Hello everyone, as the title suggests, I am attending a master's degree course and would like to download all the video lessons that are published weekly. It is a website created specifically for the course and I use a personal login to access it. Through it, I can view the lessons.
I have tried to download the videos using simple software, but even though the file size is correct, the video opens but the screen is black. Could you help me remove the DMRs and follow the lessons? I would like to avoid recording the screen. Thank you very much
[It's "DRM", not "DMR"...]
Without you telling us the URL the answer can only be: look at the various sticky threads. Maybe the answer lies within https://forum.videohelp.com/threads/416316-%5BRelease%5D-WidevineProxy2-Extension-Bypa...s-Lic-wrapping
Good luck! -
Thank you very much for your reply.
I tried to follow the guide, but as soon as I load the file into the extension and press play, the message appears:
Error 2104 Device not supported.
Could this be due to the generic Widevine Device file I inserted? I haven't tried it with Android Studio yet.
Thanks again for your help -
yes if it's VdoCipher
https://forum.videohelp.com/threads/417268-Can-a-Real-Device-L3-CDM-Crack-VdoCipher-DR...Seeking-Advice
VdoCipher will show "Error 2104: Device not supported" when you try to use an "emulated" device.
Panasonic DVD recorder passthrough settings (DMR-ES10, DMR-ES15, DMR-ES25)
By Brad in forum Capturing and VCRReplies: 466Last Post: 22nd Aug 2025, 09:30 -
Comparison before the DMR ES10 and captured with the DMR ES10
By Joscraft_05 in forum Capturing and VCRReplies: 12Last Post: 28th Dec 2024, 20:11 -
online restream
By kabreski in forum Capturing and VCRReplies: 0Last Post: 15th Aug 2024, 09:19 -
Panasonic DMR-BCT74ENK - cannot copy XP recorded footage to external HDD
By guy24s in forum DVD & Blu-ray RecordersReplies: 14Last Post: 15th Jan 2024, 02:20 -
Stuttering Playback Issue with DMR-ES10 recorded DVDs
By autephex in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Apr 2022, 01:00
