Hey everyone,
I’m attaching a short clip for feedback.
To my eyes it doesn’t look very natural - it’s overly sharp and kind of “processed.”
Or maybe it’s just me - after so long working with the DV standard.
The source is a modern, not so cheap car dashcam that someone used for non‑car footage.
The device claims it records in 4K'ish dimensions (UWQHD),
but I’ve seen devices that upscale lower resolution just after recording stops.
Question is, how should I fix it? Should I?
Thanks.
Most dashcam, security, and trail cameras use sensors that are much lower resolution than what is claimed. To achieve their published specs, they simply up-res. The results of capturing in lower resolution and then up-resn'g are what you see when neophytes in this forum try to get details and sharpness that is missing in their lower resolution images. Sharpening is often part of this quest to produce details that are not there.
So, it is not surprising that your sample looks over-sharpened.
There are lots of comparison sites which uncover these issues, like this one:
The Truth About Dash Cams!
I've done a little work with security cameras (similar technology to dashcams), and if you want one that can actually read license plates (a requirement for both dashcams and security cameras), you have to spend at least $1,000. I have a dashcam, but it is $100 and when I've tested to see how many license plates I can read, my car has to be only a few car lengths away before I can resolve the letters and numbers.
AI software promises to be able to produce actual details where they did not exist. While I have learned to not underestimate what AI can do, so far I have not seen a convincing demo. -
Recommended to check this video. https://youtu.be/uLjGazIxjEA The guy probably doesn’t know about AviSynth’s miracles and just went empirical with dashcams. That’s empirical, not commercial. The one obtained is among the best channel findings. Interesting channel after all.
It is UWQHD ("4K" is the most abused and misused term on the planet).
I don't think so. It looks fine to me.Should I? -
It is simply heavily denoised, some form of median denoiser probably - typical look for poor sensor in low light conditions - to reduce video bitrate source need to be denoised and this is effect.
Does deinterlacing raw footage vs compressed footage makes a difference ?
By Hamilthon in forum Video ConversionReplies: 15Last Post: 10th Apr 2025, 07:32 -
How to repair AVI file - dashcam footage for accident
By kp278 in forum Newbie / General discussionsReplies: 13Last Post: 7th Dec 2022, 02:17 -
dashcam Nextbase 522 GW issue
By realspeed in forum Newbie / General discussionsReplies: 1Last Post: 2nd Sep 2022, 17:42 -
Can't concat Garmin DashCam videos with telemetry (GPS data)
By jmlgeo in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2021, 17:23 -
MP4 from dashcam
By Deltaechocharlie in forum Newbie / General discussionsReplies: 4Last Post: 4th Sep 2020, 23:18
