Hi
please patience with cat.
I need use x264vfw encoder (not with virtualdub) to encode 10bit. Is it possible ?
thanks
Technically v2.x can, but the pipeline you use to feed x264vfw might cause problems in terms of pixel type incompatibilities
https://www.videohelp.com/software/x264-VFW/version-history
v2.00 2020.03.21.
- Initial version, using x264lib build 159, revision 2991
Because I haven't seen any updates on the original x264vfw codec in the past several years, I've made a new version, based on my x265vfw, using x264lib from https://code.videolan.org/videolan/x264
You can download the new x264vfw from http://mpxplay.sourceforge.net
Advantages over the original x264vfw:
- 8 and 10 bit encoding output (use --output-depth 10 option in the extra command line)
- Supports much more input color spaces, including 10 and 16 bit per channel ones (see list in the help, press '?' button)
can I encoding in MJPEG 10bit?
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 17th Mar 2025, 13:07 -
Going from 10Bit H265 to 8Bit H264
By carlmart in forum Video ConversionReplies: 12Last Post: 14th May 2021, 15:01 -
big color gradient 8bit vs 10bit X265 encode from 8bit source PLZ help
By kamyar in forum Newbie / General discussionsReplies: 0Last Post: 21st Apr 2021, 04:51 -
Newbie doubts about 10Bit and Bitrate
By Itzamna in forum Newbie / General discussionsReplies: 3Last Post: 8th Mar 2021, 14:03 -
HEVC_AMF 10bit support
By MihaiB. in forum Newbie / General discussionsReplies: 6Last Post: 18th Dec 2020, 01:09
