Results 1 to 11 of 11
  1. I am trying to create video captures of vinyl rips with video coming from my phone and audio coming from Audicity line-in flac capture on my comp. I have successfully gotten the separate video and audio files to mux with mkvtoonix gui, but it flips the aspect ratio 90 counter clock. Is there an application that will direct stream mux the files without changing aspect ratio from portrait to landscape (9:16 to 16:9), preferably free? I tried Capcut for windows and it looks like it will do it correctly, but im not paying 12 bux a month for it.
    AMD Athlon TBird 1400mhz, Abit KT7A-Raid, 512mb Crucial Cas2 133 SDR, All-In-Wonder Radeon 32mb DDR AGP 4x, Plextor 12x4x32 SCSI, 40gig Maxtor ATA/100
  2. Video properties, set aspect ratio: Set here what you want, 16/9 or 9/16.
  3. Do you mean video properties in win file explorer or mkvtoolnix? There isnt a 9/16 aspect listed in there.
  4. Originally Posted by warbird View Post
    In mkvtoolnix. Write in 9/16 and mux the file.
  5. Maybe im using the wrong version because there isn't a way to write it in, only a drop down tab that has predefined aspects like 4/3, 16/9, 1.66, 1.8, 2.33.
  6. Use the empty option and write the value manually in the set aspect ratio field.
  7. try this:
    video-crop-app
    There is nothing wrong .. with my environment
  8. I wrote 9/16 into mkvtoolmux and it is upside down and stretched. Using crop
    Mov will take forever bc the files are 20gb
  9. I got it. Under video properties set roll rotation to +90
  10. Actually, all that did was make it play correctly in media player classic, but in everything else it still plays the same. Ill have to mess around with the settings more, or find another application to mux them
  11. Post a mediainfo report (text mode) from your phone video here.
