Hello, all. I'm. I have already inserted all the videos I want on the DVD I'm creating. I have all of the chapter icons as I want them. All I have left to do is select the short video file that I want to be playing for the background, but when I browse to the folder that video is in, it's not there to be selected.
In the upper left corner of the screen, there is a button that says "background". When I click it, a window opens that shows a list of the videos I have selected to be on my DVD. On top of this list is an option to "add/edit image." When I click on it, a browse my computer's files window opens. When I browse to the folder that has the video I want to use for my animated background, it is not there.
Can anyone tell me what I need to do to make my videos selectable? Thanks.
Just locate your folders manually and note exactly where they are located and then open the program go to where you located the folders.
Best bluray authoring software for menu creation
By mulliganman in forum Authoring (Blu-ray)Replies: 30Last Post: 21st Dec 2024, 12:55 -
Font Creation and Effects Help
By Hardback247 in forum SubtitleReplies: 2Last Post: 30th Mar 2024, 23:25 -
Best DVD menu creation software?
By JackyBorderCollie in forum Authoring (DVD)Replies: 9Last Post: 4th Jul 2023, 16:23 -
RAW video creation
By wissamms in forum Video ConversionReplies: 4Last Post: 4th Apr 2023, 17:50 -
Software DVD menu creation
By Donnje in forum Authoring (DVD)Replies: 5Last Post: 10th Dec 2022, 03:23
