So I got a VCR recently and I tried to record something from my HDMI to AV converter onto a blank tape. The problem? When I play the tape back, it’s in monochrome.
Keep in mind, the converter WAS in color and it still played the other tapes that I had (and haven’t recorded anything on) just fine.
I tried using different tapes, different cords, I tried messing with the settings on both my laptop and the converter respectively, but it remained monochrome.
Anyone else ever have this issue and does anyone know how to fix this?
Results 1 to 9 of 9
The HDMI to AV cannot playback tapes, You need a AV to HDMI for playback, we need to know how are you hooking up you VCR and what format are you recording in?
Connect your laptop (using the HDMI>AV converter) up to the TV's AV In. That will confirm the output of your HDMI>AV converter.
It is a remote possibility that the laptop's putting out monochrome: you can test that by plugging the HDMI straight into the TV. -
I don't understand. How do you know? Are you monitoring the Video Out of the VCR on a monitor?It played in color not only when it was hooked up to the VCR
If you're getting colour from the Video Out of the VCR, then the recording system must be defective. -
Yes, I am.Are you monitoring the Video Out of the VCR on a monitor?
Here’s a video just so you know exactly what’s going on.
20250906_2025_09_06_16_07_01.mp4
[don’t ask why I made it adult swim themed I’m bored] -
It has something to do with those chinese junk A/V boxes, they usually work in non standard formats, this is why they are not recommended for capturing or even recording to VCRs.
Here is what I had to do to get a decent test rig for testing VCRs. -
Good video. As you say, you're getting colour out of the converter OK. I still think it's a problem with the recording function of the VCR.
To definitely discount a buggy converter, try recording a tape using a DVD player Video Out as input to the VCR.
Just a WAG, if the VCR has it, try changing the colour system from NTSC to PAL or vice versa.
Possibility to get monochrome picture (problem digitizing old Video8 casset
By haneu in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 29th May 2024, 19:44 -
play a reel to reel tape and record onto a dvd disc through dvd recorder
By barry25 in forum Capturing and VCRReplies: 13Last Post: 29th Oct 2023, 22:43 -
Record a tape cassette
By Subtitles in forum AudioReplies: 6Last Post: 21st Jun 2023, 03:41 -
how do you play a betamax tape and record onto a blank dvd disc
By barry25 in forum Capturing and VCRReplies: 2Last Post: 12th Jun 2023, 10:32 -
Here's something interesting about original monochrome analog video spec
By Videogamer555 in forum MediaReplies: 10Last Post: 26th Oct 2022, 16:36
