Results 1 to 14 of 14
  1. Hello,
    I have a 60 fps source video in which some sections appear to be with duplicate frames.
    I am using the following command to "cleanup" the parts with duplicate frames and to keep audio in sync:
    ffmpeg -i input.mp4 -vf mpdecimate -vsync vfr out.mp4
    When I run resulting video, the player will speed up at the section where duplicate frames where removed.
    What am I doing wrong ?
    Thank you.
  2. Probably nothing, mpdecimate is a video only filter, it does not touch the audio at all.
    There are projects like https://github.com/KenjiTakahashi/mpdecimate_trim which try to keep the audio sync, but afaik. there is no option for this directly in ffmpeg.
    Cu Selur
  3. Maybe your player doesn't handle variable frame rate properly?
  4. Originally Posted by jagabo View Post
    I am using Media Player Classic or VLC. Same thing happens with both - video starts playing faster at the point where duplicate frames were removed.
    Aug 2018
    Wrocław
    Originally Posted by marius2du View Post
    Hello,
    Thank you.
    Can you send the link? (privately possible)
    I want to test my VFR to CFR conversion script with duplicate frame removal.
  6. @rgr Please check your inbox. I have sent you both, the source file and the resulting file with duplicate frames being removed.
  7. That ffmpeg command line produces a variable frame rate video. It shouldn't play any smoother than the original because the timecodes play the remaining frames at exactly the same time as in the original file. So for example, one second worth of totally black frames might be reduced to a single black frame. But that single black frame will be displayed for one second, just like in the original video.
    Some players (especially editors) can't handle VFR properly and will play the video at the average frame rate of the final video. That one black frame will be displayed for the same duration as all the other frames. That is probably what you're seeing.
    Aug 2018
    Wrocław
    This is a CFR file, not a VFR file.
    This is probably not the original file; someone has already converted it.
    Part of the clip is 60fps, part is 30fps with duplicate frames.
    Nevertheless, I'll try converting it and let you know.
    By removing duplicate frames, you've sped up the video because there are now fewer of them. The video is artificially sped up at these points and therefore finishes sooner than the audio.
    Aug 2018
    Wrocław
    Check inbox. Duplicate frames were interpolated from adjacent ones.
    Aug 2018
    Wrocław
    Well, something didn't work because CFR came out.
    Video
    Format : AVC
    Format profile : High@L4.2
    Format settings : CABAC / 4 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference fra : 4 frames
    Codec ID : avc1
    Duration : 9 s 944 ms
    Bit rate : 6 455 kb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 59.940 (60000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.052
    Stream size : 7.65 MiB (97%)
    Writing library : x264 core 144 r2525 40bb568
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Codec configuration box : avcC
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Duration : 12 s 791 ms
    Duration_LastFrame : -9 ms
    Bit rate mode : Constant
    Bit rate : 128 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 200 KiB (2%)
    Default : Yes
    Alternate group : 1
    Edit:
    But out of curiosity I checked it with ffmpeg8 and it turned out OK. Of course, this doesn't actually improve anything.
    Duration : 12 s 730 ms
    Source duration : 12 s 763 ms
    Frame rate mode : Variable
  11. Originally Posted by rgr View Post
    I think you left out the "-vsync vfr" on the ffmpeg command line. Without it, I believe mpdecimate outputs VFR but ffmpeg converts it back to CFR by adding back duplicate frames.
    Aug 2018
    Wrocław
    I evaluated the output file provided by the author. My attempt is in the post above (Edit section).
  13. Originally Posted by rgr View Post
    Video
    Format : AVC
    Codec ID : avc1
    Color space : YUV
    Bit depth : 8 bits
    Audio
    Format : AAC LC
    Bit rate : 128 kb/s
    Default : Yes
    Alternate group : 1
    Edit:
    Interestingly, MediaInfo reports for me VFR. See below:
    Video
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format settings, ReFrames        : 4 frames
    Codec ID                         : avc1
    Duration                         : 9s 943ms
    Bit rate mode                    : Variable
    Bit rate                         : 6 455 Kbps
    Display aspect ratio             : 16/9
    Frame rate                       : 59.940 fps
    Resolution                       : 24 bits
    Colorimetry                      : 4:2:0
    Audio
    Format                           : AAC
    Format version                   : Version 4
    Format profile                   : LC
    Format settings, SBR             : No
    Codec ID                         : 40
    Duration                         : 12s 790ms
    Bit rate                         : 128 Kbps
    Channel positions                : L R
    Sampling rate                    : 48.0 KHz
    Resolution                       : 16 bits
  14. Originally Posted by marius2du View Post
    Video
    Format                           : AVC
    Codec ID                         : avc1
    Duration                         : 9s 943ms
    Colorimetry                      : 4:2:0
    Audio
    Format                           : AAC
    Format profile                   : LC
    Codec ID                         : 40
    Bit rate                         : 128 Kbps
    That's a different matter. MP4 uses two integers to represent the frame rate, a numerator and a denominator. Often the denominator is 90,000. 59.94 (60000/1001) fps can't be represented exactly using that denominator -- it would require timestamps that are a multiple of 1501.5/90000. So even though the source is a constant frame rate of 60000/1001 the time codes are variable, alternating between 1501/90000 and 1502/90000 seconds, giving an average of 1501.5/90000.
