  1. Although I used to take my video camera everywhere, I find on many occasions I just have my phone (Galaxy S21)
    The video clips are then set to default as H.264 High L4.0 1080x1920 29.97fps
    Looking for some help on 2 questions.
    #1 Is there a better video setting to use on the phone, eg should I use HDR10+ HEVC
    #2 Is there a basic LUTs file I should use with the Samsung S21, no special effects - just to help optimize output
  2. I would use the 4K setting as that is a better resolution if your editor can handle it.
    Extraordinary claims require extraordinary evidence -Carl Sagan
  3. Originally Posted by TreeTops View Post
    OK ... not used UHD video mode .... I'll give it a try.
    Media Info tells me with UHD it is:
    General
    Complete nam : C:\Users\rick_\Desktop\20250804_170904.mp4
    Format : MPEG-4
    Format profil : Base Media / Version 2
    Codec ID : mp42 (isom/mp42)
    File size : 85.5 MiB
    Duration : 9 s 943 ms
    Overall bit rate : 72.1 Mb/s
    Frame rate : 59.940 FPS
    Encoded date : 2025-08-04 16:09:15 UTC
    Tagged date : 2025-08-04 16:09:15 UTC
    Recorded location : 51.6285°N 3.8601°W
    Writing operating system : Google Android 13
    Writing hardware : Samsung Galaxy S21 FE 5G (SM-G990U)
    Video
    Format : AVC
    Format profile : High@L5.2
    Format settings : CABAC / 1 Ref Frames
    Format settings, CAB : Yes
    Format settings, Reference frames : 1 frame
    Format settings, GOP : M=1, N=60
    Codec ID : avc1
    Source duration : 9 s 940 ms
    Bit rate : 71.9 Mb/s
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Rotation : 90°
    Frame rate mode : Variable
    Frame rate : 59.940 (59940/1000) FPS
    Minimum frame rate : 56.356 FPS
    Maximum frame rate : 64.888 FPS
    Real frame rate : 60.000 FPS
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.145
    Stream size : 85.2 MiB (100%)
    Source stream size : 85.2 MiB (100%)
    Title : VideoHandle
    Language : English
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    mdhd_Duration : 9943
    Codec configuration box : avcC
    Aug 2018
    Wrocław
    The best thing is increase frame rate from 29.97 to 59.54 (60fps).
