    Aug 2018
    Wrocław
    I have files in an MKV container with the following audio track:
    Format: AC-3
    Format/Info: Audio Coding 3
    Commercial name: Dolby Digital
    Codec ID: A_AC3
    Duration: 49 s 952 ms
    Bit rate mode: Constant
    Bit rate: 448 kb/s
    Channel(s): 6 channels
    Channel layout: L R C LFE Ls Rs
    Sampling rate: 48.0 kHz
    I convert them to MP4 (H264+AAC) using the AviSynth script (audio passthrough) and get the following audio:
    Format: AAC LC
    Format/Info: Advanced Audio Codec Low Complexity
    Codec ID: mp4a-40-2
    Source duration: 49 s 973 ms
    Source_Duration_LastFrame: -11 ms
    Bit rate: 192 kb/s
    Channel layout: L R C Cb Lb Rb
    Is this channel conversion correct? (L R C LFE Ls Rs -> L R C Cb Lb Rb)?
    When I try to open the output MP4 in VDub I get "FFMPEG: Unsupported channel layout".
  2. I believe VDub is telling you that the FFMPEG version you have does not understand the L R C Cb Lb Rb channel layout.
    This may be for any FFMPEG version but I'm not sure about this.
    The FFMPEG codecs need to have the code to understand this channel layout to work with it.
    Why not use FFMPEG command line?
    Or maybe Clever to do this conversion?
  3. I would use Clever instead of vdub ..
    and update FFmpeg to 8.x
    There is nothing wrong with my environment
    Aug 2018
    Wrocław
    Vdub is for testing. I open the source mkv in AviSynth.
