Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 31 to 60 of 82
  1. Originally Posted by Data2006 View Post
    Hello,
    Here's the file again. I just created it.
    Best regards
    Heiko
    hey can you send screenshots when it starts downloading both video and audio, because i don't have working vpn to proceed further
    N_m3u8DL-RE "https://manifest.googlevideo.com/api/manifest/dash/expire/1756830587/ei/G8e2aNrDLevy6dsP64Hl0QQ/ip/2003%3Aca%3A4f19%3Ab500%3Aed7a%3A8687%3A3306%3A1cec/id/51b0ca0fa4960d99/source/youtube/requiressl/yes/xpc/EgVo2aDSNQ%3D%3D/playback_host/rr5---sn-4g5lznl6.googlevideo.com/met/1756808987%2C/mh/3d/mm/31%2C29/mn/sn-4g5lznl6%2Csn-4g5edndy/ms/au%2Crdu/mv/m/mvi/5/pl/37/rms/au%2Cau/ctier/A/as/fmp4_audio_cenc%2Cfmp4_sd_hd_cenc/pfa/5/gcr/de/initcwndbps/806250/hightc/yes/siu/1/spc/l3OVKfdzb1LxR94_NJHZpW_pU_RS9hLGofQOkSymA74ITWXMv6YX3K_Z_WxIGtY7x94U/vprv/1/rqh/2/mt/1756808515/fvip/3/keepalive/yes/fexp/51355912%2C51552689%2C51565115%2C51565681%2C51580968/itag/0/sparams/expire%2Cei%2Cip%2Cid%2Csource%2Crequiressl%2Cxpc%2Cctier%2Cas%2Cpfa%2Cgcr%2Chightc%2Csiu%2Cspc%2Cvprv%2Crqh%2Citag/sig/AJfQdSswRQIhAOspYjRnVdY4HIODxaovOuPgo5zjo05bEE1ArA_eniZqAiAZb8fHStiaZFrh1eeAtFe2jP47FbEjvuSjzK6m76yWPg%3D%3D/lsparams/playback_host%2Cmet%2Cmh%2Cmm%2Cmn%2Cms%2Cmv%2Cmvi%2Cpl%2Crms%2Cinitcwndbps/lsig/APaTxxMwRQIhAN3yIGqZ8GSaYcTvME7iQYRBVtKOp66-MSn0T8Sbs_L_AiASHmKkhaXwgl7dQjZ-KboyuwRlzWfTGtQq5tD2TbnAgA%3D%3D" -sv best -sa best -ss all --save-name "Stand By Me - Das Geheimnis eines Sommers" -mt -M mkv --key b54d66c6808e5d82ba3821b0534e75ee:b89e695a41d9ec92564e9c8a3632605e --key eaf2c76eb69151c0b6d74111d950639b:72d4a47133233643de2a11532de23f3c --use-shaka-packager
    if link doesn't work it means it's expired
  2. Best regards
    Heiko
  3. Originally Posted by Data2006 View Post
    Best regards
    Heiko
    your one key is incorrect
    find this one 3533d589ec6251ad9919104bc8fb2488:
    this key is correct
  4. Code:
    heiko@Worf:/media/heiko/Win11 (2)/Users/Heiko/Stephen King$ N_m3u8DL-RE "https://manifest.googlevideo.com/api/manifest/dash/expire/1756830587/ei/G8e2aNrDLevy6dsP64Hl0QQ/ip/2003%3Aca%3A4f19%3Ab500%3Aed7a%3A8687%3A3306%3A1cec/id/51b0ca0fa4960d99/source/youtube/requiressl/yes/xpc/EgVo2aDSNQ%3D%3D/playback_host/rr5---sn-4g5lznl6.googlevideo.com/met/1756808987%2C/mh/3d/mm/31%2C29/mn/sn-4g5lznl6%2Csn-4g5edndy/ms/au%2Crdu/mv/m/mvi/5/pl/37/rms/au%2Cau/ctier/A/as/fmp4_audio_cenc%2Cfmp4_sd_hd_cenc/pfa/5/gcr/de/initcwndbps/806250/hightc/yes/siu/1/spc/l3OVKfdzb1LxR94_NJHZpW_pU_RS9hLGofQOkSymA74ITWXMv6YX3K_Z_WxIGtY7x94U/vprv/1/rqh/2/mt/1756808515/fvip/3/keepalive/yes/fexp/51355912%2C51552689%2C51565115%2C51565681%2C51580968/itag/0/sparams/expire%2Cei%2Cip%2Cid%2Csource%2Crequiressl%2Cxpc%2Cctier%2Cas%2Cpfa%2Cgcr%2Chightc%2Csiu%2Cspc%2Cvprv%2Crqh%2Citag/sig/AJfQdSswRQIhAOspYjRnVdY4HIODxaovOuPgo5zjo05bEE1ArA_eniZqAiAZb8fHStiaZFrh1eeAtFe2jP47FbEjvuSjzK6m76yWPg%3D%3D/lsparams/playback_host%2Cmet%2Cmh%2Cmm%2Cmn%2Cms%2Cmv%2Cmvi%2Cpl%2Crms%2Cinitcwndbps/lsig/APaTxxMwRQIhAN3yIGqZ8GSaYcTvME7iQYRBVtKOp66-MSn0T8Sbs_L_AiASHmKkhaXwgl7dQjZ-KboyuwRlzWfTGtQq5tD2TbnAgA%3D%3D" -sv best -sa best -ss all --save-name "Stand By Me - Das Geheimnis eines Sommers" -mt -M mkv --key eaf2c76eb69151c0b6d74111d950639b:72d4a47133233643de2a11532de23f3c --use-shaka-packager
    14:41:46.654 INFO : N_m3u8DL-RE (Beta version) 20240630
    14:41:46.662 ERROR: Unable to find the specified file.
    14:41:46.839 INFO : New version detected! v0.3.0-beta
    Best regards
    Heiko
  5. Originally Posted by Data2006 View Post
    Best regards
    Heiko
    find 2nd key man, and the link you are trying is expired
  6. So, I played the video again. Then pressed Ctrl+U. I saved it as a .txt file. I searched for manifest.google and copied it.
    And pulled new keys via WidevineProxy2. Two keys were displayed again.
    But I still got the error.
    Best regards
    Heiko
  7. Originally Posted by Data2006 View Post
    Best regards
    Heiko
    send screenshot
  8. I tried again with your first command and your second key. Your link still works.
    Which browser are you using, and are you also using WidevineProxy2?
  9. Originally Posted by Data2006 View Post
    have you got your first key? because i see there is need of 2 keys one for video and 2nd for audio (based on your screenshot)
    your first key starts from 3533d589ec6251ad9919104bc8fb2488
    and i am using nothing from my side, everything is from your side
  10. Code:
  11. Originally Posted by Data2006 View Post
    this one is wrong
  12. Code:
  13. Why is it wrong? WidefrogProxy2 shows it like this.
  14. Is it possible that I'm using an outdated/incorrect WVD file in WidefrogProxy2? If so, where can I get a current version?
  15. Originally Posted by Data2006 View Post
    try this https://github.com/FoxRefire/wvg/
  16. The instructions are quite complicated. I did that once, but it was a long time ago.
    Don't you have a ready-made WVD file? Thanks.
    Best regards
    Heiko
  17. Originally Posted by Data2006 View Post
    Best regards
    Heiko
    just use the same file you using for WVP2
  18. Yes, but I want to create a new WVD file for WVP2.
    Or is there another way to get the keys?
    Best regards
    Heiko
  19. I was able to find 2 other keys with the Widevine L3 Decrypter:
    --key b54d66c6808e5d82ba3821b0534e75ee:b89e695a41d9ec925 64e9c8a3632605e --key eaf2c76eb69151c0b6d74111d950639b:72d4a47133233643d e2a11532de23f3c
    But now I'm having trouble finding the video URL. Ctrl+u is very cumbersome. How do I find something there?
    Best regards
    Heiko
  20. It didn't work via yt-dlp either:
    heiko@Worf:/media/heiko/Win11 (2)/Users/Heiko/Stephen King$ yt-dlp -o enc.mp4 "https://manifest.googlevideo.com/api/manifest/dash/expire/1756860631/ei/dzy3aIjNM9GLvdIPw4eh6A4/ip/2003%3Aca%3A4f19%3Ab500%3A34eb%3A16ef%3A50a0%3A2103/id/51b0ca0fa4960d99/source/youtube/requiressl/yes/xpc/EgVo2aDSNQ%3D%3D/playback_host/rr3---sn-4g5edndy.googlevideo.com/met/1756839031%2C/mh/3d/mm/31%2C29/mn/sn-4g5edndy%2Csn-4g5lznl6/ms/au%2Crdu/mv/m/mvi/3/pl/44/rms/au%2Cau/ctier/A/as/fmp4_audio_cenc%2Cfmp4_sd_hd_cenc/pfa/5/gcr/de/initcwndbps/377500/hightc/yes/siu/1/spc/l3OVKfvVGd7ywWXwTZRmTDjKOa_jBy6H4SJj4AN4YxIuWPNqP_nqWi3blWJ005GzfW8I/vprv/1/rqh/2/mt/1756838492/fvip/5/keepalive/yes/fexp/51355912%2C51552689%2C51565115%2C51565681%2C51580968/itag/0/sparams/expire%2Cei%2Cip%2Cid%2Csource%2Crequiressl%2Cxpc%2Cctier%2Cas%2Cpfa%2Cgcr%2Chightc%2Csiu%2Cspc%2Cvprv%2Crqh%2Citag/sig/AJfQdSswRQIhAOoaoJ74ZOy5fL15uwlKIgfU0e7H172DYEceIwQaM05YAiAy64nEXYN3Fc5oatYj2gVAe6eV5TVXzzl47M-u89vjcg%3D%3D/lsparams/playback_host%2Cmet%2Cmh%2Cmm%2Cmn%2Cms%2Cmv%2Cmvi%2Cpl%2Crms%2Cinitcwndbps/lsig/APaTxxMwRAIgWdOhw_8Y4qHEyrzoyiPZpjQduiLmoeC-zILMo_S5xccCIDi5ZUnZseeL-1BU2Y3rZtO_sbJBQg60tecEugtmfqJT" --cookies-from-browser firefox
    [generic] Extracting URL: https://manifest.googlevideo.com/api/manifest/dash/expire/1756860631/ei/dzy3aIjNM9GLvdIPw4eh6A4/i...sbJBQg60tecEugtmfqJT
    [generic] APaTxxMwRAIgWdOhw_8Y4qHEyrzoyiPZpjQduiLmoeC-zILMo_S5xccCIDi5ZUnZseeL-1BU2Y3rZtO_sbJBQg60tecEugtmfqJT: Downloading webpage
    Extracting cookies from firefox
    Extracted 156 cookies from firefox
    [info] APaTxxMwRAIgWdOhw_8Y4qHEyrzoyiPZpjQduiLmoeC-zILMo_S5xccCIDi5ZUnZseeL-1BU2Y3rZtO_sbJBQg60tecEugtmfqJT: Downloading 1 format(s): vnd.mpeg.dash.mpd
    [download] enc.mp4 has already been downloaded
    [download] 100% of   24.76KiB
    I don't know what to do now. How can I download the movie so that it runs through?
    Best regards
    Heiko
  21. Originally Posted by Data2006 View Post
    Best regards
    Heiko
    man find the first key, this one is wrong
    your 1st key - missing
    your 2nd key - eaf2c76eb69151c0b6d74111d950639b:72d4a47133233643d e2a11532de23f3c
  22. Good morning,
    Okay, the first key might be wrong, but where do I get the first key?
    The L3 guesser didn't work either.
    Or can you give me the two keys and the new N_m3u8DL-RE command? Thx.
    Best regards
    Heiko
  23. Hi.
    My 2 Keys.
    Best regards
    Heiko
  24. Chrome-Widevine-Guesser-2025-main:
    Note:This is free version valid for 25 hits per ip..
    1. Extract the zip file
    2. Go to the extracted folder
    3. You will see a license.json file, open it in any text editor.
    4. update host and key as required. Make sure to save the file after editing!
    5. Contact on telegram https://t.me/chromeapisupport to buy.
    5 Chrome decrypt updates channel : https://t.me/chromedecrypt
    	"host": "https://chromeapi.wf",
    	"key": "@chromedecrypt"
    I can't install this new version in Chrome.
    What do I need to enter in the license.json file?
    Best regards
    Heiko
  25. Originally Posted by Data2006 View Post
    Good morning,
    Best regards
    Heiko
    check your private message
  26. Another question: I'm using Ubuntu 24.04 for N_m3u8DL-RE. Would it help to try it under Windows 11 Pro?
    Best regards
    Heiko
  27. Good evening,
    I need some help with this:
    https://www.youtube.com/watch?v=4EtXNUz_L2Q&t=4554s
    I found manifest.google, but I can't download it. Apparently the address is incorrect:
    heiko@Worf:/media/heiko/Win11 (2)/Users/Heiko/Love Lies Bleeding$ N_m3u8DL-RE -sv best -sa best -mt -M mkv --use-shaka-packager "https://manifest.googlevideo.com/api/manifest/dash/expire/1757461584/ei/8GfAaKOaNfjjxN8Phb6x8As/ip/2003%3Aca%3A4f19%3Ab500%3A7b83%3A941%3Ad103%3Aaef3/id/e04b57354cff2f64/source/youtube/requiressl/yes/xpc/EgVo2aDSNQ%3D%3D/playback_host/rr2---sn-h0jeln7l.googlevideo.com/met/1757439984%2C/mh/1i/mm/31%2C29/mn/sn-h0jeln7l%2Csn-4g5e6nzl/ms/au%2Crdu/mv/m/mvi/2/pl/44/rms/au%2Cau/ctier/A/as/fmp4_audio_cenc%2Cfmp4_sd_hd_cenc/pfa/5/gcr/de/initcwndbps/2328750/hightc/yes/siu/1/spc/hcYD5fs8oH2v6QSVq7n368FJfWb50VwUKi9pIVEz07L36stLPRZ8UC2w46bTfsYTMkTX/vprv/1/rqh/2/mt/1757439732/fvip/4/keepalive/yes/fexp/51355912%2C51552689%2C51565115%2C51565681%2C51580968/itag/0/sparams/expire%2Cei%2Cip%2Cid%2Csource%2Crequiressl%2Cxpc%2Cctier%2Cas%2Cpfa%2Cgcr%2Chightc%2Csiu%2Cspc%2Cvprv%2Crqh%2Citag/sig/AJfQdSswRgIhAPI7sM5mRRwomF_Ebnr3XIOAD3ntJZopY69BfvZ0MUdkAiEAqNW-5flFCKFwxJeNB6qaHoYJqN23pswPgbDVywyfOcc%3D/lsparams/playback_host%2Cmet%2Cmh%2Cmm%2Cmn%2Cms%2Cmv%2Cmvi%2Cpl%2Crms%2Cinitcwndbps/lsig/APaTxxMwRQIhANsP6nUVNzZnuNTsJExyE__GAh58ck6sx-gt3ug8XBrmAiBvXG-ExIY9SE6SKjyhcNs1f_rgscfHxsA0JTY0rfOaFg%3D%3D" --key 39af1710081b527eb3f316ef3f207137:8a8d79e6d5b577fa86e4f604db1b88bc --key 356db50fb42b5ceb864cab1f75e8cd19:8a21f8065102a990b9ab3a28c7eedf26 --key fc8f63d06f7d5cbda877c3339fbb03e9:800ec5cbc3b4762d51694a03fa9d0c1a
    19:48:31.939 INFO : N_m3u8DL-RE (Beta version) 20240630
    19:48:31.946 INFO : Loading URL: https://manifest.googlevideo.com/api/manifest/dash/expire/1757461584/ei/8GfAaKOaNfjjxN8Phb6x8As/ip/2003%3Aca%3A4f19%3Ab500%3A7b83%3A941%3Ad103%3Aaef3/id/e04b57354cff2f64/source/youtube/requiressl/yes/xpc/EgVo2aDSNQ%3D%3D/playback_host/rr2---sn-h0jeln7l.googlevideo.com/met/1757439984%2C/mh/1i/mm/31%2C29/mn/sn-h0jeln7l%2Csn-4g5e6nzl/ms/au%2Crdu/mv/m/mvi/2/pl/44/rms/au%2Cau/ctier/A/as/fmp4_audio_cenc%2Cfmp4_sd_hd_cenc/pfa/5/gcr/de/initcwndbps/2328750/hightc/yes/siu/1/spc/hcYD5fs8oH2v6QSVq7n368FJfWb50VwUKi9pIVEz07L36stLPRZ8UC2w46bTfsYTMkTX/vprv/1/rqh/2/mt/1757439732/fvip/4/keepalive/yes/fexp/51355912%2C51552689%2C51565115%2C51565681%2C51580968/itag/0/sparams/expire%2Cei%2Cip%2Cid%2Csource%2Crequiressl%2Cxpc%2Cctier%2Cas%2Cpfa%2Cgcr%2Chightc%2Csiu%2Cspc%2Cvprv%2Crqh%2Citag/sig/AJfQdSswRgIhAPI7sM5mRRwomF_Ebnr3XIOAD3ntJZopY69BfvZ0MUdkAiEAqNW-5flFCKFwxJeNB6qaHoYJqN23pswPgbDVywyfOcc%3D/lsparams/playback_host%2Cmet%2Cmh%2Cmm%2Cmn%2Cms%2Cmv%2Cmvi%2Cpl%2Crms%2Cinitcwndbps/lsig/APaTxxMwRQIhANsP6nUVNzZnuNTsJExyE__GAh58ck6sx-gt3ug8XBrmAiBvXG-ExIY9SE6SKjyhcNs1f_rgscfHxsA0JTY0rfOaFg%3D%3D
    19:48:32.071 INFO : New version detected! v0.3.0-beta
    19:48:32.212 WARN : Response status code does not indicate success: 404 (Not Found). (1/10)
    19:48:33.712 INFO : Loading URL: https://manifest.googlevideo.com/api/manifest/dash/expire/1757461584/ei/8GfAaKOaNfjjxN8Phb6x8As/ip/2003%3Aca%3A4f19%3Ab500%3A7b83%3A941%3Ad103%3Aaef3/id/e04b57354cff2f64/source/youtube/requiressl/yes/xpc/EgVo2aDSNQ%3D%3D/playback_host/rr2---sn-h0jeln7l.googlevideo.com/met/1757439984%2C/mh/1i/mm/31%2C29/mn/sn-h0jeln7l%2Csn-4g5e6nzl/ms/au%2Crdu/mv/m/mvi/2/pl/44/rms/au%2Cau/ctier/A/as/fmp4_audio_cenc%2Cfmp4_sd_hd_cenc/pfa/5/gcr/de/initcwndbps/2328750/hightc/yes/siu/1/spc/hcYD5fs8oH2v6QSVq7n368FJfWb50VwUKi9pIVEz07L36stLPRZ8UC2w46bTfsYTMkTX/vprv/1/rqh/2/mt/1757439732/fvip/4/keepalive/yes/fexp/51355912%2C51552689%2C51565115%2C51565681%2C51580968/itag/0/sparams/expire%2Cei%2Cip%2Cid%2Csource%2Crequiressl%2Cxpc%2Cctier%2Cas%2Cpfa%2Cgcr%2Chightc%2Csiu%2Cspc%2Cvprv%2Crqh%2Citag/sig/AJfQdSswRgIhAPI7sM5mRRwomF_Ebnr3XIOAD3ntJZopY69BfvZ0MUdkAiEAqNW-5flFCKFwxJeNB6qaHoYJqN23pswPgbDVywyfOcc%3D/lsparams/playback_host%2Cmet%2Cmh%2Cmm%2Cmn%2Cms%2Cmv%2Cmvi%2Cpl%2Crms%2Cinitcwndbps/lsig/APaTxxMwRQIhANsP6nUVNzZnuNTsJExyE__GAh58ck6sx-gt3ug8XBrmAiBvXG-ExIY9SE6SKjyhcNs1f_rgscfHxsA0JTY0rfOaFg%3D%3D
    19:48:33.785 WARN : Response status code does not indicate success: 404 (Not Found). (2/10)
    19:48:35.287 INFO : Loading URL: https://manifest.googlevideo.com/api/manifest/dash/expire/1757461584/ei/8GfAaKOaNfjjxN8Phb6x8As/ip/2003%3Aca%3A4f19%3Ab500%3A7b83%3A941%3Ad103%3Aaef3/id/e04b57354cff2f64/source/youtube/requiressl/yes/xpc/EgVo2aDSNQ%3D%3D/playback_host/rr2---sn-h0jeln7l.googlevideo.com/met/1757439984%2C/mh/1i/mm/31%2C29/mn/sn-h0jeln7l%2Csn-4g5e6nzl/ms/au%2Crdu/mv/m/mvi/2/pl/44/rms/au%2Cau/ctier/A/as/fmp4_audio_cenc%2Cfmp4_sd_hd_cenc/pfa/5/gcr/de/initcwndbps/2328750/hightc/yes/siu/1/spc/hcYD5fs8oH2v6QSVq7n368FJfWb50VwUKi9pIVEz07L36stLPRZ8UC2w46bTfsYTMkTX/vprv/1/rqh/2/mt/1757439732/fvip/4/keepalive/yes/fexp/51355912%2C51552689%2C51565115%2C51565681%2C51580968/itag/0/sparams/expire%2Cei%2Cip%2Cid%2Csource%2Crequiressl%2Cxpc%2Cctier%2Cas%2Cpfa%2Cgcr%2Chightc%2Csiu%2Cspc%2Cvprv%2Crqh%2Citag/sig/AJfQdSswRgIhAPI7sM5mRRwomF_Ebnr3XIOAD3ntJZopY69BfvZ0MUdkAiEAqNW-5flFCKFwxJeNB6qaHoYJqN23pswPgbDVywyfOcc%3D/lsparams/playback_host%2Cmet%2Cmh%2Cmm%2Cmn%2Cms%2Cmv%2Cmvi%2Cpl%2Crms%2Cinitcwndbps/lsig/APaTxxMwRQIhANsP6nUVNzZnuNTsJExyE__GAh58ck6sx-gt3ug8XBrmAiBvXG-ExIY9SE6SKjyhcNs1f_rgscfHxsA0JTY0rfOaFg%3D%3D
    19:48:35.406 WARN : Response status code does not indicate success: 404 (Not Found). (3/10)
    19:48:36.907 INFO : Loading URL: https://manifest.googlevideo.com/api/manifest/dash/expire/1757461584/ei/8GfAaKOaNfjjxN8Phb6x8As/ip/2003%3Aca%3A4f19%3Ab500%3A7b83%3A941%3Ad103%3Aaef3/id/e04b57354cff2f64/source/youtube/requiressl/yes/xpc/EgVo2aDSNQ%3D%3D/playback_host/rr2---sn-h0jeln7l.googlevideo.com/met/1757439984%2C/mh/1i/mm/31%2C29/mn/sn-h0jeln7l%2Csn-4g5e6nzl/ms/au%2Crdu/mv/m/mvi/2/pl/44/rms/au%2Cau/ctier/A/as/fmp4_audio_cenc%2Cfmp4_sd_hd_cenc/pfa/5/gcr/de/initcwndbps/2328750/hightc/yes/siu/1/spc/hcYD5fs8oH2v6QSVq7n368FJfWb50VwUKi9pIVEz07L36stLPRZ8UC2w46bTfsYTMkTX/vprv/1/rqh/2/mt/1757439732/fvip/4/keepalive/yes/fexp/51355912%2C51552689%2C51565115%2C51565681%2C51580968/itag/0/sparams/expire%2Cei%2Cip%2Cid%2Csource%2Crequiressl%2Cxpc%2Cctier%2Cas%2Cpfa%2Cgcr%2Chightc%2Csiu%2Cspc%2Cvprv%2Crqh%2Citag/sig/AJfQdSswRgIhAPI7sM5mRRwomF_Ebnr3XIOAD3ntJZopY69BfvZ0MUdkAiEAqNW-5flFCKFwxJeNB6qaHoYJqN23pswPgbDVywyfOcc%3D/lsparams/playback_host%2Cmet%2Cmh%2Cmm%2Cmn%2Cms%2Cmv%2Cmvi%2Cpl%2Crms%2Cinitcwndbps/lsig/APaTxxMwRQIhANsP6nUVNzZnuNTsJExyE__GAh58ck6sx-gt3ug8XBrmAiBvXG-ExIY9SE6SKjyhcNs1f_rgscfHxsA0JTY0rfOaFg%3D%3D
    19:48:37.007 WARN : Response status code does not indicate success: 404 (Not Found). (4/10)
    ^C19:48:38.294 WARN : Force Exit...
    Can someone please help me? Thank you.
    Best regards
    Heiko
  28. PS: I use Firefox on Ubuntu.
  29. Hi.
    I just downloaded another movie from YouTube. I received these files:
    heiko@Worf:/media/heiko/Win11 (2)/Users/Heiko/Conjuring 3 - Im Bann des Teufels/4K$ ll
    insgesamt 19917972
    drwxrwxr-x 1 heiko heiko           0 Sep 11 18:09 ./
    drwxrwxr-x 1 heiko heiko        4096 Sep 11 17:45 ../
    -rw-rw-r-- 1 heiko heiko   327855265 Sep 11 18:09 enc.f261-12.m4a
    -rw-rw-r-- 1 heiko heiko 20068142490 Sep 11 18:09 enc.f687.mp4
    I selected this resolution with yt-dlp -f:
    687    mp4  3840x2160   24 10     │   18.69GiB 23926k https │ vp09.02.50.10 23926k video only          DRM, 2160p HDR, mp4_dash
    mp4decrypt couldn't decrypt the video. What program can I use to decrypt it?
    Perhaps shaka-packager?
    Best regards
    Heiko
  30. Hello everyone.
    Does anyone have any tips for me?
    When I use mp4decrypt, the audio works, but VLC won't play the video because of vp9.
    Best regards
    Heiko
