tags in MKV videos.
https://superuser.com/questions/1102265/how-to-save-custom-data-into-header-in-movie-f...102278#1102278
Some testing should give what you want. -
Use the multiplex button.
Here you can add/change language tags and titles for the single streams.
[Attachment 89197 - Click to enlarge] -
These days most people use *.mkv files for storing multiple audio tracks in a video. MKVToolNix GUI is a quick and simple tool for renaming tracks, and it also supports MKV flags.
Tracks may be flagged as “visual impaired” (example: audio descriptions for the blind), “hearing impaired” (example: closed captions), “commentary” (director’s or cast), “forced” (translation subtitles), etc. -
Thx, I'll check it out. In the meantime someone suggested using MkvToolNix, which looks like it fits the bill!
MPC-HC x64 wrongfully does not show any audio track to choose on mkv file
By SendHelp in forum Software PlayingReplies: 9Last Post: 12th Feb 2025, 17:28 -
MP4 with Dolby Vision in a separate track -> MKV with a single video track
By bond_007 in forum Video ConversionReplies: 3Last Post: 13th Oct 2023, 04:11 -
Convert mp4 to mkv with track names intact
By magnu in forum Video ConversionReplies: 1Last Post: 31st May 2023, 12:17 -
Audio track and subtitle track in DVD Styler
By JPM44 in forum Authoring (DVD)Replies: 3Last Post: 12th Nov 2022, 12:20 -
ffmpeg losing subtitle track converting MP4 to MP4
By the_steve_randolph in forum Newbie / General discussionsReplies: 9Last Post: 31st May 2021, 17:42
