Results 1 to 13 of 13
    Jan 2024
    georgia
    Windows PowerShell
    Copyright (C) Microsoft Corporation. All rights reserved.
    N_m3u8DL-RE : The term 'N_m3u8DL-RE' is not recognized as the name of a cmdlet, function, script file, or operable
    program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
    At line:1 char:1
    + N_m3u8DL-RE "https://a2fa1d10f52f404f8a0d045b8f7765d6.mediatailor.us- ...
    + CategoryInfo : ObjectNotFound: (N_m3u8DL-RE:String) [], CommandNotFoundException
    + FullyQualifiedErrorId : CommandNotFoundException
    PS C:\Users\User\Downloads> f^F
    Jan 2024
    georgia
    Originally Posted by LZAA View Post
    Use 'cmd'.
    it says
    'N_m3u8DL-RE' is not recognized as an internal or external command,
    operable program or batch file.
    C:\Windows\System32>f
    Jan 2024
    georgia
    Originally Posted by ddll2 View Post
    i guess am doing something wrong i downloaded new version of powershel i think something is not installed correctly, what shoul i do, i fallowed a video on youtube, thank you anyway
  4. 'cmd':
    "Path to N_m3u8DL-RE.exe" -h
    Jan 2024
    georgia
    if i wanna download videos from cmd what should i install?
  6. Originally Posted by pithon123 View Post
    You dont have to install anything. You have only to download the software.
    Jan 2024
    georgia
    can you tell me name of the software? please, i am struggling with this
  8. Originally Posted by pithon123 View Post
    https://www.videohelp.com/software/N-m3u8DL-RE
    go to this address..
    download the corresponding version
    move the exe file to folder of ur choice
    open cmd by typing in cmd in the address bar of tht folder after moving the exe file
    now try running the command
  9. 1️⃣ Download the Executable
    1. Visit the official GitHub releases: N_m3u8DL-RE Releases
    2. Grab the latest Windows binary (look for a file like N_m3u8DL-RE.exe or the zip that contains it).
    2️⃣ Place in C:\Tools
    1. Create the folder if needed:
      C:\Tools
    2. Copy
      N_m3u8DL-RE.exe
      directly into
      C:\Tools
      (final path should be
      C:\Tools\N_m3u8DL-RE.exe
    3️⃣ Add C:\Tools to PATH
    1. Press Win + S, search for environment variables, and open “Edit the system environment variables”.
    2. Click Environment Variables….
    3. Under System variables, select PathEditNew.
    4. Enter:
      C:\Tools
    5. Click OK to close all dialogs.
    4️⃣ Test It
    1. Open a new Command Prompt.
    2. Run:
      N_m3u8DL-RE --version
    3. Seeing a version number means everything is set up correctly.
    For any other tools needed, put it inside that folder
    Jan 2024
    georgia
    Hi, thanks for explain, i am not sure sure what i did but it says this
    Microsoft Windows [Version 10.0.26100.6584]
    (c) Microsoft Corporation. All rights reserved.
    C:\c tools N_m3u8DL-RE>N_m3u8DL-RE "https://vod-lf-oneapp2-prd.akamaized.net/prod/telemundo/dpR/Qxs/9000436645/1738692651165-C4EiH/cmaf/mpeg_cenc_2sec/master_cmaf.mpd?audio=all&subtitle=all&forcedNarra tive=true" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:143.0) Gecko/20100101 Firefox/143.0" -H "Accept: */*" -H "Referer: https://www.nbc.com/" -H "Origin: https://www.nbc.com" -H "Proxy-Authorization: Basic ZnJlZXVzZXIxOmZyZWV1c2VyMQ==" --key 6d43ecd990e844d89f8d5801cd49d472:3cd51d9801befe07a 71229274e8e6aaa --use-shaka-packager -M format=mkv
    11:01:57.579 INFO : N_m3u8DL-RE (Beta version) 20241203
    11:01:57.583 INFO : Loading URL: https://vod-lf-oneapp2-prd.akamaized.net/prod/telemundo/dpR/Qxs/9000436645/17386926511...Narrative=true
    11:01:57.918 WARN : Response status code does not indicate success: 403 (Forbidden). (1/10)
    11:01:59.431 INFO : Loading URL: https://vod-lf-oneapp2-prd.akamaized.net/prod/telemundo/dpR/Qxs/9000436645/17386926511...Narrative=true
    11:01:59.499 WARN : Response status code does not indicate success: 403 (Forbidden). (2/10)
    11:02:01.018 INFO : Loading URL: https://vod-lf-oneapp2-prd.akamaized.net/prod/telemundo/dpR/Qxs/9000436645/17386926511...Narrative=true
    11:02:01.056 WARN : Response status code does not indicate success: 403 (Forbidden). (3/10)
    11:02:02.572 INFO : Loading URL: https://vod-lf-oneapp2-prd.akamaized.net/prod/telemundo/dpR/Qxs/9000436645/17386926511...Narrative=true
    11:02:02.596 WARN : Response status code does not indicate success: 403 (Forbidden). (4/10)
    11:02:04.109 INFO : Loading URL: https://vod-lf-oneapp2-prd.akamaized.net/prod/telemundo/dpR/Qxs/9000436645/17386926511...Narrative=true
    11:02:04.140 WARN : Response status code does not indicate success: 403 (Forbidden). (5/10)
    11:02:05.647 INFO : Loading URL: https://vod-lf-oneapp2-prd.akamaized.net/prod/telemundo/dpR/Qxs/9000436645/17386926511...Narrative=true
    11:02:05.683 WARN : Response status code does not indicate success: 403 (Forbidden). (6/10)
    11:02:07.188 INFO : Loading URL: https://vod-lf-oneapp2-prd.akamaized.net/prod/telemundo/dpR/Qxs/9000436645/17386926511...Narrative=true
    11:02:07.212 WARN : Response status code does not indicate success: 403 (Forbidden). (7/10)
    11:02:08.715 INFO : Loading URL: https://vod-lf-oneapp2-prd.akamaized.net/prod/telemundo/dpR/Qxs/9000436645/17386926511...Narrative=true
    11:02:08.733 WARN : Response status code does not indicate success: 403 (Forbidden). (8/10)
    11:02:10.238 INFO : Loading URL: https://vod-lf-oneapp2-prd.akamaized.net/prod/telemundo/dpR/Qxs/9000436645/17386926511...Narrative=true
    11:02:10.260 WARN : Response status code does not indicate success: 403 (Forbidden). (9/10)
    11:02:11.763 INFO : Loading URL: https://vod-lf-oneapp2-prd.akamaized.net/prod/telemundo/dpR/Qxs/9000436645/17386926511...Narrative=true
    11:02:11.778 WARN : Response status code does not indicate success: 403 (Forbidden). (10/10)
    11:02:13.287 ERROR: Failed to execute action after 10 retries.
    C:\c tools N_m3u8DL-RE>11:02:05.647 INFO : Loading URL: https://vod-lf-oneapp2-prd.akamaized.net/prod/telemundo/dpR/Qxs/9000436645/17386926511...ue11:02:05.647 INFO : Loading URL: https://vod-lf-oneapp2-prd.akamaized.net/prod/telemundo/dpR/Qxs/9000436645/17386926511...Narrative=true
    The filename, directory name, or volume label syntax is incorrect.
    'subtitle' is not recognized as an internal or external command,
    'forcedNarrative' is not recognized as an internal or external command,
  11. Originally Posted by pithon123 View Post
    VPN server USA - works
