For many years now I have run several concurrent instances of DVBDream tuned into my Hauppauge Quad DVB-T tuner, TBS DVB-S quad, and two USB DVB-T dongles all without any issues.
That's 10 instances with all the tuners using the BDA interface at the same time - recording simultaneously without a problem.
Now, without any obvious changes (though probably a Windows update), in the past week or so (late Aug/early Sep '25), I cannot have more than one instance running via the BDA interface - all others have to now use the StreamReader interface.
General Hardware Fault!
Cannot Initialize DVB Hardware! ErrorCode:3
Application will work in Offline Mode
Please try StreamReader device interface (Go to main menu->Options->Device and select "StreamReader")
OK
Is anyone else experiencing this issue at all - possibly even have a fix?
(Frustratingly as well, StreamReader on DVBDream cannot access the third and fourth tuners of the TBS quad.)
Hello im having the same issue on a fresh install of windows 11, did you find a fix?
Unfortunately not. I was considering the option of a fresh Windows install, but your experience suggests it's not a solution. I did have a search to see what updates to Windows could potentially have caused this, but I'm no expert in such things. I would also imagine the number of people this affects is minimal.
issue with keys
By whs912km in forum Video Streaming DownloadingReplies: 4Last Post: 11th May 2024, 15:27 -
Playback Issue
By Cptjimkirk363 in forum RestorationReplies: 1Last Post: 26th May 2023, 15:01 -
Framerate issue
By Damiano in forum Newbie / General discussionsReplies: 2Last Post: 27th Jul 2022, 22:47 -
Bitchute issue
By danderson400 in forum Video Streaming DownloadingReplies: 1Last Post: 15th Jul 2022, 10:16 -
VirtualBox Issue
By Dani33 in forum ComputerReplies: 3Last Post: 29th Jun 2022, 13:40
