Results 1 to 11 of 11
    Dec 2010
    quebec
    The whites are brown to orange , i don't know if it's burned in or anyway to correct this
    and if possiblei want to stay in 422 as long as possible
    so far i'm working with that script :
    FFVideoSource("H:\1\Sportheque\GUY.09.01.mkv",colo rspace="YUY2")
    # current resolution: 712x576
    # cropping
    Crop(4,0,-4,-96)# 704x480
    # deinterlacing
    ConvertToYV16(interlaced=true)
    AssumeTFF().ReduceFlicker()
    QTGMC(Preset="Fast", NoiseDeint="Generate", ediThreads=2)
    # color modifications
    SmoothLevels(input_low=11,input_high=255,Ecurve=0, HQ=true)
    SmoothTweak(hue1=3, hue2=0, brightness=0, saturation=0.8,HQ=true,TVrange=True, Limiter=False)
    #Histogram("Levels")
    #Histogram("Color2")
    # reducing kinescope moire
    DeStripe(rad=2,offset=0,thr=1)
    # scaling to 960x720
    nnedi3_rpow2(rfactor=2,cshift="Spline36Resize",fwi dth=960,fheight=720)
    PreFetch(4)
    # setting output fps to 59.940fps
    AssumeFPS(60000,1001)
    ConvertBits(8)
    and the mediainfo gives this:
    General
    Unique ID : 32971893598388217430140786845060223731 (0x18CE27DD4B44047ED48F9CDDD474D2F3)
    Complete name : H:\1\Sportheque\GUY.09.01.mkv
    Format : Matroska
    Format version : Version 4
    File size : 22.0 GiB
    Duration : 34 min 6 s
    Overall bit rate : 92.3 Mb/s
    Frame rate : 29.970 FPS
    Writing application : Lavf58.76.100
    Writing library : Lavf58.76.100
    ErrorDetectionType : Per level 1
    Video
    Format : HuffYUV
    Format version : Version 2
    Codec ID : V_MS/VFW/FOURCC / HFYU
    Bit rate : 88.9 Mb/s
    Width : 712 pixels
    Height : 576 pixels
    Display aspect ratio : 5:4
    Frame rate mode : Constant
    Frame rate : 29.970 (29970/1000) FPS
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 7.235
    Stream size : 21.2 GiB (96%)
    Default : Yes
    Forced : No
    Audio
    Format : PCM
    Format settings : Little / Signed
    Codec ID : A_PCM/INT/LIT
    Bit rate mode : Constant
    Bit rate : 1 536 kb/s
    Channel(s) : 2 channels
    Sampling rate : 48.0 kHz
    Bit depth : 16 bits
    Stream size : 375 MiB (2%)
    Default : Yes
    Forced : No
    ReportBy : MediaInfoLib - v25.04
    I don't know why it was captured that way , more than 10 years ago , the tape is now long gone
    captured with a JVC 5800 and a datavideo TBC-1000 and a old ATI capture card that i can't recall
  2. Maybe try:
    a. Levels to scale the colors to 16-235
    b. use Tweak to lower the saturation (maybe to 0.8)
    b. apply GrayWorld https://github.com/Asd-g/AviSynthPlus-grayworld
    Dec 2010
    quebec
    i'm on windows 7 and .. does grayworld available in hybrid ?
    ConvertToRGB32() is not enough needs planar format , how do i do that
    added
    ConvertToRGB32()
    PackedToPlanar()
    grayworld()
    and still throw same error needs RGB32 planar reverses it and said that input is already in planar format
    PackedToPlanar()
    ConvertToRGB32()
    grayworld()
  4. Hybrid does support Grayworld through Vapoursynth, not Avisynth. (but current versions will not work on Windows 7)
    In Avisynth you probably should use: ConvertToPlanarRGB
    you could also use https://github.com/Dogway/Avisynth-Scripts/blob/master/GradePack.avsi => GreyWorld
    Dec 2010
    quebec
    Well i found Grayworld inside kdenlive , turns the reds into green .. and i will look into GradePack and see where it goes
  6. Color correction is usually best achieved using an NLE because most of them have sophisticated color correction tools, and you can do the corrections interactively.
    You might consider using some sort of audio restoration on the horribly clipped audio.
    Dec 2010
    quebec
    For NLE i only have , Shotcut , Kdenlive and vegas movie studio ( no scopes, but will be using it for stabilisation) and the audio was clipped at the microphone level
    Mar 2008
    Here's an example, done competely in Virtualdub2
    May 2005
    Australia-PAL Land
    That's good, Dave, what was your secret sauce? I used the Camcorder Colour Denoiser and 6-Axis Colour Corrector.
    Mar 2008
    Hi Alwyn, they're almost the same. I reduced saturation a little and employed the temporal smoother as a last step
    Dec 2010
    quebec
    When going YUY2 to YV16 and back to YUY2 ... am i missing anything ?
