I'm baffled by how the FPS setting works in the Settings screen of SE and how it is activated or saved.
Is it activated by the video FPS? No it seems constant in that. If it is reset to match a video FPS does it reload for that video? Unsure.
What I find in a long process of doing corrections and fine tuning a sub from Whisper is that it seems when I go back the following day, small increments in time stamp need adjustment. Am I imagining things?
The truth is I fail to check what the FPS is set at when doing one of these corrections over many sessions since I cannot do a lot all at once.
I'm only familiar with synchronization for time at the Synchronization tab .
This setting is in Options > Settings > General > Default Frame rate.
The source vid is 29.97 and I found that odd since Euro vids from 2005 were all 25 FPS.
Regardless, the one I have is 29.97.
I just wondered when/how the Default Frame rate can change when a new vid is loaded. -
As far as I can see if the frame rate is set to the actual video rate before the subs are loaded,
it may help some of the subtitle time adjustments to be slightly more accurate (milliseconds of accuracy)
It seems, as you mention, that if an actual video is loaded in the program it would use that instead of the default setting.
The default settings seems to be there for the use case where a video file is not loaded, but the subs only.
I never used it myself and I never had any issues -
Thanks Dave.
After watching an SRT load more closely I see that the FPS stays where I had it previously.
I matched both just in case. Yes there are small millisecond variations (at least from my looking at it) to get best possible sync with the video. I do all this manually line by line and add descriptive features where it seems to look good (Feet Stomping) (audience laughs) Adding the musical clef to indicate music or singing etc.
This does not help explaining what the function is for if it is independent of the video. To my mind it can only make something worse. Regardless they seem to be working on the program all the time.
Steps & Settings for use of Whisper in Subtitle Edit ?
By Seeker47 in forum SubtitleReplies: 45Last Post: 18th May 2024, 01:32 -
Subtitle edit - How to put 'A with a dash on top' in subtitle edit?
By SSEN in forum SubtitleReplies: 5Last Post: 21st Sep 2023, 21:57 -
Subtitle Edit : Capitalize Subtitle to Normal Subtitle incomplete
By kalemvar1 in forum SubtitleReplies: 6Last Post: 5th Aug 2023, 13:28 -
Subtitle Edit - Shortcut to set a subtitle minimum gap
By tren in forum SubtitleReplies: 2Last Post: 1st Aug 2023, 07:44 -
Subtitle Edit fine tuning General Settings
By loninappleton in forum SubtitleReplies: 22Last Post: 4th May 2023, 01:26
