Page 15 of 16
FirstFirst ... 5 13 14 15 16 LastLast
Results 421 to 450 of 460
  1. Originally Posted by stabbedbybrick View Post
    Unshackle v2.0.0 was released, so I've updated the services and fixed the bugs I was aware of. Make sure to uv sync Unshackle to install the latest version. As for the Channel4 error mentioned above, I can't reproduce it. It's working without any issues on my end, so might've been just a temporary problem.
    I've also added 10Play and 7Plus. A lot of weird shit had to be done for these services, so there might be a few bugs here and there.
    Some general notes:
    • Use 'unshackle dl SERVICE --help' to get information about each service.
    • Use github issues to report bugs and suggestions.
    • When reporting a bug, please include title/URL and error output. I won't hunt down or guess whatever it is you're trying to download.
    • VPN/proxy issues is not something I can do anything about.
    Please also note that I'm not the dev of Unshackle, so I can't help with any issues. I'm not really using it myself on a regular basis, I'm just making these services for others to use since it's the only public and competently developed downloader out there at the moment. For any bugs and/or suggestions, I'd recommend checking their github or discord channel.
    uv sync Unshackle or uv sync unshackle doesn't work for with me
    error: unexpected argument 'unshackle' found
    Dec 2021
    england
    uv sync
    service update- git pull
  3. Originally Posted by iamghost View Post
    uv sync
    Doesn't work
    Dec 2021
    england
    uv sync
    Doesn't work
    you always say everytime "doesnt work", the problems is just you not your machine
    it always work with everyone...
    unshackle>uv sync
    Resolved 97 packages in 3ms
    Audited 97 packages in 93ms
    [Attachment 89682 - Click to enlarge]
  5. Unfortunately Moonlighting S02E14 is still stuck with version 2.0
  6. Originally Posted by iamghost View Post
    uv sync
    Doesn't work
    unshackle>uv sync
    It should be :-
    git checkout main
    git pull
    uv sync
    Thanks goes to PSXman_uk for info
    Dec 2021
    england
    why quote on me?
    taking the piss...
    not fault of unshackle 2.0
    its just 1 episode, move on to next episode..
  8. Originally Posted by iamghost View Post
    why quote on me?
    taking the piss...
    I don't know how to download a single episode or download the rest from the next one
    Dec 2021
    england
    tom already reply to you and show you how, read...
    https://forum.videohelp.com/threads/418705-Unshackle-Modular-Movie-TV-and-Music-Archiv...14#post2786060
    episode 14 error because of "\" can not add in video title name
    uv run unshackle dl -w s02e15-s05 STV https://player.stv.tv/summary/disney-moonlighting
  10. I've tried to download / start from S02E14 but I get this error
    Moonlighting S02E14 14. Every Daughter's Father is a Virgin ────
    1 Video
    └── [H.264, SDR] | en | 1280x720 @ 1987 kb/s, 25.000 FPS
    1 Audio
    └── [AAC] | en | 127 kb/s
    ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 00:03 • Downloaded
    4 Chapters
    ├── 00:00:00.000
    ├── 00:11:31.812
    ├── 00:23:32.400
    └── 00:33:10.300
    Widevine(AAAAVnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAA DYIARIQ+Es29N50Q...)
    └── f84b36f4de7441908ef5fb23a29937bf:673eac24b25c4727a 301bba467d4b9c2*
    from Local SQLite
    ❌ Download Failed...
    [WinError 32] The process cannot access the file because it is
    being used by another process:
    'C:\\Scripts\\unshackle\\temp\\Video_f69d8aba.mp4'
    An unexpected error occurred in one of the download workers.
    See the error trace above for more information.
    C:\Scripts\unshackle>
    Dec 2021
    england
    delete all in temp folder and start again
    edit: you keep doing episode 14!!, move over from episode 15, forget about 14
  12. Originally Posted by iamghost View Post
    One temp file I can't delete
    Yes but 15 works. I want to start from 14, why can't I ?
    Dec 2021
    england
    because it cant rename video name title with "/"
    [Attachment 89691 - Click to enlarge]
    episode 14 are still in temp folder, use mkvtoolnix to merge video and audio and rename it by yourself
  14. Originally Posted by iamghost View Post
    Hmm how do you merge the audio part ?
  15. You can also use Clever FFmpeg GUI to mux the video, audio and subtitle together.
  16. Originally Posted by Tom Saurus View Post
    Ok got it running but how do I extract / mux the audio part with it ?
    Dec 2021
    england
    I have done them...
    https://gofile.io/d/4HSyEW
    now forget about download episode 14 by yourself
    move on.....
  18. Originally Posted by iamghost View Post
    I have done them...
    move on.....
    Great thanks but I'd still like to know how to mux the video with Clever FFmpeg GUI
    Dec 2021
    england
    ok...
    you want to learn more with clever then your in wrong thread
    go to there and asking question> https://forum.videohelp.com/search.php?searchid=4631009
    you have visit Clever FFmpeg GUI download site, just grab download and dont bother scroll down, there is Guides and How to's
    [Attachment 89692 - Click to enlarge]
  20. SBB just added Australia SBS. I have tried SEVEN and it working well for me so far. Be warned there is PAL speed up in some TV series such as "The Irrational". This is not the fault of the service or Unshackle it is just how the channel deals with certain North American Shows. It has a remedy when it comes to playing via VLC:
    https://wiki.robotz.com/index.php/Compensate_for_PAL_Speedup_in_Digital_Video
    This remedy works well in VLC and for me corrects the issue. This happens for certain North American shows on the UK services as well. But regardless Unshackle is terrific as are the services. That you stabbedbybrick. Thank you also the developer of Unshackle. Also thank you to the poster earlier in the thread who showed me how to deal with Pal Speedup.
  21. I tested out SBS and did the --list-titles and --list -w S01E01 and it revealed just four video files, no audio no subtitle. Anyway I did a download and the audio and subtitle were in the video file. So it is different then other services in that aspect. It is terrific service. So don't be concerned as your audio is captured at the same as the video. Thank you to stabbedbybrick for using your skills to develop these services and thank you Sparky for the evolution of Unshackle building on the terrific Devine. Thank you to everyone who takes the time to help those of us who don't quite grasp things right away but with your guidance we get there.
    Additional Information: I had the default ariac2 as I hadn't set the downloader for SBS. I tried it with N_m3u8DL-RE and I am getting twice the download speed and hopefully the VPN stability will be the same.
  22. I decided to give TEN a try. I have added my credentials to the appropriate spot in the Unshackle.yaml I hadn't added a downloader and apparently it wants N_m3u8DL-RE as its downloader so I went to the appropriate spot in my Unshackle.yaml and added in the line:
    # TEN: n_m3u8dl_re
    Then I saved the .yaml but I am still getting this:
    C:\unshackle>uv run unshackle dl --list-titles TEN https://10.com.au/the-village
    Service is not Geoblocked in your region
    - Error: n_m3u8dl_re downloader is required for this service.
    I did a unshackle env check just in case and it reveals I have N_m3u8dl-RE installed and I checked my binaries folder and it is there.
    So I was wondering if someone else would do a check to see if they have this error with TEN. With Ozivine I had no success with TEN it was like BBC very adept at sniffing out my VPN and rejecting it. However since SEVEN worked so well for me last night I thought might as well give TEN at try. With Ozivine and seven I would get an episode downloaded and try another but the second would fail most of the time. So I would delete what was in the temp disconnect the VPN and give it another try and it would usually get that episode. Last night I was able to get a whole season of a show with no rejection of the VPN even after three hours of Unshackle working away at it.
    Thanks in advance and please appreciate I used my skills with that line of code to try to remedy the error and it didn't seem to work. So any guidance is appreciated as I probably have yet more to learn.
  23. Member
    Dec 2021
    england
    you will need add N_m3u8dl-RE as downloader in unshackle.yaml
    [Attachment 89710 - Click to enlarge]
    [Attachment 89711 - Click to enlarge]
  24. Member
    Dec 2021
    england
    if you would like all services mapping,
    it will be like that...
    downloader:
      TEN: n_m3u8dl_re
      ALL4: aria2c
      CBC: aria2c
      SBS: aria2c
      SEVEN: aria2c
      STV: aria2c
      iP: aria2c
      AUBC: aria2c
      CBS: aria2c
      CTV: aria2c
      CWTV: aria2c
      DSCP: aria2c
      ITV: aria2c
      MY5: aria2c
      PLUTO: aria2c
      ROKU: aria2c
      RTE: aria2c
      TUBI: aria2c
      TVNZ: aria2c
      UKTV: aria2c
  25. Originally Posted by iamghost View Post
    Thank you for your kindness for your guidance and I trust others learn along with me so I thank you for them as well. I did as you wrote and it has fixed the problem and it is downloading at the full speed that my DSL allows me which is something new for an Australian service. I will study and test the mapping you posted in your follow up post. I have been using N_m3u8dl-RE for TUBI and several other services. But I will test and see what this mapping gives me in terms of speed and VPN stability. Thank you once again for all that you do to guide us in this thread and others.
  26. I tested TEN and the download was a success. The episode has commercials in it but one can edit those out with LosslessCut. I am impressed by the speed of the download and one can live with commercials. It is terrific that this and other services have been added as of late. I remember with Pluto TV that stabbedbybrick back when were using Freevine that removing commercials resulted in lip sync issues and he had to delve in and find the cause which was bumpers.
  27. Originally Posted by Tom Saurus View Post
    That was my mistake. I forgot to filter out the ads for all tracks, not just 1080p. It should be fixed now.
  28. Originally Posted by stabbedbybrick View Post
    Thank you for fixing it.
    Update I did a download and it is definitely fixed.
  29. deleted
  30. Tubi has apparently started adding 1080p on some titles, so the service has been updated to include it.
    It's only available as H.265 though, so use '-v H.265' to request those tracks.
