  1. Hi. I trying trim Interlaced 50 fps video without re-encode, but get output file only 25 fps. what i wrong?
    Original video:
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (isom/iso2/avc1/mp41)
    File size : 6.80 GiB
    Duration : 2 h 18 min
    Overall bit rate : 7 035 kb/s
    Frame rate : 50.000 FPS
    Writing application : Lavf62.1.102
    Video
    Format : AVC
    Format profile : High@L4
    Format settings : CABAC / 4 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference frames : 4 frames
    Codec ID : avc1
    Source duration : 2 h 18 min
    Bit rate : 6 556 kb/s
    Maximum bit rate : 6 833 kb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Active Format Description : Letterbox 16:9 image
    Frame rate mode : Constant
    Original frame rate : 25.000 FPS
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan type, store method : Separated fields
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.063
    Stream size : 6.34 GiB (93%)
    Source stream size : 6.60 GiB (97%)
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Codec configuration box : avcC
    After trim:
    Format : MPEG-4
    File size : 224 MiB
    Duration : 4 min 58 s
    Overall bit rate : 6 304 kb/s
    Frame rate : 25.000 FPS
    Writing application : VideoReDo (Lavf58.29.100)
    Video
    Format : AVC
    Format settings, GOP : M=4, N=28
    Codec ID : avc1
    Bit rate : 6 099 kb/s
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.118
    Stream size : 217 MiB (97%)
  2. It is likely 25 fps , because 50 fps interlaced (100 fields / second) does not exist as a standard .
    If something was 50 FPS, or 100 FPS, it would be progressive not interlaced
    You can verify this by looking at the frame count (debug => advanced mode in medianfo) and checking against the duration
