Results 1 to 22 of 22
    Sep 2014
    Rome
    Hi
    i have to backup some of my dvds , i bought them so i can have 1 copy
    i have used DVD Decrypter and DVD Shrink to rip and mostly DVD Shrink to shink and burn on dvd
    but now dvd shrink doesn' t work on windows 11 , it does not open iso file , and it does give me lots of errors
    what can i use to rip (remove protections) and burn my original dvd on a new one?
    thanks
    Feb 2006
    Originally Posted by rama View Post
    Hi
    thanks
    give makeMKV a try
    Jul 2008
    Old Dominion
    If you just want to BackUp the DVDs try Xreveal to decrypt the DVD on the fly and ImgBurn to Read them to ISO on your PC.
    May 2005
    Australia-PAL Land
    MakeMKV.
    To create an ISO, a direct copy of the whole disk: open MakeMKV-Click Backup icon (or File>Backup…).
    To extract the main movie only (similar to DVDShrink):
    Use the Open Disc mode to analyse the video files on the disk and choose which ones you want to save to MKV.
    -Insert your DVD
    -File>Open Disc…
    -Deselect all the titles you don’t want converted ie blue-tick only the movie you want to keep.
    -Set the Output folder.
    -Click MakeMKV
    MakeMKV will extract your selected movies into MKV files.
    Sep 2014
    Rome
    MakeMKV.
    -Insert your DVD
    -File>Open Disc…
    -Click MakeMKV
    hi
    i want to shrink to burn on a dvd5 (4.7GB) , makeMKV doesn't do , i guess it can rip blue ray and dvd removing protection to create a personal copy
    dvdshrink could compress the movie just to fit on dvd single layer
    thanks
    Sep 2014
    Rome
    hi
    Xreveal doesn't shrink any video to store on a 4.7 gb
    but is free or not by the way?
    thanks
  7. MakeMKV or XReveal will rip an .ISO which will be the full size DVD.
    XReveal can also rip to DVD compliant folders still full size.
    You have to use one of these to decrypt a commercial DVD.
    You need to read the setup instructions for both.
    As they require some additional files to work.
    Once you get it ripped to your hard drive full size you need to compress it to DVD5 size.
    I do not know if DVD Rebuilder works with Windows 11 but give it a try.
    It can compress to DVD5 size.
    Like many softwares XReveal has a free & paid version.
    I thought of another software AVStoDVD can also compress to DVD5.
    It also has to have the DVD decrypted first.
    May 2005
    Australia-PAL Land
    @manono, AFAIK, IMGBurn will not shrink a DVD-9 to fit on a DVD-5. It is simply a burner.
  9. Alwyn is correct.
    I'm 100% sure ImgBurn does not compress DVD files.
    Or any other type file.
    I would say it is more than a simple burner because of other things it can do.
    Jul 2008
    Old Dominion
    @rama I am running Windows 11 Pro. I installed DVDShrink 3.2 and ran a test using Xreveal (paid/registered version) and DVDShrink. My test DVD was a rather old series of The Outer Limits 1995 (YMMV with newer DVDs and the free verssion of Xreveal). With Xreveal running, DVDShrink recognized the DVD as "Not Encrypted" and successfully shrank it from DVD9 to DVD5 without any errors and created an ISO for me.
    Sep 2014
    Rome
    hi
    dvdshrink doesn't even analize a dvd , it does give me only errors
    may i know whay Xreveal (paid/registered version) can do more than the free version?
    just because i can find any information about the pro version
    thanks
  12. Originally Posted by Alwyn View Post
    That's right. But here's what he asked:
    He is already using DVD Decrypter to decrypt the files to the hard drive. He can use ImgBurn to burn to DVD. Those are the answers to his two questions.
    As for shrinking to DVD-5 size, several good options were already suggested. Me, I'd use an AviSynth script opened in HC Encoder. Failing that, I'd suggest Avs2DVD, which also uses an AviSynth script, QuEnc for the encoding and ImgBurn at the end. Here's Baldrick's guide for the job:
    https://forum.videohelp.com/threads/353284-AVStoDVD-beginners-guide-Any-video-to-DVD-Video
    May 2005
    Australia-PAL Land
    @manono, post #5 and #6 clearly indicate they want to shrink. Hence my comment to you.
  14. Originally Posted by Alwyn View Post
    Yes, you're right. He also says he used to use DVDShrink, while I think it's a piece of junk suitable only for those that don't know anything and don't want to learn anything.
    If he wants to do it the easiest way and get good results at the same time, the I'd still recommend Avs2DVD.
  15. @ manono,
    I saw Baldrick used Quenc in his guide but acording to MrC the author it is no longer used & the quote is from 2013.
    Originally Posted by _MrC_ View Post
    QuEnc is no longer used in the latest AVStoDVD release, fully replaced by FFmpeg.
    I would like a short guide on doing this.
    I have done some additional reading on doing this but any imput would be appreciated.
    DVD Decrypter may or may not decrypt a commercial DVD depending on how modern the encryption on the DVD is.
    Although I would also use ImgBurn DVD Decrypter can also Write to a DVD.
    DVD Rebuilder even the free version allows more settings in HCEnc than AVStoDVD.
    You need to modify both the rebuilder.ini & HC.ini in the Program Files folder for DVD Rebuilder.
    I have been told this is made easier in the paid verson but I do not have it.
    I like DVDShrink but I have other paid software I also use.
    I've found if DVDShrink rejects a DVD when used with a decrypter.
    It is a good indication there is a problem with that DVD.
  16. Originally Posted by rama View Post
    but now dvd shrink doesn' t work on windows 11 , it does not open iso file...
    Dvdshrink works fine on Windows11.
    For the iso file, mount it first (doubleclick it, a new drive letter will be assigned to it).
    In Dvdshrink, open file, locate the main ifo in the new drive letter.
  17. Originally Posted by cholla View Post
    @ manono,
    I've never used it, and am only familiar with its ease of use and the fact it's supposed to be useful for the inexperienced. The encoder name I got from the guide. If it's no longer used, then fine.
    There's nothing difficult about using HCEnc. Make a DVD compliant script, open it in HCEnc, set a few parameters and let it do its thing. Afterwards (if NTSC) run it through DGPulldown to set the pulldown. Then author it with whatever you might use (Muxman, if you don't need menus). Here's a decent guide:
    https://forum.videohelp.com/threads/273620-How-to-encode-an-Avi-to-dvd-ready-video-and...-Aften#1734488
    About the only part I find useful is the bottom HcEnc screen. Test the script first in VDub to make sure it works and is complaint (framerate, resolution)
  18. Originally Posted by rama View Post
    Hi
    thanks
    Strange! I just used DVD Shrink successfully on Windows 11 yesterday.
    Aug 2003
    This is my specs and I use DVD Shrink, ImgBurn, and DVD Decrypter alot. These are older programs but still come in useful.
    Edition Windows 11 Home
    Version 25H2
    Installed on ‎8/‎28/‎2025
    OS build 26200.7462
    Experience Windows Feature Experience Pack 1000.26100.275.0 (don't know what this iis)
    Sep 2014
    Rome
    Hi
    thanks
    Version 25H2
    OS build 26200.7462
    Hi
    i can use dvd decrypter but dvd shrink , it gave me many errors
    "parameter not correct"
    can i know why?
    thanks
    Image Attached Images
    Jul 2008
    Old Dominion
    hi
    thanks
    At the time I got it there was a free and "pro" version. I paid for the lifetime license. The price has gone up.
