Hello everyone,
I would like to make the text under a (German) traffic sign legible. The video was recorded with a dashcam.
Resolution: 1920 x 1080
Data rate: 7700 kBit/s
Frame rate: 30 frames/sec
File extension original file: MOV
Are there any (free?) tools that can enlarge the video and decipher or sharpen the text under the traffic sign?
I am currently using Cyberlink Power Director and Aiseesoft Video Converter Ultimate – unfortunately without success so far.
I need the text recognition for a legal matter.
If anyone knows of a solution or can help, please get in touch (also via PM). It's for a good cause.
Thank you in advance for your help!
Martin
I've seen dozens of posts like this in various forums. 99% of the time the video contains nothing that can be enhanced, not even with modern tools.
Even AI cannot correctly recognize what's on the plate if it has absolutely nothing to go on.
You will need to post the video if you hope to get any help. If you can almost make out the letters, or can positively see one or two and just need help with the remaining letters and digits, then there might be some hope. Otherwise, forget it.
I always include this link when responding to these requests:
Let's Enhance
The problem is that you've seen dozens of these scenes and therefore believe this is possible. It is not (usually).Last edited by johnmeyer; 6th Sep 2025 at 11:49. Reason: type
Unless the sign is new, or it's some rural area , another approach is to use Google Street View
Subtitle Edit and sign text trajectory
By nobrand in forum SubtitleReplies: 12Last Post: 30th Mar 2025, 16:38 -
How to make text pop-in on screen ?
By satimis in forum Newbie / General discussionsReplies: 4Last Post: 27th Mar 2025, 20:33 -
VSDC Video Editor make scrollinbg text only appear in section of scene
By OldNick in forum Newbie / General discussionsReplies: 0Last Post: 3rd Oct 2022, 18:16 -
Does it exist some app or software to make animated text?
By Chemist116 in forum Newbie / General discussionsReplies: 9Last Post: 11th May 2022, 20:25 -
search Avisynth Expert to make Slideshow with template and Text over Image
By danilo in forum EditingReplies: 1Last Post: 7th Jun 2021, 12:34
