Page 17 of 28
FirstFirst ... 7 15 16 17 18 19 27 ... LastLast
Results 481 to 510 of 831
  1. Originally Posted by iamghost View Post
    ok thats fine,
    now try with without subtitle, I got error with ccextractor.
    this one is fine
    uv run unshackle dl -ns cbc https://gem.cbc.ca/swipe-bet-repeat
    Unfortunately it's the same...
    warning: `VIRTUAL_ENV=/home/pc/Downloads/pyenvs/main` does not match the project environment path `.venv` and will be ignored; use `--active` to target the active environment instead
                 v 2.0.0 - © 2025 - github.com/unshackle-dl/unshackle
         Service Config loaded
         Loaded 0/0 Vaults
         Loaded Widevine CDM: 28919 (L3)
      ─────────────────────────────── Service: CBC ───────────────────────────────
         Service is not Geoblocked in your region
          + Using cached tokens
         Authenticated with Service
      ──────────────────── Movies: Swipe. Bet. Repeat. (2025) ────────────────────
         1 Movie
      ──────────────────────── Swipe. Bet. Repeat. (2025) ────────────────────────
         Skipped subtitles as --no-subs was used...
         1 Video
         └── [H.264, SDR] | en-CA | 1920x1080 @ 6811 kb/s, 29.970 FPS
              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 00:40 • Downloaded
         1 Audio
         └── [AAC] | en-CA | 2.0
              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 01:03 • Downloaded
         5 Chapters
         ├── 00:00:00.000
         ├── 00:13:15.000
         ├── 00:25:58.000
         ├── 00:36:58.000
         └── 00:43:23.000 | Credits
         Track downloads finished in 1m7s
         Failed to Mux video to Matroska file (2):
         #GUI#error The type of file
         '/home/pc/Downloads/devine/temp/Video_a55fa21f.mp4' could not be
         recognized.
         Multiplexing... ⠦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ •
    [Attachment 89820 - Click to enlarge]
    I tried Envied and it worked no problems...
    uv run envied dl cbc https://gem.cbc.ca/swipe-bet-repeat
                               and more than unshackled...
                    v 2.0.0 - https://github.com/vinefeeder/envied
         Loaded 1/1 Vaults
         Requesting new tokens...
         1 Movie
         1 Video
             ⠦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━╸ • 00:01 • Downloaded
         1 Audio
         5 Chapters
         ├── 00:00:00.000
         ├── 00:13:15.000
         ├── 00:25:58.000
         ├── 00:36:58.000
         Track downloads finished in 0m58s
         Extracted a Closed Caption from Video track 1
         Multiplexing... ⠇ ━━━━━━━╸━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 00:05              Multiplexing...  ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 00:05
         🎉 Title downloaded in 1m14s!
         Processed all titles in 1m22s
    Dec 2021
    england
    same with devine without problem. it unshackle and need a bit fix with ccextractor
  3. Originally Posted by iamghost View Post
    Ok
  4. Thankfully I was able to download an episode from CBC at 540 resolution with no problems. It got the subtitles with the download.
  5. It is probably just me but tonight I am having failure after failure with TUBI. So I will take a break and try another service and give TUBI a try again later on.
    Feb 2022
    Search the forum first!
    Ok
    Envied is a direct fork of unshackle with the addition of --select-titles. With the upgrade to v2 for unshackle, I followed upstream exactly.
    Unshackle failing at muxing is most likely the result of configuration.
    I know that envied specifies shaka-packager; I set that deliberately as recently I found mp4decrypt giving errors on my system - muxing; black-video or refusal to play-back.
    So perhaps unshackle.yaml needs a tweak away from mp4decypt for unshackle users.
    TwinVine on CachyOS
    [Attachment 89829 - Click to enlarge]
    Noob Starter Pack. Just download any Widevine media! Over 25,000 downloads for V6!.
    Sep 2025
    France
    [QUOTE=A_n_g_e_l_a;2786842]
    How did you managed to get SubtitleEdit ported to CachyOS?
  8. With TUBI I am getting this:
    [CODE][C:\unshackle>uv run unshackle dl -q 480 -V TUBI https://tubitv.com/movies/100042107/jeremiah-johnson
    Loaded 1/1 Vaults
    Loaded Widevine CDM: 8158 (L3)
    ────────────────────────────── Service: TUBI ───────────────────────────────
    Service has no Geofence
    ───────────────────── Movies: Jeremiah Johnson (1972) ──────────────────────
    1 Movie
    ───────────────────────── Jeremiah Johnson (1972) ──────────────────────────
    [Aria2c]: Download Error (#ff9fb1286ced4d3d): No URI available. (24),
    https://nc-fa.tubi.video/2b6f9dab-aa42-4222-b0a8-
    f1b0eb0313af/x5x305vj.mp4?fastly_token=1764348177_ff1bccb6bb
    246021b61d3e8ef61575a1fe706cbe
    1 Video
    └── [H.264, SDR] | en | 854x356 @ 1324 kb/s, 23.976 FPS
    ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 01:09 • FAILED
    Widevine(AAAAOHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAA BgSEBQRFbbUXE1Av...)
    └── 141115b6d45c4d40bf650eda1ccda7ba:8e235d5ddeebf9fdd b8c5378d7646641*
    from Local SQLite
    ❌ Download Failed...
    [WinError 32] The process cannot access the file because it is
    being used by another process:
    'C:\\unshackle\\Temp\\Video_e81d6728.mp4.aria2__te mp'
    An unexpected error occurred in one of the download workers.
    See the error trace above for more information.
    C:\unshackle>/CODE]
    I have the latest TUBI Service SBB put out. I have a cookie and credentials. It was working well until yesterday when it started to get these errors more and more. Any advice is appreciate and thank you in advance.
    I gave it a try with DEVINE and it is working fine. I am wondering if having both cookie and credentials is bothering TUBI.
    Feb 2022
    I shamelessly copied the approach taken by Akirainblack here https://github.com/vinefeeder/TwinVine/issues/1#issuecomment-3538725879. It uses a windows version run with mono. Mono installs from the CachyOS package manager and if you download install.sh (in the link) and read through you'll find the command to get SubtitleEdit.
    All credit to Akirainblack.
  10. Originally Posted by A_n_g_e_l_a View Post
    Ok
    I don't have anything set in my yaml
    [Attachment 89850 - Click to enlarge]
    Do you know what the setting is to set it to shaka? I've read the github example yaml but there's nothing for decryptor
    Feb 2022
    as an unshackle user you should already be using shakapackager; I think that is now the unshackle default.
    You may also set it as below.
    The envied verson in TwinVine was set to mp4decrypt as it wasn't producing annoying notes to screen like shaka does.
    I do more with TwinVine to try to make it easier for people to use.
    [Attachment 89851 - Click to enlarge]
  12. Originally Posted by A_n_g_e_l_a View Post
    Yeah Envied works with this CBC link no problems
    I tried setting the Unshackle yaml to both shaka and mp4decrypt, but it still can't complete the multiplexing for some reason.
     uv run unshackle -d dl cbc https://gem.cbc.ca/swipe-bet-repeat
         Loaded 0/0 Vaults
         No vaults are currently active
         Starting new HTTPS connection (1): ipinfo.io:443
         https://ipinfo.io:443 "GET /json HTTP/1.1" 200 None
         Starting new HTTPS connection (1): services.radio-canada.ca:443
         https://services.radio-canada.ca:443 "GET
         /ott/subscription/v2/gem/Subscriber/profile?device=web HTTP/1.1" 200
         953
         Cache key mapping: https://gem.cbc.ca/swipe-bet-repeat ->
         titles_1c6b2d727c7614a9_gb_335b8fe3
         Cache hit for https://gem.cbc.ca/swipe-bet-repeat (hits: 1, misses: 0)
         1 Movie
         /media/meta/v1/index.ashx?appCode=gem&idMedia=985652&output=jsonObject
         HTTP/1.1" 200 1154
         /media/validation/v2?appCode=gem&&deviceType=android&idMedia=985652&ma
         nifestType=smart-tv&output=json&tech=hls HTTP/1.1" 200 642
         Starting new HTTPS connection (1): cbcrcott-aws-gem.akamaized.net:443
         https://cbcrcott-aws-gem.akamaized.net:443 "GET
         /out/v1/1f4b23faa2c243e4826d132a7b49d183/026bf27581e640c4b4fb78ae5aaa5
         021/4992c413374a4be4af23a7b5453f28df/index-aes.m3u8?pckgrp=bf5b9c2800b
         7e86d48330ceb5add54a4&ewid=83317&manifestType=smarttv&hdnea=st=1763895
         716~exp=1763895836~acl=*~hmac=17fafe40d32ce374d776b634e3dcbdc0d3d3394d
         cfd8e042cfd296cf4afcb686&EIA608ClosedCaptions=true&lang=en HTTP/1.1"
         200 None
         Pre-selecting Widevine CDM based on highest quality 1080p across all
         video tracks
         /hdntl=exp=1763982119~acl=%2F*~data=hdntl~hmac=9b002db3c7a78849466438b
         c79366c071e71a90807a1ef006c96800df8e805d3/out/v1/1f4b23faa2c243e4826d1
         32a7b49d183/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b54
         53f28df/350790c9387544c29261600984e76d74/6baf985d549245c48f39e42930e10
         a5e/index-aes_1.m3u8?aka_me_session_id=AAAAAAAAAAAnOyRpAAAAAPkot1mLSov
         0Jgq3nlERblX72obVCXtLeiYd6V%2F4vmS2VoE7HB%2F71yfynL5Idz1Ra5nqIX1beQxN&
         aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4
         HTTP/1.1" 200 None
         Starting new HTTP connection (1): 127.0.0.1:53473
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 145
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 86
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 153
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 154
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 1757
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 2989
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 4662
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 6077
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 7091
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 8460
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 9768
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 11076
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 12920
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 14104
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 15073
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 16370
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 17527
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 18959
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 20444
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 21779
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 22994
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 156
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 24469
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 26069
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 27319
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 28852
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 152
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 29994
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 31770
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 32592
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 34154
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 35600
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 155
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 36630
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 38405
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 39658
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 40776
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 42395
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 43773
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 44247
         http://127.0.0.1:53473 "POST /jsonrpc HTTP/1.1" 200 87
         Resetting dropped connection: 127.0.0.1
         a5e/index-aes_12_0.m3u8?aka_me_session_id=AAAAAAAAAAAnOyRpAAAAAPkot1mL
         Sov0Jgq3nlERblX72obVCXtLeiYd6V%2F4vmS2VoE7HB%2F71yfynL5Idz1Ra5nqIX1beQ
         xN&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4
         HTTP/1.1" 200 3148
         Starting new HTTP connection (1): 127.0.0.1:42011
         Starting new HTTP connection (2): 127.0.0.1:42011
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 86
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 152
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 1334
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 2868
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 4315
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 154
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 5604
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 6820
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 9599
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 12075
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 153
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 14604
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 16977
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 151
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 19450
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 22096
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 24566
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 27126
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 29563
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 31997
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 34509
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 36918
         http://127.0.0.1:42011 "POST /jsonrpc HTTP/1.1" 200 87
         1 Video
              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 00:36 • Downloaded
         1 Audio
              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 01:05 • Downloaded
         5 Chapters
         ├── 00:00:00.000
         ├── 00:13:15.000
         ├── 00:25:58.000
         ├── 00:36:58.000
         Track downloads finished in 1m10s
         '/home/pc/Downloads/devine/temp/Video_64295cf8.mp4' could not be
         recognized.
         Multiplexing... ⠧ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ •
    The "Video_64295cf8.mp4" is present in my temp folder, as is the audio:
    [Attachment 89859 - Click to enlarge]
    But only the audio is playable/decrypted. The video is not playable either due to being corrupt or still encrypted.
  13. vidsrme: Have you tried downloading it in a lower quality perhaps 540? Have you checked your temp file and deleted what was in there? Have you cleared the CBC cache?
  14. Originally Posted by Tom Saurus View Post
    I just tried with
    -q 720
    and
    -q 540
    and both failed with the same error, and yes I've deleted temp and cache
    Mar 2024
    @vidsrme: I was hoping to give you an answer by debugging. However I can't reproduce the issue. Everything works fine for me. Sorry!
  16. Since my GMTek Mini PC stopped working I decided to try to get Unshackle up and running on my Beelink mini pc and it took quite sometime but I finally got it set up. Now I am having trouble with CBC but I had success with PLUTO. CBC has failed on the subtitle with CCExtractor. The audio and video are in the temp folder and both are decrypted and fully intact. So I can mux them together and I can live without the subtitle. I will try it with just asking Unshackle to get the audio and video and see how that goes.
  17. I was able to get an episode just fine with CBC by using the -V -A to just get the audio and video. Also TUBI seems to be working again for me with success with a DRM video and DRM free video.
  18. We don’t have username/password logins for DSCP — authentication is only through mobile number + OTP. Because of that, we can’t use the credentials: section in unshackle.yaml.
    How do we configure DSCP to use cookies only? I have placed the cookes.txt file in D:\unshackle\Cookies\cookies.txt
    I’m currently getting this error:
    unshackle dl -w S01E01 DSCP https://discoveryplus.in/videos/planet-earth-iii-in/
    Error: There are no Services added yet, therefore the 'DSCP' Service could not be found.
    credentials in unshackle.yaml
    # Direct credentials (no profile support)
    DSCP:
  19. Originally Posted by SaintyUK View Post
    Hmm, ok thats strange but thanks for trying
    EDIT: iamghost said he had the problem too so it isn't limited to just me:
    DSCP:
    It looks like your .yaml isn't set correctly, or you didn't add or don't have any services. Check your directories with:
    uv run unshackle env info
    And post the output
    Also check the services are present in the services directory.
  20. Can anyone tell me where the variable options and parameters (such as -q -w -v -a -ns and any others) are listed... I can't find them anywhere.
  21. If anyone is interested, I have created a Dockerfile for Unshackle. When I initially built it, I had engineered a version of the unshackle-ui that worked somewhat. That's still in the Dockerfile, but the changes I had to make to the unshackle backend did not work out well when running unshackle from the command line. As such, those changes are not implemented, but the UI is still in the Dockerfile and may still work, partially.
    https://github.com/Kryxan/Unshackle-docker
  22. Member
    Mar 2024
    unshackle dl --help
  23. Originally Posted by hitman View Post
    DSCP:
    And post the output
    Also check the services are present in the services directory.[/QUOTE]
    PS D:\ops\unshackle> uv run unshackle env info
    Config loaded from D:\OPs\unshackle\unshackle\unshackle.yaml
    Directories
    ┃ Name ┃ Path ┃
    │ Cache │ D:\OPs\unshackle\Cache │
    │ Commands │ D:\OPs\unshackle\unshackle\commands │
    │ Cookies │ D:\OPs\unshackle\Cookies │
    │ Core_Dir │ D:\OPs\unshackle\unshackle\core │
    │ Data │ D:\OPs\unshackle\unshackle │
    │ Dcsl │ D:\OPs\unshackle\DCSL │
    │ Downloads │ D:\OPs\unshackle\Downloads │
    │ Fonts │ D:\OPs\unshackle\unshackle\fonts │
    │ Logs │ D:\OPs\unshackle\Logs │
    │ Namespace_Dir │ D:\OPs\unshackle\unshackle │
    │ Prds │ D:\OPs\unshackle\PRDs │
    │ Services │ D:\OPs\unshackle\unshackle\services │
    │ Temp │ D:\OPs\unshackle\Temp │
    │ User_Configs │ D:\OPs\unshackle\unshackle │
    │ Vaults │ D:\OPs\unshackle\unshackle\vaults │
    │ Wvds │ D:\OPs\unshackle\WVDs │
    I can see DSCP service folder here - D:\OPs\unshackle\unshackle\services
    Cookies placed in D:\OPs\unshackle\Cookies\cookies.txt
    I tried one video with PLEX, it is working properly.
Name:	Screenshot 2025-11-24 160309.png
  24. Member
    Dec 2021
    england
    i have everything...
    [Attachment 89904 - Click to enlarge]
    download get error
    [Attachment 89905 - Click to enlarge]
    download with -ns (no subtitle) is fine
    it only just this movie, other is no problem
  25. Member
    Nov 2025
    London
    Getting this with DSNP:
    ────────────────────────────── Service: DSNP ───────────────────────────────
    + Refreshing Tokens
    ─────────────────────── Series: Downton Abbey (2010) ───────────────────────
    6 seasons, S1(7), S2(9), S3(10), S4(10), S5(9), S6(9)
    ────────────────── Downton Abbey 2010 S01E01 Episode One ───────────────────
    1 Video
    └── [H.264, SDR] | en | 1280x720 @ 2581 kb/s, 23.976 FPS
    ⠙ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • LICENSED
    1 Audio
    └── [AAC] | en | 2.0 | 128 kb/s
    16 Subtitles
    ├── [VTT] | en
    ├── [VTT] | en | SDH
    ├── [VTT] | cs
    ├── [VTT] | da
    ├── [VTT] | de
    ├── [VTT] | el
    ├── [VTT] | es-ES
    ├── [VTT] | fi
    ├── [VTT] | fr-FR
    ├── [VTT] | hu
    ├── [VTT] | it
    ├── [VTT] | nl
    ├── [VTT] | no
    ├── [VTT] | pt-PT
    ├── [VTT] | ro
    └── [VTT] | sv
    4 Chapters
    ├── 00:00:00.000 | Start
    ├── 00:00:01.001 | Title Sequence
    ├── 00:01:45.689 | Scene 1
    └── 01:07:54.320 | End Credits
    Widevine(AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAA BISEMRS+3/YAESSs...)
    └── c452fb7fd8004492b32ccccce13b4daf:49777a5cc1746ab1b f93acae7803526f
    from Local SQLite
    ╭───────────────────── Traceback (most recent call last) ──────────────────────╮
    │ C:\Users\kabul\OneDrive\Desktop\rip2\unshackle\uns hackle\commands\dl.py:1456 │
    │ in result │
    │ 1453 │ │ │ │ │ │ │ │ for i, track in enumerate(title.track │
    │ 1454 │ │ │ │ │ │ │ ) │
    │ 1455 │ │ │ │ │ │ ): │
    │ ❱ 1456 │ │ │ │ │ │ │ download.result() │
    │ 1457 │ │ │ │
    │ 1458 │ │ │ except KeyboardInterrupt: │
    │ 1459 │ │ │ │ console.print(Padding(": Download Cancelled...", (0 │
    │ C:\Program Files\Python311\Lib\concurrent\futures\_base.py:44 9 in result │
    │ 446 │ │ │ │ if self._state in [CANCELLED, CANCELLED_AND_NOTIFIED]: │
    │ 447 │ │ │ │ │ raise CancelledError() │
    │ 448 │ │ │ │ elif self._state == FINISHED: │
    │ ❱ 449 │ │ │ │ │ return self.__get_result() │
    │ 450 │ │ │ │ │
    │ 451 │ │ │ │ self._condition.wait(timeout) │
    │ 452 │
    │ C:\Program Files\Python311\Lib\concurrent\futures\_base.py:40 1 in │
    │ __get_result │
    │ 398 │ def __get_result(self): │
    │ 399 │ │ if self._exception: │
    │ 400 │ │ │ try: │
    │ ❱ 401 │ │ │ │ raise self._exception │
    │ 402 │ │ │ finally: │
    │ 403 │ │ │ │ # Break a reference cycle with the exception in self._ │
    │ 404 │ │ │ │ self = None │
    │ C:\Program Files\Python311\Lib\concurrent\futures\thread.py:5 8 in run │
    │ 55 │ │ │ return │
    │ 56 │ │ │
    │ 57 │ │ try: │
    │ ❱ 58 │ │ │ result = self.fn(*self.args, **self.kwargs) │
    │ 59 │ │ except BaseException as exc: │
    │ 60 │ │ │ self.future.set_exception(exc) │
    │ 61 │ │ │ # Break a reference cycle with the exception 'exc' │
    │ C:\Users\kabul\OneDrive\Desktop\rip2\unshackle\uns hackle\core\tracks\subtitl │
    │ e.py:215 in download │
    │ 212 │ │ *, │
    │ 213 │ │ cdm: Optional[object] = None, │
    │ 214 │ ): │
    │ ❱ 215 │ │ super().download(session, prepare_drm, max_workers, progress, │
    │ 216 │ │ if not self.path: │
    │ 217 │ │ │ return │
    │ 218 │
    │ C:\Users\kabul\OneDrive\Desktop\rip2\unshackle\uns hackle\core\tracks\track.p │
    │ y:216 in download │
    │ 213 │ │ │ save_path = save_path.with_suffix(f".{self.codec.extension │
    │ 214 │ │ │ # n_m3u8dl_re doesn't support directly downloading subtitl │
    │ 215 │ │ │ # or when the subtitle has a direct file extension │
    │ ❱ 216 │ │ │ if self.downloader.__name__ == "n_m3u8dl_re" and ( │
    │ 217 │ │ │ │ self.descriptor == self.Descriptor.URL │
    │ 218 │ │ │ │ or get_extension(self.url) in { │
    │ 219 │ │ │ │ │ ".srt", │
    AttributeError: 'str' object has no attribute '__name__'
  26. double post
    Last edited by vidsrme; 25th Nov 2025 at 06:59. Reason: same posted below in error
  27. Originally Posted by SaintyUK View Post
    unshackle dl --help
    Ok cool, I was trying
    uv run unshackle --help
    which doesn't give all the options.
    Directories
    ┃ Name ┃ Path ┃
    Ok so previously your error was
    Do you still have that error? If so that's what needs fixing first, before cookies. For cookies I believe oyu may need to use a browser extension like this for FF or this for chrome but you need to make sure the "no services error" is fixed first and foremost because it definitely won't work while it's saying that, then look at getting cookies sorted.
    Ah, you have a different error than me, I have:
         recognized.
    And trying with -ns doesn't solve my issue. I tried another CBC program and got the same result again
    uv run unshackle dl cbc https://gem.cbc.ca/gold-bars
         Loaded 0/0 Vaults
         Refreshing cached tokens...
      ───────────────────────── Movies: Gold Bars (2025) ─────────────────────────
         1 Movie
      ───────────────────────────── Gold Bars (2025) ─────────────────────────────
         1 Video
              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 01:37 • Downloaded
         1 Audio
              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 02:48 • Downloaded
         10 Chapters
         ├── 00:00:00.000
         ├── 00:20:22.000
         ├── 00:32:56.000
         ├── 00:44:03.000
         ├── 00:52:52.000
         ├── 00:59:57.000
         ├── 01:06:16.000
         ├── 01:16:01.000
         ├── 01:21:41.000
         └── 01:27:21.600 | Credits
         Track downloads finished in 2m52s
         '/home/pc/Downloads/devine/temp/Video_c5cd2eb1.mp4' could not be
         recognized.
         Multiplexing... ⠹ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ •
    For some reason the video is not being decrypted and is unplayable, but the audio is being decrypted and is playable. I have both shaka and mp4decrypt in my path so that can't be the issue.
    $ mp4decrypt
    MP4 Decrypter - Version 1.4
    (Bento4 Version 1.6.0.0)
    (c) 2002-2015 Axiomatic Systems, LLC
    $ shaka-packager
    Usage: shaka-packager [flags] <stream_descriptor> ...
    Also everything works with Envied, and unshackle works fine on other ssrvices such as ALL4:
    $ uv run unshackle dl all4 https://www.channel4.com/programmes/24-hours-in-police-custody/on-demand/77005-003
         Loaded 0/0 Vaults
      ────────────────────────────── Service: ALL4 ───────────────────────────────
          + Using cached Tokens...
      ──────────────────── Series: 24 Hours in Police Custody ────────────────────
         1 seasons, S5(1)
      ────── 24 Hours in Police Custody S05E03 Nightclub Predator - Part 1 ───────
         Cached 1 Key to 0/0 Vaults
         Falling back to the requests downloader as aria2(c) doesn't support
         the Range header
         [Widevine]: I1125 04:01:38.185404    8968 demuxer.cc:94]
                     Demuxer::Run() on file
                     '/home/pc/Downloads/devine/temp/Video_68ee9604.mp4'. I1125
                     04:01:38.185796    8968 demuxer.cc:160] Initialize Demuxer
                     for file
                     04:01:43.624313    8968 single_segment_segmenter.cc:111]
                     Update media header (moov) and rewrite the file to '/home/
                     pc/Downloads/devine/temp/Video_68ee9604_decrypted.mp4'.
                     I1125 04:01:47.842391    8968 mp4_muxer.cc:195] MP4 file '
                     /home/pc/Downloads/devine/temp/Video_68ee9604_decrypted.mp
                     4' finalized.
         the Range header
         [Widevine]: I1125 04:01:49.972498    9632 demuxer.cc:94]
                     '/home/pc/Downloads/devine/temp/Audio_841a051e.mp4'. I1125
                     04:01:49.972914    9632 demuxer.cc:160] Initialize Demuxer
                     for file
                     04:01:50.159223    9632 single_segment_segmenter.cc:111]
                     pc/Downloads/devine/temp/Audio_841a051e_decrypted.mp4'.
                     I1125 04:01:50.266770    9632 mp4_muxer.cc:195] MP4 file '
                     /home/pc/Downloads/devine/temp/Audio_841a051e_decrypted.mp
                     4' finalized.
         1 Video
         └── [H.264, SDR] | en | 1920x1080 @ 5703 kb/s, 25.000 FPS
         1 Audio
         └── [AAC] | en | 2.0 | 135 kb/s
         1 Subtitle
         └── [VTT] | en
              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 01:06 • Downloaded
         5 Chapters
         ├── 00:00:00.000 | Chapter 01
         ├── 00:11:02.040 | Chapter 02
         ├── 00:23:07.560 | Chapter 03
         ├── 00:35:19.800 | Chapter 04
         └── 00:46:25.560 | Credits
         Widevine(AAAASnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAACoIARIQqjQw7Yu93...)
         └── aa3430ed8bbddd93c80dbc117da35f3c:7e73a735a6df75a3b9e0d92935bb8d06*
         Multiplexing...  ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 00:04
         �� Title downloaded in 1m15s!
         Processed all titles in 1m16s
    But for me on CBC the above in bold doesn't happen, I guess that may be the problem does anyone know why this part isnt happening for me on CBC?
         the Range header
    And I had aria2c set as chosen downloader in my yaml. So I changed it to n_m3u8dl_re and it fixed the issue:
    $ uv run unshackle dl cbc https://gem.cbc.ca/gold-bars
         Loaded 0/0 Vaults
         1 Movie
         1 Video
             ⠴ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━╸ • --:-- • Downloaded
         1 Audio
             ⠴ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━╸ • 00:01 • Downloaded
         10 Chapters
         ├── 00:00:00.000
         ├── 00:20:22.000
         ├── 00:32:56.000
         ├── 00:44:03.000
         ├── 00:52:52.000
         ├── 00:59:57.000
         ├── 01:06:16.000
         ├── 01:16:01.000
         ├── 01:21:41.000
         Track downloads finished in 4m0s
         Multiplexing...  ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 00:09
         �� Title downloaded in 4m29s!
         Processed all titles in 4m31s
    So when Unshackle falls back to the requests downloader on CBC, the video fails to decrypt (though the audio does decrypt) and then it gives:
         recognized.
    Angela, you were right, or at least partially - it was configuration but the downloader rather than the decryptor
  28. Ok so previously your error was
    This is fixed now, but i am getting below error
    PS D:\ops\unshackle> uv run unshackle dl DSCP https://discoveryplus.in/show/man-vs-wild
         Loaded 1/1 Vaults
      ────────────────────────────── Service: DSCP ───────────────────────────────
    │ D:\OPs\unshackle\unshackle\services\DSCP\__init__.py:573 in _request         │
    │   570 │   │   response = self.session.request(method, url, **kwargs)         │
    │   571 │   │        │
    │   572 │   │   try:                                                           │
    │ ❱ 573 │   │   │   data = json.loads(response.content)                        │
    │   574 │   │   │                                                              │
    │   575 │   │   │   if errors := data.get("errors", []):                       │
    │   576 │   │   │   │   code = next((x.get("code", "") for x in errors), "")   │
    │ C:\Users\xxxxx\AppData\Roaming\uv\python\cpython-3.12.12-windows-x86_64-none │
    │ \Lib\json\__init__.py:346 in loads                                           │
    │   343 │   if (cls is None and object_hook is None and                        │
    │   344 │   │   │   parse_int is None and parse_float is None and              │
    │   345 │   │   │   parse_constant is None and object_pairs_hook is None and n │
    │ ❱ 346 │   │   return _default_decoder.decode(s)                              │
    │   347 │   if cls is None:                                                    │
    │   348 │   │   cls = JSONDecoder                                              │
    │   349 │   if object_hook is not None:                                        │
    │ \Lib\json\decoder.py:338 in decode                                           │
    │   335 │   │   containing a JSON document).                                   │
    │   336 │   │        │
    │   337 │   │   """                                                            │
    │ ❱ 338 │   │   obj, end = self.raw_decode(s, idx=_w(s, 0).end())              │
    │   339 │   │   end = _w(s, end).end()                                         │
    │   340 │   │   if end != len(s):                                              │
    │   341 │   │   │   raise JSONDecodeError("Extra data", s, end)                │
    │ \Lib\json\decoder.py:356 in raw_decode                                       │
    │   353 │   │   try:                                                           │
    │   354 │   │   │   obj, end = self.scan_once(s, idx)                          │
    │   355 │   │   except StopIteration as err:                                   │
    │ ❱ 356 │   │   │   raise JSONDecodeError("Expecting value", s, err.value) fro │
    │   357 │   │   return obj, end                                                │
    │   358        │
    JSONDecodeError: Expecting value: line 1 column 1 (char 0)
    During handling of the above exception, another exception occurred:
    │ in _run_module_as_main:198                                                   │
    │ in _run_code:88                                                              │
    │ in <module>:10                                                               │
    │ D:\OPs\unshackle\.venv\Lib\site-packages\click\core.py:1462 in __call__      │
    │ D:\OPs\unshackle\.venv\Lib\site-packages\click\core.py:1383 in main          │
    │ D:\OPs\unshackle\.venv\Lib\site-packages\click\core.py:1850 in invoke        │
    │ D:\OPs\unshackle\.venv\Lib\site-packages\click\core.py:1819 in               │
    │ _process_result                                                              │
    │ D:\OPs\unshackle\.venv\Lib\site-packages\click\core.py:814 in invoke         │
    │ D:\OPs\unshackle\unshackle\commands\dl.py:800 in result                      │
    │    797 │   │   │   try:                                                      │
    │    798 │   │   │   │   cookies = self.get_cookie_jar(self.service, self.prof │
    │    799 │   │   │   │   credential = self.get_credentials(self.service, self. │
    │ ❱  800 │   │   │   │   service.authenticate(cookies, credential)             │
    │    801 │   │   │   │   if cookies or credential:                             │
    │    802 │   │   │   │   │   self.log.info("Authenticated with Service")       │
    │    803 │   │   │   │   │   if self.debug_logger:                             │
    │ D:\OPs\unshackle\unshackle\services\DSCP\__init__.py:132 in authenticate     │
    │   129 │   │   │   "x-device-info": f"dplus/20.8.1.2 (NVIDIA/SHIELD Android T │
    │   130 │   │   })                                                             │
    │   131 │   │        │
    │ ❱ 132 │   │   access = self._request("GET", "/token", params={"realm": "bolt │
    │   133 │   │        │
    │   134 │   │   self.access_token = access["data"]["attributes"]["token"]      │
    │   135        │
    │ D:\OPs\unshackle\unshackle\services\DSCP\__init__.py:584 in _request         │
    │   581 │   │   │   return data                                                │
    │   582 │   │        │
    │   583 │   │   except Exception as e:                                         │
    │ ❱ 584 │   │   │   raise ConnectionError(f"Request failed for {url}: {e}")    │
    │   585        │
    ConnectionError: Request failed for
    https://default.any-any.prd.api.discoveryplus.com/token: Expecting value: line 1
    column 1 (char 0)
    Exported cookies from Extension > https://addons.mozilla.org/en-US/firefox/addon/export-cookies-txt/
  29. Member
    Dec 2021
    england
    link look different, go look for tips
    uv run unshackle dl dscp -?
    try this one
    uv run unshackle dl DSCP /show/c9cd73f1-ecd5-4041-980d-03677c7d8017
    search for id links
    uv run unshackle search dscp "man vs wild"
