Hi everyone, I’m new here.
I’ve got a Canopus ADVC-100 unit that’s being detected, but it won’t show any preview from the VHS player. All the switches are off except for No. 1 (set to PAL for Australia). No matter how I change the switch settings, nothing comes up in the preview - just a blue screen with 'playing' & 'camera connected'.
I’ve tried both FireWire ports (front and back) on my PowerMac G4 MDD, but mainly use the front one. My friend’s ADVC-110 works flawlessly on the same setup, so I know the Mac and the FireWire ports are fine.
Could this be a case of failing or leaky capacitors in the ADVC-100? Has anyone here come across the same issue and managed to fix it by recapping the board?
Thanks in advance for any advice.
Most likely it is the SMT capacitors. Both of my ADVC-110's stopped working and now work fine after recap.
Thanks for that aramkolt - ill get it recapped by a technician and hopefully see how it goes from that.
Canopus ADVC boxes are 1990s tech (Pentium III specs suggested, Pentium II minimum), with many quality-lowering issues. These weren't made to last 25 years, and should have been replaced with better cards 20 years ago. I would take this as an opportunity to upgrade to 2000s-2010s quality lossless cards.
Canopus ADVC-100 has a TBC after all
By amaipaipai in forum Capturing and VCRReplies: 65Last Post: 4th Mar 2025, 01:47 -
Canopus advc 100 not working
By BonnieW88 in forum Capturing and VCRReplies: 6Last Post: 21st Sep 2023, 00:19 -
How many Amps for Canopus ADVC-100
By Zax3 in forum Capturing and VCRReplies: 8Last Post: 15th Dec 2021, 12:12 -
Canopus ADVC-100 vs. ADVC-110 vs. ADVC-300
By TrackingError in forum Capturing and VCRReplies: 36Last Post: 16th Jul 2021, 11:19 -
Canopus ADVC 100 do not by any PC
By Videonet in forum Capturing and VCRReplies: 6Last Post: 17th May 2021, 23:49
