Hello everyone,
I'm trying to download a video from the Mariinsky TV website and I'm facing an issue with the stream resolution. I would appreciate any help you can provide.
Video URL:
Important Note: Access to the video is free, but it requires a quick user registration on the website.
The Problem:
The web player correctly offers a 1080p quality option, and I can watch the stream at that resolution without any problems.
However, when I inspect the network traffic to find the stream source, the manifest.mpd file I can locate only lists resolutions up to a maximum of 720p. Any download tool I've tried (like yt-dlp and others) consequently only downloads the 720p version, as it's the highest quality available in that manifest.
My question is: How can I access or find the 1080p stream? It's clearly available to the player, so I suspect there might be a different manifest file, or perhaps the player uses a different method to retrieve the higher quality stream.
Has anyone encountered a similar situation with this website or platform? Any guidance on how to capture the full-resolution stream would be greatly appreciated.
Thank you in advance for your time and help!
Discord Sei#0555
Hi notaghost,
Thank you so much for the quick reply and for providing the link and the key!
I tried to use the link with m3u8DL-RE, but unfortunately, I'm getting a Response status code does not indicate success: 404 (Not Found) error. I noticed the URL contains a user ID (user92935), so I also tried replacing that with my own user ID, but I still got the same 404 error. I might be missing a step, perhaps some required headers or cookies.
On that note, I have a follow-up question, if you don't mind. The URL you shared contains "playready" in it, which leads me to believe this is a PlayReady protected stream. This would explain why the Widevine-specific scripts I was using (like vineless and widevineproxy2) didn't detect anything.
Could you please confirm if this is indeed PlayReady DRM? Also, I'm very curious about your method. How were you able to find that specific .mpd link? Knowing the process might help me figure out why I'm getting the 404 error.
Any insight you could share would be greatly appreciated, as I'm trying to learn.
Thanks again for your help!Discord Sei#0555 -
Unless I'm missing something it doesn't look like the web player options are labeled correctly. When I select 480 the 360 stream plays, same with 720 and the 480 stream plays, maybe 720 is the highest available.
Thanks for chiming in and sharing your observation. That's a very plausible theory, and I had considered that possibility as well, that the player's quality labels might simply be incorrect.
However, from my own testing, I can perceive a distinct change in quality when switching back and forth between the 720p and 1080p options in the player. The image becomes noticeably sharper when 1080p is selected and softer when going back down to 720p.
This leads me to believe that a true 1080p stream is indeed being delivered. It reinforces my suspicion that the issue isn't mislabeled options, but rather that the 1080p stream is protected differently and requires a separate manifest that isn't easily found—likely the PlayReady one that notaghost pointed out earlier.Discord Sei#0555
Download encrypted video via DRM protected MPD manifest
By Beta2k in forum Video Streaming DownloadingReplies: 19Last Post: 15th Jan 2024, 11:47 -
How To Play / Download a DRM Live Stream Protected MPD Manifest On Linux
By Rebanjulu in forum Video Streaming DownloadingReplies: 5Last Post: 2nd Nov 2022, 12:52 -
Download MPD in 1080p not in 720p
By Alkatraz in forum Video Streaming DownloadingReplies: 2Last Post: 28th Sep 2022, 06:00 -
how to download video files with "mpd" (mpeg dash manifest)?
By nzhd in forum Video Streaming DownloadingReplies: 59Last Post: 17th Apr 2021, 06:26 -
help to download videos DRM or with "mpd" (mpeg dash manifest)?
By Marven in forum ProgrammingReplies: 4Last Post: 17th Apr 2021, 06:24
