I need some help with this two, I have both and they are both in same condition and really great VCR's, but I plan to get rid of one. Which one should I keep and which to let go
Forgot to mention they are both EU version.
The one that works better. The conditions are more important than the specifications at beginning of live.
Clean and restore the VCRs at their best, play some tape (from pristine to some having troubles), compare the video and the audio with a TV/Monitor and a (nice) capture card and judge yourself. -
They are both serviced, cleaned and everything that needs to be replace is replaced. Both fully recaps Main's and REG section.
You are right I'll capture some tapes with both and decide with that.
Thanks!Last edited by Thermaltake; 20th Jul 2025 at 07:26.
Depends what your future planned use of the VCR is. If you have still many tapes to be captured I would keep both. You never know when one fails or deteriorates, and decent VCR with TBC are not so easy to find, and there is always a risk with what you will get.
Is there any way to see how much head is worn or something ? I remember back in the days that there were some key comb. on remote to see that info.
JVC HR-S9400 Adjustments?
By JCBone in forum MediaReplies: 1Last Post: 6th Mar 2024, 10:35 -
JVC HR-S7960 vs JVC HR-S7711
By Idan1822 in forum Capturing and VCRReplies: 2Last Post: 23rd Aug 2023, 08:31 -
Does JVC HR-J825MS have a TBC?
By Hunk91 in forum Capturing and VCRReplies: 2Last Post: 19th Dec 2021, 10:12 -
D-Vhs JVC.
By Caius in forum Capturing and VCRReplies: 5Last Post: 5th Dec 2021, 02:28 -
VCR Comparison: JVC SR-W5U vs JVC SR-V101US
By robjv1 in forum RestorationReplies: 18Last Post: 22nd Apr 2021, 04:36
