  1. I just got the Polariod iD995 V2. 4. k Camcorder.
    It comes with a 32 GB Micro SD Card.
    I have a 256 GB High Capacity Micro SD Card.
    I called them and asked what the Max Memory Size this Camcorder can take?
    They told me it can take up to 128 GB now more.
    They told me if I try to use anything Higher then a 128 GB Micro SD Card the Camcorder will Freeze.
    Is this true with this Camcorder?
  2. The information provided by the manufacturer is accurate. The Polaroid iD995 V2.4K Camcorder is designed to work with microSD cards up to 128GB. Using a higher capacity card, such as your 256GB card, may cause the camcorder to freeze or malfunction.
    To resolve this issue, you may try:
    - Formating the 256GB Card: Some users have reported success by formatting the 256GB card into 2 smaller partition sizes, like 128GB each, but this is not guaranteed to work and may still cause issues.
    However, It's generally recommended to use a card within the manufacturer's specified limits.
  3. I had to return that Camcorder because the Phone Support was very bad.
    I needed help or how to Set the Date and Time and they can help me get into the Settings but not how to go from Setting the Date then moving to the Day then moving the the Year.
    They did not know about the Camcorder at all.
    They would put me on Hold to check some things and come back and still can not help.
    I did find this Camcorder on Amazon and every video on YouTube talks good about it.
    Can you tell me if this would be a good Buy?
    https://www.amazon.com/Camcorder-Recorder-Vlogging-Microphone-Stabilizer/dp/B093GXP1JF...v%2C85&sr=1-16
    canada
    I read about it and found a section where it was returned quite often.
