Great work as always stabbyThank you!
Any chance you have plans to bring back Discovery+ again?
Results 451 to 480 of 644
Thanks for the updated work Stabby, I would also like to know if DSCP will get an update? I tried vineless on DSCP with a wvd and prd N_m3u8DL-RE gave me a cmd command with 4 keys but when I ran that the video was still scrambled.
I really appreciate all the help. -
try that key
https://gofile.io/d/9bCZq5Code:--key 01054122d4ffddf92de0652d0d22f783:3ac2ba9aa22bf3a0c33a0373a13dd90a --key 0100e394316bb780ada7b6c40bbeab0e:b85a6f9bd9a9b1360703cc7ffdf1ac36
I'm using NortdVPN but this link from TEN Australia gives this error. Can anyone try with a different vpn to downlead for me ? TIA
ValueError: Could not parse ID from title:
https://10.com.au/news/sydney/sydney-news-10-nov-2025/tpv251110pxztj -
Thanks for your work on DSCP Stabby, I use that service quite a bit, you're a genius.
You can probably find the m3u8 link with stream detector. Then you could probably download it with yt-dlp interface as well. These are tools that you should get to know how to use as well. I am a dolt with stream detector but I used it quite a bit earlier today to get m3u8 links that I then added to yt-dlp interface and got some videos that way. Both programs are here at Video Help.
https://www.videohelp.com/software/The-Stream-Detector -
no, You want to do it yourself. It easy to do this without DRM
[Attachment 89771 - Click to enlarge] -
Tried it in firefox as chrome no longer supported and I am amazed it worked wow. Downloaded with tvdownloader Thanks a lot. Just tried yt-dlp interface also, excellent !
DSCP service has been added. Widevine L3 will get you max 720p on this service, so make sure to use playready for higher qualities:
Remember to get fresh cookies and clear any existing cache before running it for the first time.Code:Robustness: Widevine: L1: 2160p, 1080p L3: 720p PlayReady: SL3000: 2160p SL2000: 1080p, 720p
Hi Stabby Thank you for the work on the new DSCP service, we all appreciate your amazing skills.
I've updated your new services and added a new cookie but when I run a command for DSCP I get this error
Code:Service has no Geofence + Setting up new profile... ╭───────────────────── Traceback (most recent call last) ──────────────────────╮ │ in _run_module_as_main:198 │ │ in _run_code:88 │ │ │ │ in <module>:10 │ │ │ │ C:\Users\Kev\unshackle\.venv\Lib\site-packages\click\core.py:1462 in │ │ __call__ │ │ │ │ C:\Users\Kev\unshackle\.venv\Lib\site-packages\click\core.py:1383 in main │ │ │ │ C:\Users\Kev\unshackle\.venv\Lib\site-packages\click\core.py:1850 in invoke │ │ │ │ C:\Users\Kev\unshackle\.venv\Lib\site-packages\click\core.py:1850 in invoke │ │ │ │ C:\Users\Kev\unshackle\.venv\Lib\site-packages\click\core.py:1819 in │ │ _process_result │ │ │ │ C:\Users\Kev\unshackle\.venv\Lib\site-packages\click\core.py:814 in invoke │ │ │ │ C:\Users\Kev\unshackle\unshackle\commands\dl.py:800 in result │ │ │ │ 797 │ │ │ try: │ │ 798 │ │ │ │ cookies = self.get_cookie_jar(self.service, self.prof │ │ 799 │ │ │ │ credential = self.get_credentials(self.service, self. │ │ ❱ 800 │ │ │ │ service.authenticate(cookies, credential) │ │ 801 │ │ │ │ if cookies or credential: │ │ 802 │ │ │ │ │ self.log.info("Authenticated with Service") │ │ 803 │ │ │ │ │ if self.debug_logger: │ │ │ │ C:\Users\Kev\unshackle\Services\DSCP\__init__.py:113 in authenticate │ │ │ │ 110 │ │ │ │ │ 111 │ │ │ st_token = self.session.cookies.get_dict().get("st") │ │ 112 │ │ │ if not st_token: │ │ ❱ 113 │ │ │ │ raise ValueError("- Unable to find token in cookies, t │ │ 114 │ │ │ │ │ 115 │ │ │ profile = {"token": st_token, "device_id": str(uuid.uuid1( │ │ 116 │ │ │ cache.set(profile) │ ╰──────────────────────────────────────────────────────────────────────────────╯ ValueError: - Unable to find token in cookies, try refreshing.Last edited by kev043; 19th Nov 2025 at 19:17.
Had the same issue when I extracted the cookies in Firefox with 'current site' so used 'ALL' and then removed the lines that were not specific to DSCP. My cookie extension is from https://github.com/hrdl-github/cookies-txt
Since the fairly recent rejig on DSCP I always get:
I've tried a few different browsers and cookie grabbers, it's always the same result, no doubt it's my end, cookies are always a bit of a fiddle it seems. Just as FYI, my TVNZ one works and I'm adding this DSCP one into the same folder.- Invalid Token. Cookies are invalid or may have expired.
Edit: Also, thanks SBB for the continued support, it's very much appreciated. -
Big Thanks PunchDrunkL0ve it worked great! have a good day.
Had the same issue when I extracted the cookies in Firefox with 'current site' so used 'ALL' and then removed the lines that were not specific to DSCP. My cookie extension is from https://github.com/hrdl-github/cookies-txt -
https://github.com/rotemdan/ExportCookies is a solid extension that works with most sites, including Discovery.
Alas, same result for me, regardless of cookie extension it seems. I can log-in to DSCP without any issue, play through browser no problem, but I'm always hit with the same 'Invalid token' result. I deleted cookie and tried, it then gave me the OSError which suggests I'm placing it in the right path. As soon as I then add a new dscp.txt, it just tells me it's invalid again.
It worked before they altered their their platform. I'm not expecting any magic answer, just venting my own personal problem. I can grab from DSCP via WP2, so all is not lost, just annoying cookies always teeth my side.
Thanks all, excellent stuff as always. -
Does anyone know why this is happening? The video in temp folder is corrupted so I can't manually mux it
HTML Code:$ uv run unshackle dl cbc https://gem.cbc.ca/swipe-bet-repeat ▄ ▄▌ ▐ ▄ .▄▄ · ▄ .▄ ▄▄▄· ▄▄· ▄ ▄ ▄▄▌ ▄▄▄ . █▪██▌█▌▐█▐█ ▀. ██▪▐█▐█ ▀█ ▐█ ▌▪█▌▄▌▪██ ▀▄.▀· █▌▐█▌▐█▐▐▌▄▀▀▀█▄██▀▐█▄█▀▀█ ██ ▄▄▐▀▀▄·██▪ ▐▀▀▪▄ ▐█▄█▌██▐█▌▐█▄▪▐███▌▐▀▐█ ▪▐▌▐███▌▐█.█▌▐█▌▐▌▐█▄▄▌ ▀▀▀ ▀▀ █▪ ▀▀▀▀ ▀▀▀ · ▀ ▀ ·▀▀▀ ·▀ ▀.▀▀▀ ▀▀▀ v 2.0.0 - © 2025 - github.com/unshackle-dl/unshackle Service Config loaded Loaded 0/0 Vaults Loaded Widevine CDM: 28919 (L3) ─────────────────────────────── Service: CBC ─────────────────────────────── Service is not Geoblocked in your region Requesting new tokens... Authenticated with Service ──────────────────── Movies: Swipe. Bet. Repeat. (2025) ──────────────────── 1 Movie ──────────────────────── Swipe. Bet. Repeat. (2025) ──────────────────────── 1 Video └── [H.264, SDR] | en-CA | 1920x1080 @ 6811 kb/s, 29.970 FPS ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 00:41 Downloaded 1 Audio └── [AAC] | en-CA | 2.0 ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 01:08 Downloaded 5 Chapters ├── 00:00:00.000 ├── 00:13:15.000 ├── 00:25:58.000 ├── 00:36:58.000 └── 00:43:23.000 | Credits Track downloads finished in 1m13s Failed to Mux video to Matroska file (2): #GUI#error The type of file '/home/pc/Downloads/devine/temp/Video_223a1e68.mp4' could not be recognized. Multiplexing... ⠙ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
[Attachment 89819 - Click to enlarge]Last edited by vidsrme; 20th Nov 2025 at 13:57.
I'm all good...
Code:uv run unshackle env check ▄ ▄▌ ▐ ▄ .▄▄ · ▄ .▄ ▄▄▄· ▄▄· ▄ ▄ ▄▄▌ ▄▄▄ . █▪██▌█▌▐█▐█ ▀. ██▪▐█▐█ ▀█ ▐█ ▌▪█▌▄▌▪██ ▀▄.▀· █▌▐█▌▐█▐▐▌▄▀▀▀█▄██▀▐█▄█▀▀█ ██ ▄▄▐▀▀▄·██▪ ▐▀▀▪▄ ▐█▄█▌██▐█▌▐█▄▪▐███▌▐▀▐█ ▪▐▌▐███▌▐█.█▌▐█▌▐▌▐█▄▄▌ ▀▀▀ ▀▀ █▪ ▀▀▀▀ ▀▀▀ · ▀ ▀ ·▀▀▀ ·▀ ▀.▀▀▀ ▀▀▀ v 2.0.0 - © 2025 - github.com/unshackle-dl/unshackle Environment Dependencies ┏━━━━━━━━━━━━┳━━━━━━━━━━━━━━━━━━┳━━━━━━━━━━━━┳━━━━━━┳━━━━━━━━━━━━━━━━━━━━━━┓ ┃ Category ┃ Tool ┃ Status ┃ Req ┃ Purpose ┃ ┡━━━━━━━━━━━━╇━━━━━━━━━━━━━━━━━━╇━━━━━━━━━━━━╇━━━━━━╇━━━━━━━━━━━━━━━━━━━━━━┩ │ Core │ FFmpeg │ ✓ │ Y │ Media processing │ │ │ FFprobe │ ✓ │ Y │ Media analysis │ │ │ MKVToolNix │ ✓ │ Y │ MKV muxing │ │ │ mkvpropedit │ ✓ │ Y │ MKV metadata │ │ DRM │ shaka-packager │ ✓ │ Y │ DRM decryption │ │ │ mp4decrypt │ ✓ │ - │ DRM decryption │ │ HDR │ dovi_tool │ ✓ │ - │ Dolby Vision │ │ │ HDR10Plus_tool │ ✓ │ - │ HDR10+ metadata │ │ Download │ aria2c │ ✓ │ - │ Multi-thread DL │ │ │ N_m3u8DL-RE │ ✓ │ - │ HLS/DASH/ISM │ │ Subtitle │ SubtitleEdit │ ✗ │ - │ Sub conversion │ │ │ CCExtractor │ ✓ │ - │ CC extraction │ │ Player │ FFplay │ ✓ │ - │ Simple player │ │ │ MPV │ ✓ │ - │ Advanced player │ │ Network │ HolaProxy │ ✗ │ - │ Proxy service │ │ │ Caddy │ ✗ │ - │ Web server │ └────────────┴──────────────────┴────────────┴──────┴──────────────────────┘ Total: 13/16 All required tools installed ✓ -
ok thats fine,
now try with without subtitle, I got error with ccextractor.
this one is fine
uv run unshackle dl -ns cbc https://gem.cbc.ca/swipe-bet-repeat
Devine - Modular Movie, TV, and Music Archival Software
By billybanana in forum Video Streaming DownloadingReplies: 1866Last Post: 19th Nov 2025, 22:57 -
Bitrate confusion: HD vs. DV archival
By taigi in forum Capturing and VCRReplies: 3Last Post: 9th Nov 2024, 04:38 -
How do I completely remove the music and sound effects from a movie?
By cns00 in forum EditingReplies: 1Last Post: 15th Jan 2024, 13:11 -
Which software can remove music from show but keep character dialogue?
By Mohamed61020 in forum AudioReplies: 6Last Post: 2nd Jul 2023, 22:32 -
Software for simple music videos?
By dewiclements in forum Software PlayingReplies: 3Last Post: 26th Jul 2022, 02:21
Thank you!
