  1. Hello all.
    I have a DENON AVR-S770H receiver.
    I also have an mkv file with 2 audio tracks that can't play correctly.
    The first is a pcm 5.1 track but my receiver shows me that the input signal is stereo and can't decode it to 5.1.
    Even when I press Dolby Surround, the dialogue seems to bleed in the other than the center speakers.
    The second track is Dolby TrueHD 5.1, but with that track I don't hear anything at all (although I can play blu-rays with such audio format).
    Both tracks are in 44.1KHz and not 48KHz which is the norm. Maybe that is the fault?
    So, I'd be interested in converting (without quality loss) any of those 2 tracks to a correct and playable 5.1 track.
    Is this possible? Does anyone know how?
    By the way, here's the info on the 2 tracks in case that helps:
    Audio #2
    Format : PCM
    Format settings : Little
    Codec ID : A_PCM/FLOAT/IEEE
    Duration : 2 h 6 min
    Bit rate mode : Constant
    Bit rate : 8 467 kb/s
    Channel(s) : 6 channels
    Sampling rate : 44.1 kHz
    Bit depth : 32 bits
    Stream size : 7.51 GiB (6%)
    Default : No
    Forced : No
    Audio #3
    Format : MLP FBA
    Format/Info : Meridian Lossless Packing FBA
    Commercial name : Dolby TrueHD
    Codec ID : A_TRUEHD
    Bit rate mode : Variable
    Maximum bit rate : 9 597 kb/s
    Channel layout : L R C LFE Ls Rs
    Frame rate : 1 102.500 FPS (40 SPF)
    Bit depth : 24 bits
    Compression mode : Lossless
    Default : No
    Forced : No
  2. Originally Posted by videoAI View Post
    try clever FFmpeg-GUI
    Thank you very much!
    I converted the pcm track (which showed as 2 channels originally and didn't decode correctly with Dolby Surround) to Dolby TrueHD 48KHz, and it seems that did the trick!
    I haven't muxed in the track yet in the mkv, but I previewed it with VLC and it seems correct now, in 5.1 surround sound with the dialogue coming only from the center and not bleeding in the other channels.
    I don't suppose anything was "lost" during the conversion from 44.1KHz to 48, was there?
