I have recently been bitten by the capturing bug, SVCDs, VCDs, DVD, etc. A friend gave me a copy of a movie in SVCD and I was hooked. I would like to convert some recordings from TIVO to DVD. I would imagine that I need some type of capture card and a DVD burner. I'm ready to spend approximately $1000 for a burner and capture card. Could anybody recommend a good capture card that would suite my needs. I looked at the capture card section and am getting confused by their abilities and what I need.
Have a read here . I was bored so i did the seaching for you.
http://www.cdfreaks.com/news2.php3?ID=2065
http://tivo.lightn.org/
http://tivo.samba.org/
http://tivo.samba.org/index.cgi?req=all#1.12
Option 1.It sounds like an intresting project ... just add LINUX
$1000 - not enough ! if you want to do it right - Unless you have a nice RAID or SCSI drive setup that will sustain 30+Mb/sec for full screen (DVD spec) non compressed capture.
Option 2 Generic *.avi capture card - needs good hardrives
Option 3 Mpeg2 hardware encoder card - OK but hard to edit Mpeg2 with out loss.
Option 4.Get a canopus AVDC100 A/D converter and firewire card.
http://www.canopuscorp.com/ppt_advc100.htm
Although the most expensive option this one gives you the best all round value i think. i.e - you can back up any analog source and all you need is a harddrive that can sustain DV data rates - 3.7 Mb/sec - F all ! -
@Cymbrogi
Read here:
http://forum.vcdhelp.com/viewtopic.php?t=90469&highlight=capture+wintv+kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net
Capturing VHS - Advice appreciated
By sl74 in forum Capturing and VCRReplies: 5Last Post: 25th Jan 2012, 11:14 -
Capturing hardware advice
By johnestan in forum Capturing and VCRReplies: 0Last Post: 24th Sep 2011, 19:13 -
Need advice on best capturing solution
By vitalic in forum Capturing and VCRReplies: 22Last Post: 15th Feb 2011, 13:11 -
Your Solutions and Advice for Capturing
By SixFiftyThree in forum Capturing and VCRReplies: 2Last Post: 12th Feb 2011, 00:19 -
Need advice about capturing VHS
By jimlong in forum Capturing and VCRReplies: 5Last Post: 1st Jun 2008, 02:11
