Hi, I'm trying to extract hardcoded subtitles with VideOCR but the operation is extremely slow even though I have GPU usage enabled. The GPU is working at almost 0%... Can anyone tell me why?
I installed the “VideOCR-GPU-v1.3.2-CUDA-12.9-setup-x64.exe” version since it is recommended for Nvidia 16 - 50 Series cards and I have an Nvidia RTX 2070 Super GPU.
I also get the error: Error: PaddleOCR failed. See the log file for technical details
The log says:
[2025-10-07 11:43:30] PaddleOCR process failed with exit code 3221225794.
Command: C:\PROGRA~1\VideOCR\videocr-cli-GPU-v1.3.2-CUDA-12.9\PaddleOCR-GPU-v1.3.2-CUDA-12.9\paddleocr.exe ocr --input C:\Users\frenk\AppData\Local\Temp\videocr_temp_afh o7ewe --device gpu --use_textline_orientation false --use_doc_orientation_classify False --use_doc_unwarping False --lang it --text_detection_model_dir C:\PROGRA~1\VideOCR\videocr-cli-GPU-v1.3.2-CUDA-12.9\PaddleOCR.PP-OCRv5.support.files\det\PP-OCRv5_mobile_det --text_detection_model_name PP-OCRv5_mobile_det --text_recognition_model_dir C:\PROGRA~1\VideOCR\videocr-cli-GPU-v1.3.2-CUDA-12.9\PaddleOCR.PP-OCRv5.support.files\rec\latin_PP-OCRv5_mobile_rec --text_recognition_model_name latin_PP-OCRv5_mobile_rec
--- STDOUT ---
--- STDERR ---
From experience hard coded subtitles are very hard to extract
Sorry I am not familiar with VideOCR nor would I try it.
You can save time if you try to transcribe the audio from the video (assuming it has an audio stream) using Whisper AI
Or you can try to follow this YouTube video.
https://www.youtube.com/watch?v=bgg3otPw810 -
I spoke directly with the program's creator - here - who explained to me that the first phase is very slow and that the GPU succeeds in a second phase, which I was unable to reach due to the error. He advised me to run the program as an administrator, and the error disappeared. The subtitles produced are almost perfect.
Great program.
Is there a way to remove hardcoded subtitles without cropping?
By Shaorin in forum Newbie / General discussionsReplies: 8Last Post: 27th Jul 2025, 02:36 -
Subtitle Edit slow when skiping through video/subtitles
By azdaja2005 in forum SubtitleReplies: 6Last Post: 17th Oct 2023, 01:47 -
How Can I Translate Chinese Hardcoded Subtitles to English?
By may5224 in forum SubtitleReplies: 11Last Post: 4th May 2023, 01:52 -
Change vertical pozition hardcoded sub HELP!
By Mariox in forum SubtitleReplies: 13Last Post: 24th Feb 2023, 08:00 -
By Anonymous84 in forum EditingReplies: 1Last Post: 11th Nov 2020, 10:07
