Page 23 of 28
FirstFirst ... 13 21 22 23 24 25 ... LastLast
Results 661 to 690 of 831
  1. Originally Posted by vidsrme View Post
    Originally Posted by kim1406 View Post
    I used
    uv run unshackle dl -l org,en -ns
    for no subtitles.
    I got the following problem
    did you add this to your yaml?
    dl:
      sub_format: srt
    I didn't, just added it on the command line, and didn't work, so I tried without downloading subtitles [-s].
    Now getting the above mentioned new error
    CalledProcessError: Command '[WindowsPath('packager-win-x64.EXE'),
    'input=Temp\\Audio_f7d2fe35.mp4,stream=0,output=Temp\\Audio_f7d2fe35_decrypted.m
    p4,output_format=MP4', '--enable_raw_key_decryption', '--keys',
    'label=0:key_id=0100a5d159fd35928736ef91a22a98b2:key=4cf9e0eceed92867587c58a9da2
    a5b67,label=1:key_id=00000000000000000000000000000000:key=4cf9e0eceed92867587c58
    a9da2a5b67', '--temp_dir', WindowsPath('Temp')]' returned non-zero exit status
    1.
         ❌ Download Failed...
            An unexpected error occurred in one of the download workers.
            Binary call failed, Process exit code: 1
            See the error trace above for more information.
  2. Originally Posted by kim1406 View Post
    I used
    for no subtitles.
    dl:
      sub_format: srt
    1.
    The code goes in your yaml, not the command line. For the third time - add it to your yaml.
    You're missing shaka packager. Download and add it to your PATH or put it in your Unshackle folder.
    Then post the result of "uv run unshackle env check"
  3. [QUOTE=vidsrme;2791396][QUOTE=kim1406;2791388][QUOTE=vidsrme;2791387]
    I used [CODE]u
    Here is the result:
                                Environment Dependencies
      ┃ Category   ┃ Tool             ┃   Status   ┃ Req  ┃ Purpose              ┃
      │ Core       │ FFmpeg           │     ✓      │  Y   │ Media processing     │
      │            │ FFprobe          │     ✓      │  Y   │ Media analysis       │
      │            │ MKVToolNix       │     ✓      │  Y   │ MKV muxing           │
      │            │ mkvpropedit      │     ✓      │  Y   │ MKV metadata         │
      │ DRM        │ shaka-packager   │     ✓      │  Y   │ DRM decryption       │
      │            │ mp4decrypt       │     ✓      │  -   │ DRM decryption       │
      │ HDR        │ dovi_tool        │     ✗      │  -   │ Dolby Vision         │
      │            │ HDR10Plus_tool   │     ✗      │  -   │ HDR10+ metadata      │
      │ Download   │ aria2c           │     ✓      │  -   │ Multi-thread DL      │
      │            │ N_m3u8DL-RE      │     ✗      │  -   │ HLS/DASH/ISM         │
      │ Subtitle   │ SubtitleEdit     │     ✗      │  -   │ Sub conversion       │
      │            │ CCExtractor      │     ✓      │  -   │ CC extraction        │
      │ Player     │ FFplay           │     ✓      │  -   │ Simple player        │
      │            │ MPV              │     ✗      │  -   │ Advanced player      │
      │ Network    │ HolaProxy        │     ✗      │  -   │ Proxy service        │
      │            │ Caddy            │     ✗      │  -   │ Web server           │
      Total: 9/16  All required tools installed ✓
  4. Originally Posted by kim1406 View Post
    Here is the result:
    Ok so did you try to download something?
  5. Originally Posted by vidsrme View Post
    Here is the result:
    Yes, but, still have a problem with subtitles. I added those lines in the yaml file:
    dl:
      best: true
      sub_format: srt
      workers: 16
      lang:
        - en
        - ar
    Here is the problem:
         1 Video
         └── [H.264, SDR] | en-US | 1920x800 @ 10241 kb/s, 23.976 FPS
              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 03:42 • Downloaded
         1 Audio
         └── [DD+] | en-US | 6.0 | 258 kb/s | United States
              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 00:28 • Downloaded
         9 Subtitles
         ├── [VTT] | de
         │    ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 00:02 • FAILED
         ├── [VTT] | en-US | United States
         ├── [VTT] | es-419 | Latin America
         │   ⠇ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • SKIPPED
         ├── [VTT] | fr-FR
         ├── [VTT] | it
         │   ⠏ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • SKIPPED
         ├── [VTT] | nl
         ├── [VTT] | pt-BR | Brazil
         ├── [VTT] | en-US | United States (SDH)
         └── [VTT] | it | SDH
         3 Chapters
         ├── 00:00:00.000 | Chapter 1
         ├── 01:38:32.907 | Credits
         └── 01:44:06.740 | Chapter 2
            Download Error (#db4f5f87956dcb58): Reached max-file-not-found
         count=5 (4),
         https://akm.prd.media.h264.io/gcs/b476be40-f7f5-4d1b-bb7a-3f8f5dbaad5c
         /t/02c622/en-US_cc.vtt
    When not downloading subtitles, it will work.
  6. Originally Posted by kim1406 View Post
    When not downloading subtitles, it will work. Thanks
    I dunno about subs, try experimenting and see what works (en-US instead of just "en") also you got "ar" in your yaml and that's not available.
    Also try changing "downloader" in your yaml (aria2c/requests/n_m3u8dl_re) sometimes that can affect downloads. Otherwise maybe someone else can advise.
    Dec 2021
    england
    replace your binaries
    https://files.videohelp.com/u/301156/binaries.zip
      │ HDR        │ dovi_tool        │     ✓      │  -   │ Dolby Vision         │
      │            │ HDR10Plus_tool   │     ✓      │  -   │ HDR10+ metadata      │
      │            │ N_m3u8DL-RE      │     ✓      │  -   │ HLS/DASH/ISM         │
      │ Subtitle   │ SubtitleEdit     │     ✓      │  -   │ Sub conversion       │
      │            │ MPV              │     ✓      │  -   │ Advanced player      │
      Total: 14/16  All required tools installed ✓
  8. Originally Posted by iamghost View Post
    [CODE]
    Thanks, I replaced the binaries and got exactly same as the above. However, it didn't solve the problem. I changed the downloader to n_m3u8dl_re and got the following:
     1 Video
             ⠏ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • Parsing streams...
         1 Audio
         9 Subtitles
         ├── [VTT] | de
         │   ⠏ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • FAILED
         ├── [VTT] | fr-FR
         ├── [VTT] | it
         ├── [VTT] | nl
         3 Chapters
            [WinError 3] The system cannot find the path specified:
         'Temp\\Audio_94782b72.mp4_segments'
    I then changed it to requests and got same error when using aria2c as a downloader:
     1 Video
              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 04:19 • Downloaded
         1 Audio
              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 00:32 • Downloaded
         9 Subtitles
         ├── [VTT] | de
         │   ⠴ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • FAILED
         │   ⠴ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • SKIPPED
         ├── [VTT] | fr-FR
         ├── [VTT] | it
         ├── [VTT] | nl
         3 Chapters
            404 Client Error: Not Found for url:
    Need your help.
    Thanks.
  9. Thank you for posting those binaries, that is something worth archiving.
    Dec 2021
    england
    Need your help.
    Thanks.
    post video url, you have hide them
  11. I tried using Envied and Twinvine and got same error.
  12. Originally Posted by kim1406 View Post
    Do you have subtitleedit installed?
    Why do you hide the link and ignore requests to post it?
  13. Originally Posted by vidsrme View Post
    Yes it is installed.
    I did not ignore, I sent the requester a pm with the link, as I'm not sure if posting links is allowed or not.
  14. Originally Posted by kim1406 View Post
    Yes it's ok to post links. Seeing as you have subtitleedit installed I don't know what else to suggest. If you post the link I can try to download it.
    Feb 2022
    Search the forum first!
    Hey! TwinVine is built for anyone and everyone to install. On a clean Windows 11 machine it takes all of three minutes and if you follow the install instructions it NEVER fails.
    So you are really saying you cannot follow instructions.
    Remove everything, start again and FFS do it properly and spare everyone the drama.
    Noob Starter Pack. Just download any Widevine media! Over 25,000 downloads for V6!.
  16. Originally Posted by A_n_g_e_l_a View Post
    He' got it installed, he's talking about an error with subtitles:
         1 Video
         1 Audio
         9 Subtitles
         ├── [VTT] | de
         ├── [VTT] | fr-FR
         ├── [VTT] | it
         ├── [VTT] | nl
         3 Chapters
         count=5 (4),
  17. Originally Posted by vidsrme View Post
    Thanks for your help. I figured out the problem. It was a bad service file, when I replaced it, everything downloaded fine.
  18. Originally Posted by A_n_g_e_l_a View Post
    Thanks for the amazing TwinVine, I installed without a problem. It is working fine, my problem was a bad service file.
    Great job. I Love your work.
    Feb 2022
    Then please don't leave silly one-liners that people can misinterpret.
    TwinVine installs subtitleedit as part of the installation process - you should know this.
    But more generally, if OPs actually read the error message we wouldn't get this plethora of "It doesn't work" bleatings.
    I'm not picking on this OP but anyone who posts a load of screen output with the expectation someone else will tell them what to do.
    READ THE ERROR MESSAGE!!! It tells you the problem.
    [Attachment 91038 - Click to enlarge]
    And in the case above - file not found - is the issue. Think it through - why is the file not found?
    One: could be a server error and the file has been removed at the far end. (Not likely but it does happen)
    Two: The service script has become out dated (highly likely and reported as the cause in this case), so find another way to download the file - (HellYes suggested).
    If you are up for finding out where the error comes from in a script then use VSCode (it is free!!), edit this launch.json file to suit:-
    PHP Code:
    "version""0.2.1",
    "configurations": [
    "name""Debug vinefeeder",
    "type""debugpy",
    "request""launch",
    "module""vinefeeder.__main__",
    "args": [
    "cwd""${workspaceFolder}",
    "console""integratedTerminal",
    "justMyCode"false
    "name""Debug envied",
    "type""debugpy",
    "request""launch",
    "module""envied.__main__",
    "args": [
    "dl",
    "--select-titles",
    "SPOT",
    "https://open.spotify.com/playlist/4lXLUGtdiDFUbmDSHpt699?si=kmT227kyQYmWE0Ong"
    "justMyCode"false
    VSCode's launch.json for debugging envied within TwinVine's structure.
    Use a chat AI to seek help about using VSCode as a debugger - and stop being helpless - everyone!!
  20. Originally Posted by A_n_g_e_l_a View Post
    Actually you jumped into a 2 day old conversation, only caught the end part and instead of reading the previous posts you incorrectly guessed and misinterpreted what the conversation was about.
    I was helping the guy get Unshackle working for 2 days and my comment about subtitleedit was related to Unshackle, nothing to do with Twinvine/Envied.
    If you go back and read the previous comments instead of just taking the end part and running with it you would see that.
  21. ╭───────────────────── Traceback (most recent call last) ──────────────────────╮
    │ in _run_module_as_main:198 │
    │ in _run_code:88 │
    │ in <module>:10 │
    │ C:\unshackle\.venv\Lib\site-packages\click\core.py:1462 in __call__ │
    │ C:\unshackle\.venv\Lib\site-packages\click\core.py:1383 in main │
    │ C:\unshackle\.venv\Lib\site-packages\click\core.py:1850 in invoke │
    │ C:\unshackle\.venv\Lib\site-packages\click\core.py:1819 in _process_result │
    │ C:\unshackle\.venv\Lib\site-packages\click\core.py:814 in invoke │
    │ C:\unshackle\unshackle\commands\dl.py:995 in result │
    │ 992 │ │ │ with console.status("Getting tracks...", spinner="dots"): │
    │ 993 │ │ │ │ try: │
    │ 994 │ │ │ │ │ title.tracks.add(service.get_tracks(title), warn_ │
    │ ❱ 995 │ │ │ │ │ title.tracks.chapters = service.get_chapters(titl │
    │ 996 │ │ │ │ except Exception as e: │
    │ 997 │ │ │ │ │ if self.debug_logger: │
    │ 998 │ │ │ │ │ │ self.debug_logger.log_error( │
    │ C:\unshackle\unshackle\services\ABC\__init__.py:16 3 in get_chapters │
    │ 160 │ │ │
    │ 161 │ │ credits = next((x.get("start") for x in title.data["cuePoints" │
    │ 162 │ │ if credits: │
    │ ❱ 163 │ │ │ return Chapters([Chapter(name="Credits", timestamp=credits │
    │ 164 │ │ │
    │ 165 │ │ return Chapters() │
    │ 166
    I cant seem to avoid this error. any assistance would be grand! ty ty
  22. Originally Posted by plasticpillow View Post
    │ 160 │ │ │
    │ 164 │ │ │
    │ 166
    As a fix, just remove chapters -
    find init.py for that service and change
    PHP Code:
        def get_chapters(selftitleUnion[MovieEpisode]) -> Chapters:
            if
    not title.data.get("cuePoints"):
                return
    Chapters()
    credits next((x.get("start") for x in title.data["cuePoints"] if x["type"] == "end-credits"), None)
            if
    credits:
                return
    Chapters([Chapter(name="Credits"timestamp=credits 1000)])
            return
    Chapters()
    To
    PHP Code:
    #if not title.data.get("cuePoints"):
             #   return Chapters()
            #credits = next((x.get("start") for x in title.data["cuePoints"] if x["type"] == "end-credits"), None)
            #if credits:
               # return Chapters([Chapter(name="Credits", timestamp=credits * 1000)])
    return Chapters()
  23. Thank you Phased!
    Now I can't seem to download seperate season on AUBC and or TEN. I have the services that Stabbedbybricks kindly provided, they work perfectly except for my issue.
  24. Just out of curiousity is anyone having trouble with CWTV. I was checking it one day and I could get the list titles and the title commands to work just fine but when setting it up to download it failed. I was thinking of archiving "Reign".
  25. Originally Posted by Tom Saurus View Post
    What errors is it throwing it up?
  26. It has gotten worse and I trying different U.S. cities now on the Windscribe VPN and even list titles is failing:
    C:\Unshackle>uv run unshackle dl -q 480 -w S01E01 CWTV https://www.cwtv.com/series/reign
                 v 2.3.0 - © 2025 - github.com/unshackle-dl/unshackle
         Service Config loaded
         Loaded 1/1 Vaults
         Loaded Widevine CDM: 4464 (L3)
      ────────────────────────────── Service: CWTV ───────────────────────────────
         Service is not Geoblocked in your region
    │ in _run_code:88                                                              │
    │ in <module>:10                                                               │
    │ C:\Unshackle\.venv\Lib\site-packages\click\core.py:1462 in __call__          │
    │ C:\Unshackle\.venv\Lib\site-packages\click\core.py:1383 in main              │
    │ C:\Unshackle\.venv\Lib\site-packages\click\core.py:1850 in invoke            │
    │ C:\Unshackle\.venv\Lib\site-packages\click\core.py:1819 in _process_result   │
    │ C:\Unshackle\.venv\Lib\site-packages\click\core.py:814 in invoke             │
    │ C:\Unshackle\unshackle\commands\dl.py:823 in result                          │
    │    820 │   │        │
    │    821 │   │   with console.status("Fetching Title Metadata...", spinner="do │
    │    822 │   │   │   try:                                                      │
    │ ❱  823 │   │   │   │   titles = service.get_titles_cached()                  │
    │    824 │   │   │   │   if not titles:                                        │
    │    825 │   │   │   │   │   self.log.error("No titles returned, nothing to do │
    │    826 │   │   │   │   │   if self.debug_logger:                             │
    │ C:\Unshackle\unshackle\core\service.py:259 in get_titles_cached              │
    │   256 │   │   account_hash = get_account_hash(self.credential)               │
    │   257 │   │        │
    │   258 │   │   # Use title cache to get titles with fallback support          │
    │ ❱ 259 │   │   return self.title_cache.get_cached_titles(                     │
    │   260 │   │   │   title_id=str(title_id),                                    │
    │   261 │   │   │   fetch_function=self.get_titles,                            │
    │   262 │   │   │   region=self.current_region,                                │
    │ C:\Unshackle\unshackle\core\title_cacher.py:120 in get_cached_titles         │
    │   117 │   │        │
    │   118 │   │   try:                                                           │
    │   119 │   │   │   # Attempt to fetch fresh titles                            │
    │ ❱ 120 │   │   │   titles = fetch_function()                                  │
    │   121 │   │   │                                                              │
    │   122 │   │   │   if titles:                                                 │
    │   123 │   │   │   │   # Successfully fetched, update cache                   │
    │ C:\Unshackle\unshackle\services\CWTV\__init__.py:98 in get_titles            │
    │    95 │   │   kind, guid, play_id = (match.group(i) for i in ("type", "id",  │
    │    96 │   │        │
    │    97 │   │   if kind in ("series", "shows") and not play_id:                │
    │ ❱  98 │   │   │   episodes = self._series(guid)                              │
    │    99 │   │   │   return Series(episodes)                                    │
    │   100 │   │        │
    │   101 │   │   elif kind == "movies" and not play_id:                         │
    │ C:\Unshackle\unshackle\services\CWTV\__init__.py:174 in _series              │
    │   171 │   # Service specific                                                 │
    │   172 │        │
    │   173 │   def _series(self, guid: str) -> list[Episode]:                     │
    │ ❱ 174 │   │   series = self._request("GET", f"/feed/app-2/videos/show_{guid} │
    │   175 │   │   if not series.get("items"):                                    │
    │   176 │   │   │   raise ValueError(f"Could not find any episodes with ID {gu │
    │   177        │
    │ C:\Unshackle\unshackle\services\CWTV\__init__.py:241 in _request             │
    │   238 │   │        │
    │   239 │   │   response = self.session.send(prep)                             │
    │   240 │   │   if response.status_code != 200:                                │
    │ ❱ 241 │   │   │   raise ConnectionError(f"{response.text}")                  │
    │   242 │   │        │
    │   243 │   │   try:                                                           │
    │   244 │   │   │   return json.loads(response.content)                        │
    ConnectionError: <?xml version="1.0" encoding="UTF-8"?>
    <Error><Code>AccessDenied</Code><Message>Access Denied</Message></Error>
    C:\Unshackle>
    So maybe it just something on my end maybe it is a problem for others as well.
  27. Member
    Dec 2021
    england
         Loaded 1/1 Vaults
    │ in _run_code:88                                                              │
    │ in <module>:10                                                               │
    │    820 │   │        │
    │    822 │   │   │   try:                                                      │
    │   257 │   │        │
    │   117 │   │        │
    │   118 │   │   try:                                                           │
    │   121 │   │   │                                                              │
    │    96 │   │        │
    │   100 │   │        │
    │   172 │        │
    │   177        │
    │   238 │   │        │
    │   242 │   │        │
    │   243 │   │   try:                                                           │
    C:\Unshackle>
    it not just you, I have the same
  28. Maybe me or someone else better raise this issue over at stabbedbybrick's web page. I forgot where I wrote down my Github login and password so I will leave it to someone else to raise the CWTV issue for now as it may take a while to remember where I wrote that down. Scratch that I just found it.
    I have to wait for a bit I am using Unshackle to download a season of a show right now and I need to keep my VPN on. When I sign into Github I have to go to my Yahoo Email and get a verification code and I always have to shut my VPN on or I have big time problems with my Yahoo Mail.
    I think this time I would prefer if someone else raised the CWTV issue as I am getting some stuff from Pluto that may not be available for much longer and I want to get that done and finished up.
