I have a 1h 12m 19s AVI file that I recorded / captured from my Canon MD101 back in 2008. The file is 12.9 GB.
I have used Avidemux to cut it into quarters, as 12.9 GB is quite a large file.
However, the four new files total 1h 12m 13s.
I do not believe there are any keyframes to worry about, so I am a bit confused.
Any ideas?
If it helps, here is the data from MediaInfo of the original file, and one of the cut files:
Original:
Cut:Code:General Format : AVI Format/Info : Audio Video Interleave Commercial name : DVCAM Format profile : OpenDML Format settings : BitmapInfoHeader / PcmWaveformat File size : 13.0 GiB Duration : 1 h 2 min Overall bit rate mode : Constant Overall bit rate : 29.8 Mb/s Frame rate : 25.000 FPS Recorded date : 2008-06-19 19:58:28.000 Writing application : Adobe Premiere Pro 2.0 Video ID : 0 Format : DV Commercial name : DVCAM Codec ID : dvsd Codec ID/Hint : Sony Duration : 1 h 2 min Bit rate mode : Constant Bit rate : 24.4 Mb/s Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Bottom Field First Compression mode : Lossy Bits/(Pixel*Frame) : 2.357 Stream size : 12.5 GiB (97%) Encoding settings : wb mode= / white balance= / fcm=auto focus Audio ID : 1 Format : PCM Format settings : Little / Signed Codec ID : 1 Duration : 1 h 2 min Bit rate mode : Constant Bit rate : 1 024 kb/s Channel(s) : 2 channels Sampling rate : 32.0 kHz Bit depth : 16 bits Stream size : 457 MiB (3%) Alignment : Aligned on interleaves Interleave, duration : 1000 ms (25.00 video frames) Interleave, preload duration : 1000 ms
Code:General Format : AVI Format/Info : Audio Video Interleave Commercial name : DVCAM Format settings : BitmapInfoHeader / PcmWaveformat File size : 3.09 GiB Duration : 14 min 49 s Overall bit rate mode : Constant Overall bit rate : 29.8 Mb/s Frame rate : 25.000 FPS Recorded date : 2008-06-19 19:58:28.000 Video ID : 0 Format : DV Commercial name : DVCAM Codec ID : dvsd Codec ID/Hint : Sony Duration : 14 min 49 s Bit rate mode : Constant Bit rate : 24.4 Mb/s Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Bottom Field First Compression mode : Lossy Bits/(Pixel*Frame) : 2.357 Stream size : 2.98 GiB (97%) Encoding settings : wb mode= / white balance= / fcm=auto focus Audio ID : 1 Format : PCM Format settings : Little / Signed Codec ID : 1 Duration : 14 min 49 s Bit rate mode : Constant Bit rate : 1 024 kb/s Channel(s) : 2 channels Sampling rate : 32.0 kHz Bit depth : 16 bits Stream size : 109 MiB (3%) Alignment : Aligned on interleaves Interleave, duration : 25 ms (0.63 video frame)
	There are a few potential reasons for the slight time discrepancy you're experiencing.
 Possible Causes:
 1- Keyframe Alignment
 - Even if you don't think there are keyframes, video editing software often uses keyframe-based cutting
 2- Codec Specifics
 - Some codecs handle cutting differently, potentially losing a few seconds during segmentation
 3- Metadata Inconsistency
 - Avidemux might not perfectly preserve exact timestamps
 Verification Steps
 I recommend using ffprobe to get more precise information about the original and cut files.
 # Check original file details
 # Check cut file detailsCode:ffprobe -v error -show_entries format=duration -of default=noprint_wrappers=1:nokey=1 original_file.avi
 FFmpeg often provides more accurate cutting compared to Avidemux.Code:ffprobe -v error -show_entries format=duration -of default=noprint_wrappers=1:nokey=1 cut_file1.avi ffprobe -v error -show_entries format=duration -of default=noprint_wrappers=1:nokey=1 cut_file2.avi ffprobe -v error -show_entries format=duration -of default=noprint_wrappers=1:nokey=1 cut_file3.avi ffprobe -v error -show_entries format=duration -of default=noprint_wrappers=1:nokey=1 cut_file4.avi Last edited by videoAI; 26th Aug 2025 at 11:58. There is nothing wrong .. with my environment
	Standard definition DV is all keyframes. You can cut in/out losslessly on any frame. So that's not an issue.
  Does deinterlacing raw footage vs compressed footage makes a difference ?By Hamilthon in forum Video ConversionReplies: 15Last Post: 10th Apr 2025, 07:32
  Getting a quote to fade in in two partsBy BenO in forum EditingReplies: 1Last Post: 16th Mar 2023, 13:58
  How to repair AVI file - dashcam footage for accidentBy kp278 in forum Newbie / General discussionsReplies: 13Last Post: 7th Dec 2022, 02:17
  Blur parts of a videoBy Nico Darko in forum Video ConversionReplies: 6Last Post: 21st May 2022, 23:36
  Combine Same parts of Videos with Better partsBy kucing in forum Newbie / General discussionsReplies: 15Last Post: 4th Sep 2021, 12:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
