  1. Member Seeker47's Avatar
    Jul 2005
    Got a reasonable overview on this from a Google AI query, but one not really resolving anything about this for me. In practical, real-world usage -- mainly playback of video files, across a range of devices -- I don't really notice any significant differences between these two. Kind of flip a coin, or whichever happened to be available. Am I wrong about that ? Might make some difference if you were creating / encoding the file to begin with, having some particular end use result in mind ?
    When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form.
  2. Kawaiiii
    May 2021
    Italy
    X.264 is not a codec but an open source library (used by almost every open source application) to encode in the h.264 format.
    (i don't know why so much people rely on that AI crap to have any type of answer when it's still so easy to find much more useful information with search engines.. this is the first link if you do a search with <whatever> https://en.wikipedia.org/wiki/X264)
    Mar 2008
    This is what shows up in DuckDuckgo. Sometimes it will open its "search assist" automatically,
    seems like it depends on the phrasing of your search argument
  4. Kawaiiii
    May 2021
    Italy
    Yes, since I also use DuckDuckgo.
    (anyway.. both better first results that asking to the AI crap )
    Aug 2013
    Central Germany
    ITU-T H.264 (capital H, dot) is a standard for video compression. The theory about it, written in a document.
    And x264 (lower-case x, no dot) is one of many different software implementations of this standard. A practical use of the theory.
