Page 6 of 19
FirstFirst ... 4 5 6 7 8 16 ... LastLast
Results 151 to 180 of 552
    Aug 2025
    I'm getting this.
                       v 3.3.3 Copyright © 2019-2025 rlaphoenix
                                  v 1.4.1 - unshackle
         Service Config loaded
         Loaded Widevine CDM: 4464 (L3)
         Loaded 1/1 Vaults
         Loaded NordVPN: 126 Countries (8095 Servers)
      ───────────────────────────── Service: SVTPLAY ─────────────────────────────
         Service has no Geofence
      ───────────────────────────── Movies: Unknown ──────────────────────────────
         1 Movie
      ───────────────────────────────── Unknown ──────────────────────────────────
         1 Video
         └── [H.264, SDR] | sv | 1920x1080 @ 5817 kb/s, 25.000 FPS
         2 Audio
         ├── [AAC] | sv | 2.0 | 199 kb/s
         └── [AAC] | sv | 2.0 | 199 kb/s
         ❌ Download Failed...
            An unexpected error occurred in one of the download workers.
            See the error trace above for more information.
  2. 2nd Army Bridgeburners. WhiskeyJack's Avatar
    Aug 2024
    Torshavn
    Originally Posted by Roddan View Post
    I'm getting this.
                                  v 1.4.1 - unshackle
         Loaded 1/1 Vaults
         1 Movie
         1 Video
         2 Audio
    That's great.
    Loads to work with here..........
    POst your service files here or where someone can look at them and see what kinda mess AI guided you towards.
    Aug 2025
    I'm getting this.
                                  v 1.4.1 - unshackle
         Loaded 1/1 Vaults
         1 Movie
         1 Video
         2 Audio
    That's great.
    Will do
    I tried with debug but nothing appeared.
    Service: https://pastebin.com/6WJ9nix4
    Config: https://pastebin.com/uVhaF8vu
  4. Originally Posted by mickmars View Post
    Using this command
    uv run unshackle dl ip https://www.bbc.co.uk/iplayer/episode/b01lwbt0/totp2-summertime-special
    I just keep getting this result with anything from the BBC
    TOTP2 2012 S01E00 Summertime Special ───────────────────
    Video WARN : Response status code does not indicate success: 522
    (status
    1 Video
    └── [H.264, SDR] | en | 1920x1080 @ 12000 kb/s, 50.000 FPS
    ⠋ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • FAILED
    3 Audio
    ├── [AAC] | en | 2.0 | 128 kb/s
    │ ⠋ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • Downloaded
    ├── [AAC] | en | 2.0 | 96 kb/s
    └── [AAC] | en | 2.0 | 48 kb/s
    2 Subtitles
    ├── [TTML] | en
    │ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 03:42 • Downloaded
    └── [TTML] | en | SDH
    [N_m3u8DL-RE]: ERROR: Failed
    What I find encouraging is that even though you didn't succeed in getting the full file you ended up getting the subtitle. Have you tried getiplayer? Also if you sign into BBC with your VPN will the video play on the website? This is a VPN issue certainly but sometimes you can still get the video file in some cases beyond Freevine, Devine or Unshackle. You can't get it with WidevineProxy 2 because the BBC video is unecrypted. The VideoDownload Helper can have some success with BBC. I have used getiplayer with some success to get the video file without subtitles from BBC.
    Aug 2025
    I'm getting this.
                                  v 1.4.1 - unshackle
         Loaded 1/1 Vaults
         1 Movie
         1 Video
         2 Audio
    That's great.
    Do you have any ideas?
    Also how do I Authentication with Cookies?
    Nov 2006
    canada
    Using this command
    (status
    1 Video
    3 Audio
    2 Subtitles
    ├── [TTML] | en
    I have absolutely no problems with get_iplayer, devine and watching the BBC iplayer using my Nord subsciption
    Its only with Unshackle that I have this BBC issue
  7. I remember when I had NordVPN that BBC did not work with it; but I never did figure out the proxy stuff and still haven't. I did have Hola Proxy seemingly working on Devine for awhile but I found it overwhelming and it said my IP was blocked temporarily and so I deleted Hola Proxy.
    Windscribe back when I was using Freevine early on for me seemed to be the VPN to get for BBC and ROKU. Now it seems Surf Shark does well for BBC. If Devine works for you with BBC that is terrific. I hope someone helps you get it working in Unshackle.
    Aug 2025
    What does this mean?
    CalledProcessError: Command
    '['input=Temp\\Audio_51af919a.mp4,stream=0,output=Temp\\Audio_51af919a_decrypted
    .mp4,output_format=MP4', '--enable_raw_key_decryption', '--keys',
    'label=0:key_id=KEY HERE:key=KEY HERE
    69c0b,label=1:key_id=00000000000000000000000000000000:key=KEY HERE
    b778e69c0b', '--temp_dir', WindowsPath('Temp')]' returned non-zero exit status
    3221225477.
    Dec 2022
    Lesotho
    Ain't that the truth nowadays.
  10. Hello everyone,
    I used to use freevine on Windows 10/11 but it no longer works for Tubi, so I'm trying to use Unshackle. I have it installed on my PC (running Linux) and I also used "uv run unshackle env check" to check and it seems I have all the required environment dependencies installed. I'm just trying to get some help now with setting up services so I can start ripping videos from Tubi again, if anyone can help me please message me I would really appreciate the help.
    Thank you for reading and have a good day.
    Edit: Also I have never used Devine before so I know nothing about setting up services.
  11. Originally Posted by Roddan View Post
    3221225477.
    Let's unpack it. - it seems to be taking input for audio and video streams and it mentions raw_key_decryptor - That suggests it's the decryption module returning a non-zero exit status number.. When programs terminate they may signal all is well by sending 0. So clearly, all is not well.
    The default decryptor for unshackle is shaka-packager: it could you haven't renamed it to just packager and its still got win or x64 in the name.
    Here is a python script called where_is.py
    PHP Code:
    ## find files
    ## use: py where_is.py aria2c mp4decrypt packager [url=https://www.videohelp.com/software/MKVToolNix]mkvmerge[/url]
    import shutil
    import sys
    for i in range(1,len(sys.argv)):
    binary sys.argv[i]
    executable shutil.which(binary)
        if
    not executable:
            print(
    f"{binary} executable not found...")
        else:
            print(
    executable
    copy that and name it as where_is.py. Then in the same folder run
    python3 where_is.py   aria2c mp4decrypt packager mkvmerge ffmpeg
    It will tell you if it cannot find packager. There are other ways I know and if you know too then use those.
    If your packager is correctly named then it has issue with the service. I found one in my service pack that had such an issue, ( can't remember which - might have been ARD) and set the decryptor to be mp4decrypt in the unshackle.yaml.
    decryptor:  mp4decrypt
    on a line of its own tight against the left edge.
    Whilst I'm talking services - ARD needs uv pip install isodate and uv pip install webvtt-py Annoyingly unshackle correctly throws an error on its initial parse of all the code if those are not installed for anyone using my service pack
    I've got NRK working for single episodes and movies for any Norwegian on the forum. Its not in the current release.
    Aug 2025
    3221225477.
    PHP Code:
    ## find files
    import shutil
    import sys
    binary sys.argv[i]
        if
    not executable:
            print(
        else:
            print(
    executable
    Yes it was named packager-win-x64. I renamed it to packager and receiving this now.
    .\aria2c.EXE
    .\mp4decrypt.EXE
    .\packager.EXE
    .\mkvmerge.EXE
    .\ffmpeg.EXE
    '['input=Temp\\Audio_1ae7ac59.mp4,stream=0,output=Temp\\Audio_1ae7ac59_decrypted
    'label=0:key_id=KEY_HERE:key=KEY_HERE
    69c0b,label=1:key_id=00000000000000000000000000000000:key=KEY_HERE
    3221225477.
    Seems to do the trick. Only now that it's network issue towards the service I think.
    Trying with CBS.
         [Aria2c]: Download Error (#33492bff3bd099d4): Network problem has
                   occurred. cause:A socket operation was attempted to an
                   unreachable network.   (1), https://vod-gcs-cedexis.cbsaavid
                   eo.com/intl_vms/2024/02/02/2305756227681/2570081_cenc_fmp4_h
                   dr_dash/en-US.vtt
            Download Error (#33492bff3bd099d4): Network problem has occurred.
         cause:A socket operation was attempted to an unreachable network.
          (1),
         https://vod-gcs-cedexis.cbsaavideo.com/intl_vms/2024/02/02/23057562276
         81/2570081_cenc_fmp4_hdr_dash/en-US.vtt
  13. Originally Posted by luigi700 View Post
    Hello everyone,
    There is a zip file that was posted in this thread with services in the event they didn't come with your installing Unshackle. If that folder exists and the services are in it and .yaml is pointing Unshackle towards them you should be able to use the right written arguements to get some videos from TUBI. I am remembering that stabbedbybrick had it set in Devine that TUBI liked aria2c as the downloader.
    To test TUBI in Unshackle type:
    uv run unshackle dl --list-titles TUBI "url for a TUBI TV series" without the quotation marks
    See if that gives you a list of the episodes of that TV series.
    Then type:
    uv run unshackle dl --list -w S01E01 TUBI url
    This should give you a read out of the available quality of video, audio, subtitle and chapter files for the specific episode. If you are not trying to conserve hard drive space and have the time for larger files then don't worry about the quality and just type
    uv run unshackle dl -w S01 TUBI url
    -w is the range if you want the entire series you don't need to use the -w; as the default without the -w is that Unshackle will download the entire series and if you are not concerned about the quality and are happy with the best possible quality you don't need the -q either so it would be
    uv run unshackle dl TUBI url
    I hope this helps and it makes me feel good to help others as I am usually asking for help quite a lot of the time and thankfully getting advice.
  14. I hope that when it comes to the Pluto service that going forward that those who work on fixing it if the need arises that it is remembered that Pluto tends to have lyp sinc issues and that stabbedbybrick had a remedy for that in his code. You don't want to end up with lypc sync issues in your downloads.
    Another thing to remember is shows from the 1950s through into the early 1980s that in a lot of cases the episodes per hour were 50 minutes of show and ten minutes of commercial. So if a classic hour show is showing that it is less time than it should be around that it may very well be an edited episode to fit more commercials in; so the question is do you take the time archiving an edited episode? I also launched a thread in video stream downloading as I noticed that in some instances it seems that episodes are being sped up with the video and audio being slightly faster as a way to fit more commercials in. Now this is not the fault of the downloading programs it is just a question is it worth the effort to archive such episodes. I noticed a speed up on Channel 4's Good Doctor episode 1 and on Person of Interest episodes on either an Australian or New Zealand streaming service. You notice that characters are speaking a bit faster than is usual.
    Aug 2025
    Still some issues. Also with ITV after renaming shaka packager to packager.
    ╭───────────────────── Traceback (most recent call last) ──────────────────────╮
    │ D:\unshackle\unshackle\commands\dl.py:889 in result                          │
    │    886 │   │   │   │   │   │   │   │   for i, track in enumerate(title.track │
    │    887 │   │   │   │   │   │   │   )                                         │
    │    888 │   │   │   │   │   │   ):                                            │
    │ ❱  889 │   │   │   │   │   │   │   download.result()                         │
    │    890 │   │   │   except KeyboardInterrupt:                                 │
    │    891 │   │   │   │   console.print(Padding(":x: Download Cancelled...", (0 │
    │    892 │   │   │   │   return                                                │
    │ C:\Users\Roddan\AppData\Roaming\uv\python\cpython-3.12.11-windows-x86_64-non │
    │ e\Lib\concurrent\futures\_base.py:449 in result                              │
    │   446 │   │   │   │   if self._state in [CANCELLED, CANCELLED_AND_NOTIFIED]: │
    │   447 │   │   │   │   │   raise CancelledError()                             │
    │   448 │   │   │   │   elif self._state == FINISHED:                          │
    │ ❱ 449 │   │   │   │   │   return self.__get_result()                         │
    │   450 │   │   │   │                                                          │
    │   451 │   │   │   │   self._condition.wait(timeout)                          │
    │   452        │
    │ e\Lib\concurrent\futures\_base.py:401 in __get_result                        │
    │   398 │   def __get_result(self):                                            │
    │   399 │   │   if self._exception:                                            │
    │   400 │   │   │   try:                                                       │
    │ ❱ 401 │   │   │   │   raise self._exception                                  │
    │   402 │   │   │   finally:                                                   │
    │   403 │   │   │   │   # Break a reference cycle with the exception in self._ │
    │   404 │   │   │   │   self = None                                            │
    │ e\Lib\concurrent\futures\thread.py:59 in run                                 │
    │    56 │   │   │   return                                                     │
    │    57 │   │        │
    │    58 │   │   try:                                                           │
    │ ❱  59 │   │   │   result = self.fn(*self.args, **self.kwargs)                │
    │    60 │   │   except BaseException as exc:                                   │
    │    61 │   │   │   self.future.set_exception(exc)                             │
    │    62 │   │   │   # Break a reference cycle with the exception 'exc'         │
    │ D:\unshackle\unshackle\core\tracks\track.py:248 in download                  │
    │   245 │   │   │   │   │   cdm=cdm,                                           │
    │   246 │   │   │   │   )                                                      │
    │   247 │   │   │   elif self.descriptor == self.Descriptor.DASH:              │
    │ ❱ 248 │   │   │   │   DASH.download_track(                                   │
    │   249 │   │   │   │   │   track=self,                                        │
    │   250 │   │   │   │   │   save_path=save_path,                               │
    │   251 │   │   │   │   │   save_dir=save_dir,                                 │
    │ D:\unshackle\unshackle\core\manifests\dash.py:559 in download_track          │
    │   556 │   │        │
    │   557 │   │   if drm:                                                        │
    │   558 │   │   │   progress(downloaded="Decrypting", completed=0, total=100)  │
    │ ❱ 559 │   │   │   drm.decrypt(save_path)                                     │
    │   560 │   │   │   track.drm = None                                           │
    │   561 │   │   │   events.emit(events.Types.TRACK_DECRYPTED, track=track, drm │
    │   562 │   │   │   progress(downloaded="Decrypting", advance=100)             │
    │ D:\unshackle\unshackle\core\drm\widevine.py:250 in decrypt                   │
    │   247 │   │   if use_mp4decrypt:                                             │
    │   248 │   │   │   return self._decrypt_with_mp4decrypt(path)                 │
    │   249 │   │   else:                                                          │
    │ ❱ 250 │   │   │   return self._decrypt_with_shaka_packager(path)             │
    │   251 │        │
    │   252 │   def _decrypt_with_mp4decrypt(self, path: Path) -> None:            │
    │   253 │   │   """Decrypt using mp4decrypt"""                                 │
    │ D:\unshackle\unshackle\core\drm\widevine.py:357 in                           │
    │ _decrypt_with_shaka_packager                                                 │
    │   354 │   │   │   p.wait()                                                   │
    │   355 │   │   │                                                              │
    │   356 │   │   │   if p.returncode != 0 or had_error:                         │
    │ ❱ 357 │   │   │   │   raise subprocess.CalledProcessError(p.returncode, argu │
    │   358 │   │   │                                                              │
    │   359 │   │   │   path.unlink()                                              │
    │   360 │   │   │   if not stream_skipped:                                     │
    '['input=Temp\\Audio_f9bc085b.mp4,stream=0,output=Temp\\Audio_f9bc085b_decrypted
    'label=0:key_id=KEY:key=KEY
    dbe23,label=1:key_id=00000000000000000000000000000000:key=KEY
    c2eb2dbe23', '--temp_dir', WindowsPath('Temp')]' returned non-zero exit status
    3221225477.
            Binary call failed, Process exit code: 3221225477
  16. Did you rename it to:
    packager-win-x64
    Make sure you put your required tools into the binaries folder.
    Aug 2025
    packager-win-x64
    Yep. Looks like this
    https://postimg.cc/p9JpBV7h
    https://postimg.cc/xXYkNbpD
  18. Originally Posted by Roddan View Post
    packager-win-x64
    If you're using unshackle v1.2 and later the packager binary needs to be renamed to shaka-packager.exe
    Aug 2025
    packager-win-x64
    I pulled it today. Now I got somewhat futher.
    Re-installed everything 10 min ago.
    '[WindowsPath('C:/unshackle/unshackle/binaries/SubtitleEdit.exe'), '/Convert',
    WindowsPath('Temp/Subtitle_02d3fc.vtt'), 'SubRip',
    '/outputfilename:Subtitle_02d3fc.srt', '/encoding:utf8',
    '/ConvertColorsToDialog']' returned non-zero exit status 3762504530.
  20. Originally Posted by Roddan View Post
    packager-win-x64
    remove SubtitleEdit from your binaries directory and try again
    You may have to add the following to your unshackle.yaml file:
    # conversion_method:
    # - auto (default): Smart routing - subby for WebVTT/SAMI, standard for others
    # - subby: Always use subby with advanced processing
    # - pycaption: Use only pycaption library (no SubtitleEdit, no subby)
    # - subtitleedit: Prefer SubtitleEdit when available, fall back to pycaption
    subtitle:
      conversion_method: auto
      sdh_method: auto
  21. Originally Posted by PunchDrunkL0ve View Post
    packager-win-x64
    I am using version 1.4 and didn't know that. It seems to be working with my current name for it but I will probably rename it just in case. If it causes a problem I will change it back. I apologize if I was wrong in my post.
  22. Originally Posted by Tom Saurus View Post
    Hello everyone,
    Then type:
    Okay so I've downloaded the services zip and I only added the Tubi and Pluto services in my folder so far, the TV series I tried was Garfield & Friends, and that was actually downloading, but it also says no Widevine PSSH was found, so I'm guessing it was DRM-free. This command worked perfectly "uv run unshackle dl -w S01 TUBI https://tubitv.com/series/300004999/garfield-and-friends", but this one "uv run unshackle dl TUBI https://tubitv.com/movies/516366/invasion-u-s-a" didn't work, it gave me an error. Where am I supposed to put my wvd file, I'm guessing that's what i need for decryption of the DRM protected stuff, right? I attached an output of my terminal so you can see the error.
  23. Originally Posted by Tom Saurus View Post
    packager-win-x64
    https://github.com/unshackle-dl/unshackle/commit/05ef84128200ffcd9066d4de56f880650cb9eb06
  24. Member
    Aug 2025
    packager-win-x64
    subtitle:
      sdh_method: auto
    Thanks! Will try once I get home.
  25. Originally Posted by PunchDrunkL0ve View Post
    packager-win-x64
    Thank you for the clarification. I have now renamed it.
  26. Member
    Feb 2022
    Search the forum first!
    ..., but this one "uv run unshackle dl TUBI https://tubitv.com/movies/516366/invasion-u-s-a" didn't work, it gave me an error. Where am I supposed to put my wvd file, I'm guessing that's what i need for decryption of the DRM protected stuff, right? I attached an output of my terminal so you can see the error.
    uv run unshackle dl -l en TUBI https://tubitv.com/movies/516366/invasion-usa
    Noob Starter Pack. Just download every Widevine mpd! Not kidding!.
  27. Originally Posted by luigi700 View Post
    Hello everyone,
    Then type:
    There is a folder in Unshackle named WVD. This is where you can place your .wvd file. You can get a .wvd here in this thread:
    https://forum.videohelp.com/threads/413719-Ready-to-use-CDMs-available-here%21
    Then it is matter once you have your .wvd file to point to it in your .yaml file What I usually do is go to the .wvd and right click and select "copy as path" and then go to the .yaml file and input it in the correct place. But what I did with Unshackle someone earlier in the thread posted a .zip file saying her is "Unshackle" already for you. It came with a .wvd and a .yaml configured already that I had to adapt to where I had my services and the list goes on.
    I notice in your text file a line with what looks like a Key next to Widevine. I am going to step back as I don't have the knowledge to figure out this error. I did a list test for "Invasion U.S.A." which indicated TUBI has the file for me to get via Unshackle. My Sister is doing a Zoom Meeting right now and so I am not going to do any downloading until she wraps up her meetings as it would slow down her Video and such.
  28. Member
    Aug 2025
    packager-win-x64
    subtitle:
      sdh_method: auto
    Mine is set to auto. I'll try remove SubtitleEdit and see if it works, also did my Binaries folder look correct?
    subtitle:
      sdh_method: auto
    Edit: It worked when I removed SubtitleEdit !
  29. Originally Posted by Roddan View Post
    packager-win-x64
    subtitle:
      sdh_method: auto
    subtitle:
      sdh_method: auto
  30. Unshackle is working well for me. The naming upgrade though is just giving me the usual naming with the words user tag tacked on the end. Obviously I made an error somewhere but I can live with it. Compared with how long it took me to get Devine up and running Unshackle has been remarkable in getting it up and running much quicker.
