You can find instructions in the DSCP script on how to convert. It's very easy, you basically just have to replace a few words.
As for CBS, the incomplete videos is mostly an Unshackle issue. You can work around it for now by using n_m3u8dl_re as downloader, or pulling the feature branch called "unified-downloader" from the official github repo. The possible downside by doing that is other services might break due to core changes having been made. It's getting pretty hard to keep up with all the updates, so I haven't personally tested anything yet.
Results 811 to 830 of 830
Hi Stabby, thanks for the info, I did follow your instructions to change DSCP to MAX and did have some success but when I used the command to download a series it game me a mix of 720p and 1080p I'll try it again tomorrow and double check I changed all the code correctly.
Cheers Stabby, thanks as always. -
Cheers for the info PSXman, is there a specific command to download a series in 1080p h265 please? I'm about bit rusty on the command for that.
Thanks I appreciate the help. -
Hi. I've a few questions:
- What're hydration tracks on netflix ?
- What are the factors that make it possible to obtain it ?, vice versa.
- Could you give an example of how to obtain it ?, i.e. nf id: 82157128 (vt & unshackle).
I changed my .yaml file to add the line:
# downloader:
# CBS: n_m3u8dl_re
I am not sure Unshackle accepted that. Should I do something in the CBS config file? I got several episodes downloaded file with the full time length and on the newest aired episode it was only ten minutes or so long. Thank you in advance for any guidance.
Code:C:\unshackle>uv run unshackle dl -q 540 -w S02E05 CBS https://www.cbs.com/shows/matlock/ ▄ ▄▌ ▐ ▄ .▄▄ · ▄ .▄ ▄▄▄· ▄▄· ▄ ▄ ▄▄▌ ▄▄▄ . █▪██▌█▌▐█▐█ ▀. ██▪▐█▐█ ▀█ ▐█ ▌▪█▌▄▌▪██ ▀▄.▀· █▌▐█▌▐█▐▐▌▄▀▀▀█▄██▀▐█▄█▀▀█ ██ ▄▄▐▀▀▄·██▪ ▐▀▀▪▄ ▐█▄█▌██▐█▌▐█▄▪▐███▌▐▀▐█ ▪▐▌▐███▌▐█.█▌▐█▌▐▌▐█▄▄▌ ▀▀▀ ▀▀ █▪ ▀▀▀▀ ▀▀▀ · ▀ ▀ ·▀▀▀ ·▀ ▀.▀▀▀ ▀▀▀ v 4.0.0 - © 2025-2026 - github.com/unshackle-dl/unshackle Service Config loaded Loaded 1/1 Vaults Loaded Widevine CDM: 4445 (L3) ─────────────────────────────── Service: CBS ─────────────────────────────── Service is not Geoblocked in your region ───────────────────────────── Series: Matlock ────────────────────────────── 2 seasons, S1(19), S2(11) ───────────────────────── Matlock S02E05 Mousetrap ───────────────────────── Cached 1 Key to 1/1 Vaults 1 Video └── [H.264, SDR] | en-US | 960x540 @ 1588 kb/s, 23.976 FPS ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 04:08 Downloaded 1 Audio └── [DD+] | en-US | 6.0 | 194 kb/s | United States ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 04:04 Downloaded 1 Subtitle └── [WVTT] | en-US | United States ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 02:07 Downloaded 2 Chapters ├── 00:00:00.000 └── 00:42:24.000 | Credits Widevine(AAAAWHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADgIARIQ+C3qqEkHR...) └── f82deaa84907462b865295d8ba170054:5d9c9039e76b1be5bf8767065d1fb323* Track downloads finished in 4m8s Multiplexing... ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 00:02 🎉 Title downloaded in 4m12s! Processed all titles in 4m15s C:\unshackle>uv run unshackle dl -q 720-w S02E06-S02E11 CBS https://www.cbs.com/shows/matlock/ ▄ ▄▌ ▐ ▄ .▄▄ · ▄ .▄ ▄▄▄· ▄▄· ▄ ▄ ▄▄▌ ▄▄▄ . █▪██▌█▌▐█▐█ ▀. ██▪▐█▐█ ▀█ ▐█ ▌▪█▌▄▌▪██ ▀▄.▀· █▌▐█▌▐█▐▐▌▄▀▀▀█▄██▀▐█▄█▀▀█ ██ ▄▄▐▀▀▄·██▪ ▐▀▀▪▄ ▐█▄█▌██▐█▌▐█▄▪▐███▌▐▀▐█ ▪▐▌▐███▌▐█.█▌▐█▌▐▌▐█▄▄▌ ▀▀▀ ▀▀ █▪ ▀▀▀▀ ▀▀▀ · ▀ ▀ ·▀▀▀ ·▀ ▀.▀▀▀ ▀▀▀ v 4.0.0 - © 2025-2026 - github.com/unshackle-dl/unshackle Usage: unshackle dl [OPTIONS] COMMAND [ARGS]... Try 'unshackle dl -?' for help. Error: Invalid value for '-q' / '--quality': '720-w' is not a valid integer C:\unshackle>uv run unshackle dl -q 720 -w S02E06-S02E11 CBS https://www.cbs.com/shows/matlock/ ▄ ▄▌ ▐ ▄ .▄▄ · ▄ .▄ ▄▄▄· ▄▄· ▄ ▄ ▄▄▌ ▄▄▄ . █▪██▌█▌▐█▐█ ▀. ██▪▐█▐█ ▀█ ▐█ ▌▪█▌▄▌▪██ ▀▄.▀· █▌▐█▌▐█▐▐▌▄▀▀▀█▄██▀▐█▄█▀▀█ ██ ▄▄▐▀▀▄·██▪ ▐▀▀▪▄ ▐█▄█▌██▐█▌▐█▄▪▐███▌▐▀▐█ ▪▐▌▐███▌▐█.█▌▐█▌▐▌▐█▄▄▌ ▀▀▀ ▀▀ █▪ ▀▀▀▀ ▀▀▀ · ▀ ▀ ·▀▀▀ ·▀ ▀.▀▀▀ ▀▀▀ v 4.0.0 - © 2025-2026 - github.com/unshackle-dl/unshackle Service Config loaded Loaded 1/1 Vaults Loaded Widevine CDM: 4445 (L3) ─────────────────────────────── Service: CBS ─────────────────────────────── Service is not Geoblocked in your region ───────────────────────────── Series: Matlock ────────────────────────────── 2 seasons, S1(19), S2(11) ────────────────────── Matlock S02E06 Harm Reduction ─────────────────────── Cached 1 Key to 1/1 Vaults 1 Video └── [H.264, SDR] | en-US | 1280x720 @ 3490 kb/s, 23.976 FPS ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 08:20 Downloaded 1 Audio └── [DD+] | en-US | 6.0 | 194 kb/s | United States ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 08:12 Downloaded 1 Subtitle └── [WVTT] | en-US | United States ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 04:30 Downloaded 2 Chapters ├── 00:00:00.000 └── 00:41:45.000 | Credits Widevine(AAAAWHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADgIARIQrtJd8D8WQ...) └── aed25df03f16413597180d1dd2b125d7:76c7089bdd1238f131cc060645cfdcc2* Track downloads finished in 8m20s Multiplexing... ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 00:03 🎉 Title downloaded in 8m25s! ────────────────────── Matlock S02E07 Prior Bad Acts ─────────────────────── Cached 1 Key to 1/1 Vaults 1 Video └── [H.264, SDR] | en-US | 1280x720 @ 2910 kb/s, 23.976 FPS ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 08:17 Downloaded 1 Audio └── [DD+] | en-US | 6.0 | 194 kb/s | United States ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 08:09 Downloaded 1 Subtitle └── [WVTT] | en-US | United States ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 06:00 Downloaded 2 Chapters ├── 00:00:00.000 └── 00:41:55.000 | Credits Widevine(AAAAWHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADgIARIQkz8KnnlZT...) └── 933f0a9e79594c8693c5e654dd6935f9:193b0fa96fa2b1799649f9131015fcf9* Track downloads finished in 8m17s Multiplexing... ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 00:03 🎉 Title downloaded in 8m23s! ───────────────── Matlock S02E08 Call It a Christmas Gift ────────────────── Cached 1 Key to 1/1 Vaults 1 Video └── [H.264, SDR] | en-US | 1280x720 @ 3200 kb/s, 23.976 FPS ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 09:41 Downloaded 1 Audio └── [DD+] | en-US | 6.0 | 194 kb/s | United States ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 09:31 Downloaded 1 Subtitle └── [WVTT] | en-US | United States ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 07:29 Downloaded 2 Chapters ├── 00:00:00.000 └── 00:42:23.000 | Credits Widevine(AAAAWHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADgIARIQlc3t9E3jT...) └── 95cdedf44de34cffa46e26dac9fa89c4:4562b2766bcd25259d0348845d910b6f* Track downloads finished in 9m41s Multiplexing... ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 00:03 🎉 Title downloaded in 9m46s! ──────────────────────── Matlock S02E09 Collateral ───────────────────────── Cached 1 Key to 1/1 Vaults 1 Video └── [H.264, SDR] | en-US | 1280x720 @ 3375 kb/s, 23.976 FPS ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 09:09 Downloaded 1 Audio └── [DD+] | en-US | 6.0 | 194 kb/s | United States ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 09:01 Downloaded 1 Subtitle └── [WVTT] | en-US | United States ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 06:03 Downloaded 2 Chapters ├── 00:00:00.000 └── 00:42:09.000 | Credits Widevine(AAAAWHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADgIARIQL/JHcwUfQ...) └── 2ff24773051f42a8b8dea49473964237:fd4d47b5a09b276101e4c3bb89ee61fd* Track downloads finished in 9m9s Multiplexing... ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 00:03 🎉 Title downloaded in 9m16s! ───────────────────── Matlock S02E10 The Greater Good ────────────────────── Cached 1 Key to 1/1 Vaults 1 Video └── [H.264, SDR] | en-US | 1280x720 @ 3736 kb/s, 23.976 FPS ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 08:40 Downloaded 1 Audio └── [DD+] | en-US | 6.0 | 194 kb/s | United States ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 08:34 Downloaded 1 Subtitle └── [WVTT] | en-US | United States ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 07:33 Downloaded 2 Chapters ├── 00:00:00.000 └── 00:42:20.000 | Credits Widevine(AAAAWHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADgIARIQUjulOwVrQ...) └── 523ba53b056b40e3a01a0ea798b48bcb:c282d918233d9d63e41b891d65d12391* Track downloads finished in 8m40s Multiplexing... ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 00:03 🎉 Title downloaded in 8m45s! ──────────────────────── Matlock S02E11 Tail Lights ──────────────────────── ThePlatform request failed: max() iterable argument is empty, falling back to standard manifest Cached 1 Key to 1/1 Vaults 1 Video └── [H.264, SDR] | en-US | 1280x720 @ 3179 kb/s, 23.976 FPS ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 02:13 Downloaded 1 Audio └── [DD+] | en-US | 6.0 | 194 kb/s | United States ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 02:09 Downloaded 1 Subtitle └── [WVTT] | en-US | United States ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 00:47 Downloaded 2 Chapters ├── 00:00:00.000 └── 00:42:09.000 | Credits Widevine(AAAAWHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADgIARIQDZ/HDRkQS...) └── 0d9fc70d191048a2818b9743ba2f29d6:f1d58ae4799f48ddc0bcce659de8a11e* Track downloads finished in 2m13s Multiplexing... ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 00:01 🎉 Title downloaded in 2m15s! Processed all titles in 47m9s C:\unshackle>Last edited by Tom Saurus; 30th Mar 2026 at 11:09.
I gave it a try and it caused a failure.
[CODE][/C:\unshackle>uv run unshackle dl -q 720 -w S02E11 CBS https://www.cbs.com/shows/matlock/
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "C:\unshackle\.venv\Scripts\unshackle.exe\__main__ .py", line 4, in <module>
File "C:\unshackle\unshackle\core\__main__.py", line 14, in <module>
from unshackle.core.commands import Commands
File "C:\unshackle\unshackle\core\commands.py", line 5, in <module>
from unshackle.core.config import config
File "C:\unshackle\unshackle\core\config.py", line 233, in <module>
config = Config.from_yaml(config_path)
File "C:\unshackle\unshackle\core\config.py", line 205, in from_yaml
return cls(**yaml.safe_load(path.read_text(encoding="utf8 ")) or {})
File "C:\unshackle\.venv\Lib\site-packages\yaml\__init__.py", line 125, in safe_load
return load(stream, SafeLoader)
File "C:\unshackle\.venv\Lib\site-packages\yaml\__init__.py", line 81, in load
return loader.get_single_data()
File "C:\unshackle\.venv\Lib\site-packages\yaml\constructor.py", line 49, in get_single_data
node = self.get_single_node()
File "C:\unshackle\.venv\Lib\site-packages\yaml\composer.py", line 36, in get_single_node
document = self.compose_document()
File "C:\unshackle\.venv\Lib\site-packages\yaml\composer.py", line 55, in compose_document
node = self.compose_node(None, None)
File "C:\unshackle\.venv\Lib\site-packages\yaml\composer.py", line 84, in compose_node
node = self.compose_mapping_node(anchor)
File "C:\unshackle\.venv\Lib\site-packages\yaml\composer.py", line 127, in compose_mapping_node
while not self.check_event(MappingEndEvent):
File "C:\unshackle\.venv\Lib\site-packages\yaml\parser.py", line 98, in check_event
self.current_event = self.state()
File "C:\unshackle\.venv\Lib\site-packages\yaml\parser.py", line 438, in parse_block_mapping_key
raise ParserError("while parsing a block mapping", self.marks[-1],
yaml.parser.ParserError: while parsing a block mapping
in "<unicode string>", line 2, column 1:
set_terminal_bg: false
expected <block end>, but found '<block mapping start>'
in "<unicode string>", line 187, column 3:
CBS: n_m3u8dl_re
C:\unshackle>CODE]
Update I changed it back and it downloaded but it was only ten minutes of video. It seems to be succeeding in Twinvine.
This is what the downloader portion of main .yaml looks like in Unshackle:
# Choose what software to use to download data
downloader: aria2c
# Options: requests | aria2c | curl_impersonate | n_m3u8dl_re
# Can also be a mapping:
# downloader:
# TUBI: n_m3u8dl_re
# PLUTO: n_m3u8dl_re
# TVNZ: n_m3u8dl_re
# CBC: n_m3u8dl_re
# UKTV: n_m3u8dl_re
# CBS: n_m3u8dl_re
# default: aria2c
There are three spaces between the # and the service name.Last edited by Tom Saurus; 31st Mar 2026 at 07:39.
I took a look at my Envied main.yaml and I noticed that when it comes to downloader for data that it had n_m3u8dl_re. Maybe that is why it is getting the CBS videos in their entirety. This using my brain stuff is exhausting but who knows with practice?
So from this your default is aria2c because you have everything else commented out with the "#" as sipho pointed out.
Either uncomment out your CBS, or just change
downloader: aria2c
To
downloader: n_m3u8dl_re
or
#downloader: aria2c
Just remove the "#" each time you need to switch between n_m3u8dl_re or aria2c as your downloader
Code:uv run unshackle dl -q 540 -w S02E05 CBS https://www.cbs.com/shows/matlock/ ▄ ▄▌ ▐ ▄ .▄▄ · ▄ .▄ ▄▄▄· ▄▄· ▄ ▄ ▄▄▌ ▄▄▄ . █▪██▌█▌▐█▐█ ▀. ██▪▐█▐█ ▀█ ▐█ ▌▪█▌▄▌▪██ ▀▄.▀· █▌▐█▌▐█▐▐▌▄▀▀▀█▄██▀▐█▄█▀▀█ ██ ▄▄▐▀▀▄·██▪ ▐▀▀▪▄ ▐█▄█▌██▐█▌▐█▄▪▐███▌▐▀▐█ ▪▐▌▐███▌▐█.█▌▐█▌▐▌▐█▄▄▌ ▀▀▀ ▀▀ █▪ ▀▀▀▀ ▀▀▀ · ▀ ▀ ·▀▀▀ ·▀ ▀.▀▀▀ ▀▀▀ v 4.0.0 - © 2025-2026 - github.com/unshackle-dl/unshackle Service Config loaded Loaded 1/1 Vaults Loaded Widevine CDM: 4464 (L3) Loaded Basic: 3 Countries (3 Servers) ─────────────────────────────── Service: CBS ─────────────────────────────── Service is not Geoblocked in your region ───────────────────────────── Series: Matlock ────────────────────────────── 2 seasons, S1(19), S2(11) ───────────────────────── Matlock S02E05 Mousetrap ───────────────────────── Cached 1 Key to 1/1 Vaults 1 Video └── [H.264, SDR] | en-US | 960x540 @ 1588 kb/s, 23.976 FPS ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 00:07 Downloaded 1 Audio └── [DD+] | en-US | 6.0 | 194 kb/s | United States ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 00:05 Downloaded 1 Subtitle └── [WVTT] | en-US | United States ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 00:10 Downloaded 2 Chapters ├── 00:00:00.000 └── 00:42:24.000 | Credits Widevine(AAAAWHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADgIARIQ+C3qqEkHR...) └── f82deaa84907462b865295d8ba170054:5d9c9039e76b1be5bf8767065d1fb323* Track downloads finished in 0m13s Multiplexing... ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 00:01 🎉 Title downloaded in 0m16s! Processed all titles in 0m16s -
Thank you ehurdler I will give it a try and see how it works.
I tested putting n_m3u8dl_re in after downloader and it seems to have worked.Last edited by Tom Saurus; 1st Apr 2026 at 12:18.
Has anyone have issues downloading some miniseries documentary titles off from CBC Gem?
For example I can't grab Bad Nanny (2-episode miniseries) which CBC only says "Parts" instead of "Episodes", which is why it can't be downloaded plus Bad Nanny seems to be DRM protected (for selected titles only) according to yt-dlp.
I do hope stabbedbybrick would update this.Code:uv run unshackle dl -w s01e01 CBC https://gem.cbc.ca/bad-nanny/s01e01 ▄ ▄▌ ▐ ▄ .▄▄ · ▄ .▄ ▄▄▄· ▄▄· ▄ ▄ ▄▄▌ ▄▄▄ . █▪██▌█▌▐█▐█ ▀. ██▪▐█▐█ ▀█ ▐█ ▌▪█▌▄▌▪██ ▀▄.▀· █▌▐█▌▐█▐▐▌▄▀▀▀█▄██▀▐█▄█▀▀█ ██ ▄▄▐▀▀▄·██▪ ▐▀▀▪▄ ▐█▄█▌██▐█▌▐█▄▪▐███▌▐▀▐█ ▪▐▌▐███▌▐█.█▌▐█▌▐▌▐█▄▄▌ ▀▀▀ ▀▀ █▪ ▀▀▀▀ ▀▀▀ · ▀ ▀ ·▀▀▀ ·▀ ▀.▀▀▀ ▀▀▀ v 4.0.0 - © 2025-2026 - github.com/unshackle-dl/unshackle Service Config loaded Loaded 0/0 Vaults Loaded Widevine CDM: 22589 (L3) ─────────────────────────────── Service: CBC ─────────────────────────────── Service is not Geoblocked in your region + Using cached tokens Authenticated with Service No episodes found for: Bad Nanny No titles returned, nothing to download...
I have same like you, It happen some of cbc videos.
here 2 episodes...
https://gofile.io/d/Tus1RB -
Until SBB chooses to release an update here is a fix.
Edit services/CBC/__init__.py
Add
to line 156 as in the image below. and save the file.Code:, "parts"
[Attachment 91884 - Click to enlarge]
The files are then treated as a Movie and downloaded using episode names as the "movie' titles. Not perfect but minimal coding to get a fix.Last edited by A_n_g_e_l_a; 10th Apr 2026 at 15:07.
Noob Starter Pack. Just download any Widevine media! Over 24,000 downloads for V6!.
Devine - Modular Movie, TV, and Music Archival Software
By billybanana in forum Video Streaming DownloadingReplies: 1871Last Post: 26th Jan 2026, 14:12 -
Bitrate confusion: HD vs. DV archival
By taigi in forum Capturing and VCRReplies: 3Last Post: 9th Nov 2024, 03:38 -
How do I completely remove the music and sound effects from a movie?
By cns00 in forum EditingReplies: 1Last Post: 15th Jan 2024, 12:11 -
Which software can remove music from show but keep character dialogue?
By Mohamed61020 in forum AudioReplies: 6Last Post: 2nd Jul 2023, 21:32 -
Software for simple music videos?
By dewiclements in forum Software PlayingReplies: 3Last Post: 26th Jul 2022, 01:21
