For a customer of mine, I've done DVD authoring in the past for him (DVD Lab) with no issues. But his new content is 1080p.
It's two simple videos, both put together from multiple pictures and videos in shotcut and exported in h264 29.97fps ac3 stereo
My first time using multiavchd, and after some hassle with avisynth I was able to successfully transcode the videos and end up with no errors (though they were in .h264/ac3 so I don't think transcoding was necessary, I ended up with the same disc error anyways so I decided to go ahead and do it). Also thumbnails were not working. I kind of wish multiavchd had an option for a text-only menu/chapters cause this guy doesn't want anything complex
After messing around with windows native burning, getting the error from both players saying the disc is unreadable and might not be finalized, I used CDburnerxp (haven't in years, but I can't find my old nero 9).
now the data is only about 2gb and are burned on DVD+RW's for testing (100% complete wipe, not quick), and one of his BD-R disks. Burned in UDF 2.6 (once in 2.5 just for testing), finalized disc and data checked. Same error
Two different samsung bd players, one from around 2018, and one newer (~2022?) but fairly cheap (BDP-BX370)-Both with up to date software.
I did look up the folder structure for blu rays and I am copying the right folders to the root of the disc.
Same error. Any idea?
TIA
Results 1 to 12 of 12
I have been using MultiAVCHD for almost 16 years. I have used a wide variety of different brands of Blu-Ray and DVD players. However, now my workflow has changed under Windows 11 due to something I probably have misconfigured or misinstalled in MultiAVCHD so I primarily use it for authoring. The assets I use are already converted to Blu-Ray complaint (x264 1920x1080, AC-3 audio and subtitles). Once the assets are added and configured for playback I let MultiAVCHD compile the Blu-Ray folder.
[Attachment 88468 - Click to enlarge]
I have always burned them to media with ImgBurn, whether it was DVD, AVCHD or Blu-ray, without any problems.
[Attachment 88469 - Click to enlarge]
[Attachment 88470 - Click to enlarge] -
Yeah that is what I do, the blu ray button
AVCHD isn't in the root right (I never put it there)? I actually don't have a burner on the compilation computer so I have to copy the AVCHD folder to a flash drive and copy it to my shop computer that has a burner.
have you ever issues using DVD+RW's (or even used them). Still even at that the BD-R should have played. All UDF 2.5/2.6
Yeah I had it in a BD compliant format but thought it needed to be transcoded anyways perhaps to fix this error, which didn't make any difference. -
Just to check myself I created a small compilation of 1 small file and burned it to a BD-RE successfully (2X is very slow). I found that if I didn't have "AVCHD" in the root then the disk would not play.
[Attachment 88484 - Click to enlarge]
In ImgBurn "Build" add the right panel "AVCHD" folder.
[Attachment 88485 - Click to enlarge]
This works for me. -
I used 2.6 all the time and it played on blu-ray players that were 14 years old with no issues.
Well... we had an issue with the first Sony BD-300 in 2009, but may be we did something wrong in that times. Good to know 2.6 works well.
@Uranium23567 try to burn only BDMV and CERTIFICATE. -
@Uranium23567, just FYI, the test BD-RE that I made was played on an old Samsung BD-FM57C Blu-Ray Player.
Yeah, ****. So I did that, I hooked the USB DVD burner I have for my laptop to the compilation computer (instead of moving it to another computer with a SATA BD burner). Used a different disc (DVD-R) in DAO with imgburn, UDF 2.5, BD compatibility settings in imgburn.
Same damn thing.
New to Blu Ray Burning. How do you burn a 42gb Blu Ray ISO on a 8.5 DL DVD
By zipsick in forum Authoring (VCD/SVCD)Replies: 4Last Post: 23rd Mar 2025, 10:50 -
Any current Blu-Ray players that can play back MKV from data BD-R?
By guy24s in forum DVD & Blu-ray PlayersReplies: 1Last Post: 20th Mar 2025, 13:19 -
DVD Subs stay "on" ONLY on Blu-Ray Players
By acorngr in forum SubtitleReplies: 2Last Post: 23rd Dec 2024, 03:38 -
Noob here, trying to burn Blu-ray with multiAVCHD
By beantrouser in forum Authoring (Blu-ray)Replies: 2Last Post: 8th Jan 2024, 16:01 -
Do Blu-Ray players actually upscale?
By 60fpshacksrock in forum DVD & Blu-ray PlayersReplies: 3Last Post: 23rd Jul 2021, 09:09
