  1. Hi guys
    I was given a USB 2.0 Vhs-to pc capture device it also has a DVD but my laptop does not have a DVD /CD as its been lost
    Does anyone know where i can download the correct software , the last DVD installation showed this on the sleeve
    Model DC60-008 , VERSION 4.0A win10 ,
    I think the manufacturer may be Easycap or Honestech
    My laptop is windows 10
    thankyou
  2. Software Download for your VHS-to-PC capture device:
    [Easycap DC60-008 USB video capture device]
    1. Recommended Download Sources:
    - Internet Archive has archived versions of the EasyCAP software for Windows 10
    - FileHorse.com offers EasyCAP drivers compatible with Windows 10
    2. Installation Recommendations:
    - Use Windows 7/8 drivers, as they are often compatible with Windows 10
    - Look for version 4.0A specifically, matching your device
  3. Thankyou so much it worked perfectly
  4. Capturing Memories dellsam34's Avatar
    Jan 2016
    If you want to capture lossless you can use vdub.
    Terrible advice.
    The newbie poster essentially said his finger hurt, and he wanted to cut it off. Insane.
    You told him where to get scissors.
