I have both tracks loaded in AVStoDVD, but I was never asked to configure an audio selection menu to select which audio track to use, and I don't see one in the preview menu or when I do a test convert and load the DVD folder in Potplayer. In fact, as far as Potplayer is concerned the video has only one audio stream. What's going on? Is there some special step I missed? Also, I saw no subtitle select menu either. Even though there is only one subtitle track, I was hoping I could choose whether or not to display subs through the DVD menu regardless.
Results 1 to 15 of 15
A2d does not offer a method of audio control via the menu. It does, however, create the VOB files with the extra tracks and it
can be confirmed by opening the vob in mediainfo.
The track to be played can be selected in the player
In general, for sources with 2 or 3 audio tracks, it's probably better to set A2d preferences/audio/ffmpeg(safemode)Last edited by davexnet; 6th Aug 2025 at 12:20.
You can use a software named Titlewriter .
It does not encode & only creates a menu.
It can remove a menu already in the video.
I usually work with a movie ripped as Main movie with no menu.
I also do a simple text menu but Titlewriter can create a more complex menu.
It has a good Help web page for guiding you.
The movie I used for the pictures of the menu.
The menu audio track selection:
Worked in MPC-BE & MPC-HC & DVDFAB player& Zoom player.
It did not work in VLC but I have had other movie menus work in VLC for the audio selection.
These are pictures of the menu I created.
[Attachment 88177 - Click to enlarge]
[Attachment 88178 - Click to enlarge]
[Attachment 88179 - Click to enlarge] -
Is it possible to apply that menu to a DVD, or will Titlewriter only create menus for whole videos in containers? Can it edit existing DVD menus without removing them? Perhaps I can start using DVDFlick again, I only stopped because it lists all audio and subtitle tracks not by title, but by language. I also like to include a 2.0 track and a 5.1 track, I even made a special script that downmixes better than a typical speaker setup would, I included LFE and rear speakers for example, and audio for all channels is at 100%
but if I can use a program to edit an existing DVD menu, perhaps I can simply rename the menu? So instead of:
Select Audio Track
English
English
I could have:
Select Audio Track
English 2.0
English 5.1
And a similar change to the subtitle menu:
Select Subtitle Track
English
English (Text/Signs)
Disable Subtitles -
On a DVD disc the data for the menu would already be burned or written.So that can not be changed.
Titlewriter has to have a VIDEO_TS folder on a computer
You can delete the titlewriter folder after you save the menu created.
I don't know if Titlewriter can edit existing DVD menus. If it can the DVD would still need to be ripped to a computer.
I will have to give that a try.
That's why I posted a picture.
The Setup screen shows how Titlewriter displsys the Subtitle & audio tracks.
Titlewriter does not have the ability to edit those. -
That's what I meant, if it could edit a VIDEO_TS folder on a PC, of course discs are readonly. Still, I feel like we might be onto something here, surprisingly DVDFlick is the only DVD authoring tool I have seen that has a reasonably fast and straightforward interface, allowing configuration in only a minute or two in most cases. But it lacks this one very specific feature, editing a menu generated by DVDFlick (renaming menu entries) might be the only way to do this properly.
cholla, sorry this program just stumped me and then it froze.
if i already have a video_ts folder (consists of one video track/one audio track and chapters)
how can i se this program to make a simple menu. i literally couldn't figure out how to do anything with this program.
but i have faith in you that's it's good. so give me a simple walk through on what to do.
@ geek gift,
This is the way I do it. Whether an "Expert" would do it the same way I do not know.
Also the "Help" pulldown/TitleWriter Help" links to webpage. It is a fairly complete guide.
1.Open Video_TS folder
2.If the video you are working on has a menu.
Use the DVD Menus pulldown & "Remove all menus from compilation"
3.Leave all unchecked except "Start Play with Root Menu in Vts_01"
"Save Change" & OK
4.Select "Make Menu"
5. I created a small all black .jpg for all the images with Irfanview
Put this for all images.
Select "Apply to all thumbnails"
6.Select "Advanced DVD Menu 0ptions"
Set up as picture.
7.Select "Return To Thumbnail View"
8.Select "Apply To All Movies" button & both "App|y To All Thumbnails" buttons.
9 Select "Preview" button & go through all the selection one at a time.
10.Select "Create Menu And Add lt" button
11. Test video in media player.
12.Delete Titlewriter folder if the video works correctly.
This is how I set up the "Advanced DVD Menu 0ptions"
[Attachment 88223 - Click to enlarge] -
ok i may have to sit this round out.
since i already have a video_ts. guess i should jump from step 1 to step 4.
but when i click on dvd menus. i don't even see the "make menu" option.
so everything after that, is a no too.
oh well i'm not really a menu person anyway.
It is here.It will show green if it is available.
[Attachment 88234 - Click to enlarge]
You can also use "Create Movie Menu" from the DVD Menus pulldown.
[Attachment 88236 - Click to enlarge]Last edited by cholla; 9th Aug 2025 at 20:51.
Opps double post
[Attachment 88237 - Click to enlarge] -
@ geek gift,
The video I'm posting was created by AVStoDVD.
Muxman is part of the process AVStoDVD uses to create a DVD.
I did not create a Menu for it with AVStoDVD or Titlewriter.
It opened fine in Titlewriter with make menu and create movie menu delectable.
Download it & see if it will work with your OS & Titlewriter. -
ok did the unzip. and the make menu and create menu options show, when selecting your video_ts folder.
This indicates there is a problem with your video.
Or if your video has a menu the make menu and create movie menu will be grayed out.
Use the "Remove all menus from compilation" in the DVD Menus drop down to remove any menus.
You can test making a menu for the video I posted.
rip audio from DVD-video into multiple tracks
By mrjayviper in forum DVD RippingReplies: 7Last Post: 23rd Jul 2023, 09:08 -
MP4 and multiple audio tracks
By akkers in forum Video ConversionReplies: 5Last Post: 12th Apr 2023, 04:35 -
Download video with multiple audio tracks using yt-dlp
By Pavel_47 in forum Video Streaming DownloadingReplies: 12Last Post: 3rd Apr 2023, 07:25 -
Getting rid of multiple audio tracks, etc.
By Ethaliano in forum Video ConversionReplies: 2Last Post: 25th Jun 2021, 08:49 -
Identifying Video with Multiple Audio Tracks
By bigcarp22 in forum Newbie / General discussionsReplies: 2Last Post: 27th Aug 2020, 05:02
