Hello.
Gold plated S Video cable is expensive, but would it have any better effect on VHS capture image generated with it or is it simply a myth?
I want to buy it, I only have common Svideos cables.
[Attachment 87994 - Click to enlarge]
Results 1 to 9 of 9
What really matters are individual screens for the Y and C wire to prevent Y<->C signal crosstalk plus an overall screen to protect against external electromagnetic interference.
Gold plating is well known technology for protecting against corrosion (usually due oxidation in harsh environment + some other types of corrosion) - it is commonly used in various connectors (like those in computers etc). Having gold plated connectors is fine however you need to be sure that all connectors (i.e. socket / receptacle and plug) are gold plated - if for example you socket is tin plated and your plug gold plated then gold will be quickly damaged (it will dissolve) in tin layer. Also gold layer is very thin (usually it is so thin that light can pass trough such layer), also frequently gold layer is faked by using instead gold thin layer of for example https://en.wikipedia.org/wiki/Titanium_aluminium_nitride?useskin=vector - it is common way to create appearance of gold without using gold.
I see. It's good to have this cable for other extra protection and anti-interference factors, right? But it doesn't do anything for generating any extra video quality.
Having seen your other videos it is not a matter of the cable to improve your case.
https://forum.videohelp.com/threads/418772-Need-VCRs-with-video-stabilizers -
I had bought some that looked like the ones in the picture off of eBay and they were thin and really didn’t work well. I have blue jean Svideo cables also and they are over shielded and heavy. They pull down on my Svideo ports. They don’t seem to be too grippy. Everything seems grippier when it is plugged into my TBC 3000. The ports are kinda tight compared to a 1980. That part depends on your gear. I have a Panasonic Svideo cables that I got for 2 dollars from a thrift store that I have thought about switching it out with my Blue Jean cable. Just buying some short thick non monster cables from a thrift store is a good idea in my opinion. I say non monster because I have heard they are too grippy but I’m not sure I’ve never owned any.
ION VCR 2 PC USB vs DVHS SUPER VIDEO.
By Litaiff in forum Capturing and VCRReplies: 9Last Post: 1st Jun 2025, 08:30 -
VCR only outputting image via S-Video cable on SVHS recorded cassettes
By phaenius in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2025, 14:20 -
Best Ai scaler to clean up and upscale video,s that isnt super expensive?
By leo5150 in forum RestorationReplies: 3Last Post: 3rd Jan 2025, 01:03 -
HDMI to S-Video cable or SCART to S-Video cable.Which is better for elgato?
By VideoFanatic in forum Capturing and VCRReplies: 22Last Post: 23rd Jan 2023, 14:40 -
HOW TO DOWNLOAD MYTV SUPER video?
By aad55699 in forum Video Streaming DownloadingReplies: 19Last Post: 11th Nov 2022, 21:22
