I just downloaded your avi from #125 post,
as Sharc mentioned somewhere above,
before encoding I definitely would do some crop to 704x480, (left 12 pixels, right 4 pixels, before using QTGMC) and then while encoding H.264 ( not intermediate prores) use SAR 10/11. If not using SAR for H.264, you should resize to 4:3 dimensions.
Results 151 to 157 of 157
I see that. I've been so concerned about the rest of it. Thanks. Where in my code would you put it or?
Is there anything else I should add before batching all my videos?
Thanks!Last edited by Riker0007; 7th Sep 2025 at 10:24.
I'm the dude who writes scripts
for tuning up captures, you have local gurus available, that mostly already gave you hints,
also I use vapoursynth, do not have qtgmc set up for avisynth , avisource gave me Error of not having ULY2 decompresor to try if it captures yuv422P8, if it captures 29.97 etc. So I had to use vapoursynth and BestSource loading plugin to make sure it does, it is available for avisynth as well. So this is a tested vapoursynth script:
so you might use your avisource if it captures 29.97fps and into YUV422P8, also put crop line before qtgmc, and also mask a black on the bottom to get rid of those bottom flickering lines (but mask it, do not crop it, that screws up aspect ratio),Code:from vapoursynth import core import havsfunc video_input = "jvc w pass tbc off.avi" video = core.bs.VideoSource(video_input) audio = core.bs.AudioSource(video_input) #adding clip props (for later potential format changes) video = video.std.SetFrameProps(_FieldBased=2, _Matrix=6, _Transfer=6, _Primaries=6) #intval=1 for bff , 2 for tff, 0 for frame based #cropping black captured borders (16 total) to get proper aspect ratio later video = video.std.Crop(left=12, right=4) #placing 6pixel black strip at the bottom video = video.std.Crop(bottom=6) video = video.std.AddBorders(bottom=6) #deinterlace video = havsfunc.QTGMC(video, Preset='Slower', TFF=True) #potential YUV420P8 output #video = core.resize.Point(clip=video, format=vs.YUV420P8) video.set_output(0) audio.set_output(1)
perhaps this in avisynth:
that is besides fixing image a bit, like those bleeding colors (visible especialy on those railings) or perhaps some noise (CCD?), that be worthy to look atCode:#https://github.com/vapoursynth/bestsource/releases BSVideoSource("%~1") # or just use avisource if it captures in 422 AssumeTFF() #cropping left and right captured strips to have correct aspect ratio later Crop(12, 0, -4, 0) #left, top, right, bottom (in avisynth you cannot write key arguments!) #adding a black mask at the bottom Crop(0, 0, 0, -6) AddBorders(0, 0, 0, 6) #deinterlace QTGMC(Preset="Slower") AudioDub(last, BSAudioSource("%~1")) -
Just tried LWLibavVideoSource source plugin for your "jvc w pass tbc off.avi" , it loaded 422 video, but FPS: 29958/1001fps, not 30000/1001fps (as BestSource). For the length of video, all frames were matching with BestSource (maybe video was not long enough) , so maybe it is just ok to use LWLibavVideoSource("jvc w pass tbc off.avi") and add AssumeFPS(30000,1001), to get 29.97fps, not sure.
or use LWLibavVideoSource("jvc w pass tbc off.avi", fpsnum=30000, fpsden=1001) , but then frames were not matching with BestSource though, BestSource gave 1430frames and LWLibavVideoSource 1432.
Actually, I take back that last sentence, that fpsnum, fpsden did not work at all, video frames go back and forthLast edited by _Al_; 7th Sep 2025 at 21:19.
Im not using it, just wanted to make one sample work for someone else. No big deal. Best Source should be the best anyway, it says so.
In my understanding when you specify fpsnum and fpsden in LWLibavVideoSource it will convert vfr to cfr by duplicating or dropping frames to achieve the target framerate. For short clips and snippets it may get fooled by the inaccurate average framerate estimation or by few (initial) frames with timestamps which are off the kilter, simulating a variable framerate which it then converts to cfr by dropping or duplicating frames.
Without fps specification it returns 715 interlaced frames for the 'jvc w pass tbc off.avi', with fps specification 716 interlaced frames. The difference seems to happen with the first frame of the clip where the fps specified variant introduces a repeat of frame 0.Last edited by Sharc; 8th Sep 2025 at 04:29. Reason: clarifications added
Is it worth upscaling video?
By sophisticles in forum Video ConversionReplies: 15Last Post: 30th Apr 2024, 10:51 -
Is an eGPU worth it to speed up encoding?
By mfmto in forum Newbie / General discussionsReplies: 6Last Post: 2nd May 2023, 13:36 -
Are more expensive AV cables worth it?
By bigbadben in forum Newbie / General discussionsReplies: 8Last Post: 1st Nov 2021, 10:06 -
Is it worth upgrading?
By sophisticles in forum Newbie / General discussionsReplies: 0Last Post: 24th May 2021, 17:24 -
How Merge 1 Video to 100 Videos (Intro + Multiple Main Videos) help
By Squid Ward in forum EditingReplies: 0Last Post: 4th Sep 2020, 11:27
