Hi all,
I have a single VHS-C tape and I don't even know what's on it - don't really want to spend 30 quid on an adaptor, or indeed pay a conversion company to digitise it.
Can I take the spool out and put it in a full size VHS cassette?
I've taken many VHS tapes apart over the years, and I'd have no issue with the mechanics of it.
Question is - are the spools inter-changeable, or does the tape lie/positioned differently in a VHS-C tape?
Another option would be to manually transfer it onto a normal VHS spool bobbin, but I'm aware I could damage the tape doing that, and also of course even though it's only a 30 min tape, I'd imagine there's still a fair amount of tape there....
Thanks!
Results 1 to 9 of 9
Why would transfer into a full spool cause damage?
There's no different risk than re-shelling full-sized VHS tape.Want my help? Ask here! (not via PM!)
Yes, you can swap VHS-C into a regular VHS shell presuming you splice it on to the the full size hub that is on the other side of the tape, would just make sure you keep a clear tape leader in place on both ends of the tape. My understanding is that the regular size hub can be used from the VHSC tape without any modification within the full tape.
Thanks both; I moved the VHS-C spool into a normal VHS cassette, and the VHS player attempts to play it but I can't seem to get a picture....nothing.
Is VHS-C recorded in some way differently (compared to VHS) that would mean it won't play?
My thinking was that it should surely play from a normal VHS cassette given that the adaptor means the tape would be offered up for reading in the same way as a normal VHS cassette - but it doesn't seem to work at all..... -
Could the VHS-C be a blank tape ?
If it was never recorded on then nothing will play. -
I don't think so; it was in a broken converter, I don't think it was blank.....could have been, though, I guess.
Make sure you did not flip the tape upside down or over, It has to be transferred as is to the bigger shell, The clear sides of the reels are facing up and the white sides facing down for both cassettes.
Absolutely, that's what I did. To be honest it would hard not to do that, as the spools wouldn't fit in, if it was upside down.
Well, then the tape is blank or it has been erased.
Deinterlacing 25fps PAL VHS Capture - dropped frames and field order swap?
By jbl_prof in forum Video ConversionReplies: 8Last Post: 24th Aug 2024, 14:03 -
JVC HR-S7600AM S-VHS VS. HM-DH5U D-VHS Capturing a VHS Tape
By dellsam34 in forum Capturing and VCRReplies: 26Last Post: 25th Aug 2023, 10:18 -
is it normal that DVD CIF is really sharper than VHS??
By anonymoustly in forum MediaReplies: 44Last Post: 12th Jun 2023, 17:05 -
"Error opening mask file!.....[not] correct spool dir"
By Georgey in forum Newbie / General discussionsReplies: 6Last Post: 31st Dec 2022, 09:54 -
vhs tape will NOT move through vhs recorder at all
By tepeco in forum RestorationReplies: 52Last Post: 24th Oct 2022, 12:31
