i read online that you could potentially force a lot of analog capture cards to capture more of the vertical picture with something like graphedit/graphstudionext. so like the blackmagic cards which capture 486 lines instead of 480. i have a gv-usb2, has anyone had any luck taking a crack at this?
There is not "more" of a vertical picture if you capture x486.
https://forum.videohelp.com/threads/405710-Why-does-NTSC-video-usually-get-captured-at...ion-of-720x480
dellsam34 did some experiment with its hardware and posted few samples some time ago (search the forum). -
Kinda depends on the type of tape you're capturing I think. The problem with 480 line captures is that you don't get to choose *which* 480 lines are captured. The very top line is a "half line" which is kind of annoying and usually something I'd either mask or not use, but on first generation tapes, it is often possible to get rid of the head switching noise altogether depending on the playback machine.
As far as being able to extend the capturable area, I'm not sure if that'd be possible without customizing the driver, or it could be something that is hardware locked.
GV-USB2 capture range
By theseeker2 in forum Capturing and VCRReplies: 35Last Post: 7th Mar 2025, 05:18 -
Generic AV TO USB2.0 capture device will not initialise.
By nikoisdumb in forum Capturing and VCRReplies: 2Last Post: 2nd Jan 2024, 01:28 -
Sony DCR-TRV 330E PAL not visible to computer nor video capture software
By Rahneshin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 7th May 2021, 11:30 -
By Rahneshin in forum Newbie / General discussionsReplies: 0Last Post: 6th May 2021, 10:52 -
GV-USB2 Capture Stick-What's In It?
By Alwyn in forum Capturing and VCRReplies: 39Last Post: 11th Apr 2021, 12:22
