Hi please can help a cat?
I try
Code:ffmpeg.exe -threads 12 -y -i input.avi -c:v copy -an out.mxf
but
why the error "Drop frame is only allowed with multiples of 30000/1001 FPS" ?Code:ffmpeg version 8.0-full_build-www.gyan.dev Copyright (c) 2000-2025 the FFmpeg developers built with gcc 15.2.0 (Rev8, Built by MSYS2 project) configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-lcms2 --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-libdvdnav --enable-libdvdread --enable-sdl2 --enable-libaribb24 --enable-libaribcaption --enable-libdav1d --enable-libdavs2 --enable-libopenjpeg --enable-libquirc --enable-libuavs3d --enable-libxevd --enable-libzvbi --enable-liboapv --enable-libqrencode --enable-librav1e --enable-libsvtav1 --enable-libvvenc --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxeve --enable-libxvid --enable-libaom --enable-libjxl --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-libharfbuzz --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-dxva2 --enable-d3d11va --enable-d3d12va --enable-ffnvcodec --enable-libvpl --enable-nvdec --enable-nvenc --enable-vaapi --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-openal --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libcodec2 --enable-libilbc --enable-libgsm --enable-liblc3 --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint --enable-whisper libavutil 60. 8.100 / 60. 8.100 libavcodec 62. 11.100 / 62. 11.100 libavformat 62. 3.100 / 62. 3.100 libavdevice 62. 1.100 / 62. 1.100 libavfilter 11. 4.100 / 11. 4.100 libswscale 9. 1.100 / 9. 1.100 libswresample 6. 1.100 / 6. 1.100 Input #0, avi, from 'input.avi': Metadata: timecode : 21:57:57;01 Duration: 00:00:39.20, start: 0.000000, bitrate: 12300 kb/s Stream #0:0: Video: h264 (High 4:2:2) (h264 / 0x34363268), yuv422p(tv, bt709, progressive), 1920x1080 [SAR 1:1 DAR 16:9], 12295 kb/s, 50 fps, 50 tbr, 50 tbn Stream mapping: Stream #0:0 -> #0:0 (copy) [mxf @ 0000024abf27ec40] Drop frame is only allowed with multiples of 30000/1001 FPS [out#0/mxf @ 0000024abeca6e40] Could not write header (incorrect codec parameters ?): Invalid argument Conversion failed!![]()
I assume ffmpeg is copying the timecodes along with the video and it's not happy because the frame rate is 50fps, but I'm kinda guessing.Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
[Attachment 89069 - Click to enlarge]
oh
virtualdub make me a sort of "timecode" in avi but evidently the world doesn't want me to use it
Code:echo VirtualDub.audio.filters.Clear^(^);>>"%cd%\temp10bit.vcf" if NOT "%TimeCode%"=="" echo VirtualDub.project.ClearTextInfo^(^);>>"%cd%\temp10bit.vcf" if NOT "%TimeCode%"=="" echo VirtualDub.project.AddTextInfo^("ISMP", "%TIMECODE%"^);>>"%cd%\temp10bit.vcf"
devtools not allowed
By Zabon in forum Video Streaming DownloadingReplies: 4Last Post: 27th Oct 2023, 01:53 -
Download an episode from 1001.tv
By Semohan in forum Video Streaming DownloadingReplies: 3Last Post: 27th Mar 2023, 04:44 -
405 method not allowed
By inklara in forum Video Streaming DownloadingReplies: 2Last Post: 24th Nov 2022, 02:20 -
Please help: Frame Drop in Video
By Jesse1827 in forum Newbie / General discussionsReplies: 3Last Post: 24th May 2021, 08:18 -
Create a drop shadow as well as a transparent drop shadow?
By Bass_Soul in forum SubtitleReplies: 0Last Post: 26th Nov 2020, 00:28
